Old 11-14-2007, 09:43 AM   #136
akrider
mild adventurer
Oddometer: 1,754
"floss" off that decal
If you need to remove a sticker from a tank or side plate just think floss.
Use your heat gun or hair dryer to loosen the glue and get one corner of the sticker loose. Then use fishing line or un waxed dental floss under the sticker. Just like flossing your teeth. Having an assistant keep the heat on the project helps.
If your air hose gets stuck under car tires in the shop, try putting old automotive brake shoes between the tire and floor. It makes a nice round corner for the hose to rub against.
To someone with only a hammer - all problems appear to be nails.
Ignoranus-def: someone who is stupid and an asshole.
akrider is offline   Reply With Quote
Old 11-15-2007, 05:43 PM   #137
guzzidave21
The Professor
guzzidave21's Avatar
Oddometer: 178
[quote=Allgonoshow]Make yourself two, maybe three babies. After a couple of years, their tiny hands will be a big asset in the shop.
I used my little brother.. Told him he had Japanese hands.
He grew up. Drats.
guzzidave21 is offline   Reply With Quote
Old 11-16-2007, 01:34 PM   #138
KiefferGS
Oddometer: 16
These bins on a rolling rack are fairly inexpensive (I have bought them at Sam's) and are great for seeing what you have without opening drawers. Grab a bin or two for a project and set them on the work bench. For example I keep soldering stuff in one, 12V connectors and crimpers in another, dremel and attachments in another, etc... I would five more if I had room!
KiefferGS is offline   Reply With Quote
Old 11-16-2007, 07:44 PM   #139
scooteraug02
Dog Rancher
scooteraug02's Avatar
Oddometer: 4,531
Originally Posted by thetourist
13 mm is supposed to be red, as is 9/16.
I use 3M electrical tape to mark sockets and wrenches.
http://stores.ebay.com/Steel-Labels $4.49 delivered Not mine, found on Ebay
scooteraug02 is offline   Reply With Quote
Old 11-19-2007, 07:16 AM   #140
lightsorce OP
Inner Banks Swamp Rider
lightsorce's Avatar
Oddometer: 220
Thumb Grease gun temperature
I have an unheated motorcycle/maintenance shed and when the temps drop the grease becomes Playdoh. I got a large old Tupperware storage container and put my grease and greasegun in it and stored it in the closet in the house. No smells and usable grease!
lightsorce is offline   Reply With Quote
Old 11-20-2007, 05:53 PM   #141
DirtyDave
Location: Im the only one here that doesent bleed black/gold
Oddometer: 105
Hammer and screw driver trick
Well it may work well but. What you are actually doing is stretching the threads on the likely aluminum or magnesium case. Be careful or you ma need a helicoil kit in with your hammer and screw driver the next time. Get an impact driver that you tap with a hammer their about 20 bucks at sears. This handy tool does the same thing faster and directs most of the force into rotation instead of your soft expensive case. It also fits in your saddle bag for those road side MF'ers. Dirty Oh yeh great thread.
"Don't worry all these roads are connected"
DirtyDave is offline   Reply With Quote
Old 11-22-2007, 05:54 PM   #142
Chubber
I am the Brewmaster.
Chubber's Avatar
Oddometer: 551
I just bought two sets, one for the sockets and one for the wrenches. Now I have to clean my sockets and wrenches really well. Sheesh.
Chubber is offline   Reply With Quote
Old 11-23-2007, 02:22 PM   #143
FrisbeeR1200GS
FrisbeeR1200GS's Avatar
Oddometer: 195
EVERY time I move something that's in my way, to a different part of my garage.....in less than 15 minutes it's back to being in the way. Sorry, I don't have a solution...that's your job!!
"Never Underestimate The Consequences Of Human Error"
FrisbeeR1200GS is offline   Reply With Quote
Old 11-23-2007, 04:49 PM   #144
Timmer
Timmer's Avatar
Oddometer: 2,357
My knee needed to be drained of fluid. When I saw the size of the syringe they used, I asked if I could have it. It works great with a little tubing on the end to remove or install fluids. The bonus feature is that it's graduated.
Need to install a phillips or caphead screw in a hard to reach location? Put a little chassis grease on the head of the screw and let grease help stick it to the screw driver.
timmer
Tim in Burien, WA
'05 R1200GS '03 F650GS
'08 WR250R
'03 Wing
'01 ST1100
Timmer is offline   Reply With Quote
Old 11-23-2007, 07:29 PM   #145
worldrider555
worldrider555's Avatar
Oddometer: 443
To Get rid of rust on parts and tools, use the electrolysis method
1. Get a Large Plastic Tub
2. Fill it up with water.
3. For every gallon of water add washing soda. (or baking soda)
4. Put rusted part in tub.
5. Put a piece of iron or stainless steel in the tub.
6. Hook the negative end of a battery charger to the part to be cleaned, and the positive to the piece of iron.
7.It should start to bubble, let sit for a few hours, and pull out and all the rust should be able to be wiped off with a paper towel.
Works great, just did it to a nail pull i left outside
worldrider555 is offline   Reply With Quote
Old 11-24-2007, 07:38 PM   #146
bullfrog
Dismember
bullfrog's Avatar
Oddometer: 593
Damn, I am lovin' this thread...
Here's a trick that I haven't seen here yet:
Got a filthy/crusty foam air filter???
Joe's Hand Cleaner or GoJo to the rescue!!!
Cuts through that grime FAST...
R1150GS Hack, Speed Triple 1050, 450XCW Plated, XR400R
bullfrog is offline   Reply With Quote
Old 11-24-2007, 08:11 PM   #147
Motojournalism
motojournalism.com
Motojournalism's Avatar
Oddometer: 1,666
This thread rawks
(Oxygen tank, swim fins, novelty bronze condom)
"Absorb what is useful, Discard what is useless, Add what is uniquely your own" - Bruce Lee
Motorcycle Travel Photography tips at motojournalism.com
Way Out West - Canada to the Darien Gap
Follow me on Twitter
Motojournalism is offline   Reply With Quote
Old 11-24-2007, 08:31 PM   #148
scooteraug02
Dog Rancher
Oddometer: 4,531
That's good. GoJo works to get finger prints off of oxidized paint too.
I asked an expert about cleaning air filters and he said
Mineral Spirits to cut the oil, then Dawn grease cutting dish soap and water to get the rest of the dirt out.
(Get a Dawn bottle dedicated to the garage so you don't piss off the wife)
Rinse the filter good, let it air dry.
Then put your oil in a big Zip lock bag and work the oil until the filter is covered.
Or I got a plastic one gallon paint container with a lid. Pour some Air Filter oil in the container and dip the filter in the oil. Gently squeeze out the excess oil. Put the lid on the container and use the oil again.
Always use rubber gloves. You never know if these chemicals will mess with your organs.
Old 11-24-2007, 10:54 PM   #149
Timmer
Timmer's Avatar
Oddometer: 2,357
Another way to remove rust is to soak pieces in a molasses solution.
Timmer
Tim in Burien, WA
'08 WR250R
'03 Wing
'01 ST1100
Old 11-25-2007, 09:50 PM   #150
Brooklyn Rob
Do'h!
Oddometer: 474
Originally Posted by Curtis in Texas
OK, I'd like to play this one too!
Here's how we do the Doo Hickey in Texas.
Our Tech Day last Saturday in my shop.
Harbor Freight 880 lb 120v winches mounted to an "I" beam. I use this to swap car bodys mostly, but we improvised for Tech day. The Harbor Freight Winches like these can be found on sale for less than $100 sometimes.
I have 5 of them.
This puts the engine case right at chest level and make draining the oil unnecessary.
I lift my bike up like this all the time to work on it. Back Problem!
I also used this Sunday on my KLR to lift my gas tank off the KLR while I fitted my Stebel horns under the tank. The IMS tank was almost full. And I knew there would be a lot of on and off fitting.
Here's a shot of a friends bike hanging while we worked on his engine gaurd.
I have even used the 440lb ones on my door.
Hope this gives you guys some ideas!
Curtis
Here's an even easier way to do the doo..
buy a Honda.
Brooklyn Rob is offline   Reply With Quote
Times are GMT -7.   It's 03:48 PM.
