Old 11-24-2008, 04:59 PM   #241
mark1305
Old Enough To Know Better
mark1305's Avatar
Oddometer: 6,070
Originally Posted by P B G
Searched this thread, I may have missed it rather it could have been mentioned. But the use of a box end wrench to increase leverage on a combination open/box end wrench. I know most people who work on stuff know this trick, but I figured hey some might not, and might as well put it on here.
Situation nut won't come loose, can't fit a socket/breaker bar into the location. Solution, take a box end wrench that fits the nut/bolt head, get it on the head of the nut. Take another box end wrench and interlock the box with the tines of the first wrench's open end.
reverse to tighten.
This trick combines well with another when makinga tool kit from scratch for a bike that came without one (like my R80 ST). I bought a metric stubby open/box end wrench set from Harbor Fright and used just the sizes needed on the bike knowing that stubbies cam be used in tandem as above to get adequate leverage.
Mark J
Merritt Island, FL
When a person asks you for advice, they don't want advice. They want corroboration.
mark1305 is offline   Reply With Quote
Old 11-24-2008, 05:28 PM   #242
P B G
Oddometer: 10,001
That and it can be better than a ratchet handle of the same length because it has less offset. So when you put rotational force onto the fastener the wrench doesn't want to twist.
Old 11-25-2008, 06:13 AM   #243
scooteraug02
Dog Rancher
scooteraug02's Avatar
Oddometer: 4,531
Just found out most of the local auto parts stores will rent you tools for FREE.
I was told you buy the tool then return it in good condition for a full refund. So the deposit is equal to the price of the tool. O'Rielly's had seperate rental tools so they don't mess up all the new ones. Advanced auto supposedly does the same thing.
Reminded of the time I went to buy 26mm socket. There was an empty package and another package with the socket in it. This policy must increase sales and cut down on theft.
scooteraug02 is offline   Reply With Quote
Old 11-25-2008, 10:08 AM   #244
P B G
Oddometer: 10,001
Yup autozone is deposit which is refunded, including the sales tax.
Things like sockets you should just buy to own, you'll need em eventually. Things like perhaps a gear puller or slide hammer. For sure rent.
Autozone also has alot of vehicle specific tools for rental. Which could be helpful.
Old 11-26-2008, 06:05 PM   #245
ibafran
villagidiot
Oddometer: 1,289
I have met a bike dealer or two who will 'sell' me a factory tool and give me my money back if I return the tool in great shape. I could see that the tool had been used many times. The parts counter guy will know if such a tool is available. Its understood that if you bung up the tool, its yours for the price of a new one to re-start the 'loaner program'.
"beware the grease mud. for therein lies the skid demon."-memory from an old Honda safety pamphlet
ibafran is offline   Reply With Quote
Old 12-01-2008, 03:17 PM   #246
e.Rock
No Guts, No Story
e.Rock's Avatar
Oddometer: 219
Originally Posted by wos
egg cartons- great for storing little bits you want to keep seperated and organised, some even have little locking bits on them to securely stack. I like the paper ones as you can write on them.
I read through 16 pages to make sure nobody already mentioned this, but +1 on the egg cartons. I keep several in the garage at all times. My favorite use is for bodywork fasteners. I label one end with "FRONT" and put the fasteners in as I take them off, the egg pairs are great for keeping track of left and right sides. Close them, put them on the shelf and do your work. They're in the same order when you're ready to put the bodywork back on.
-E
e.Rock is offline   Reply With Quote
Old 01-07-2009, 11:53 AM   #247
HowlingMad
drags knuckles
HowlingMad's Avatar
Oddometer: 1,356
rolling tool eyesore
Thought this was interesting. Not my style (hate peg board) but thought it clever. Tools on wheels are always a good idea.
Full story here.
HowlingMad is offline   Reply With Quote
Old 01-08-2009, 02:35 PM   #248
FistFullofDirt
whistle whistle whistle
FistFullofDirt's Avatar
Oddometer: 200
coupla things
Take you old desk top computer out to the garage. That way you can look at all the pictures you took when reassembling stuff. Its also useful for looking up parts, etc. I have the computer part on a shelf, and the screen and key board mounted on a platform thats welded to a pipe going up to the ceiling. This makes it a little flexible in case you hit it with something ( or in frusteration )
Also, the set of drawers under the work bench is now mounted on a cart with swivley wheels. The tools can be at hand wherever, and the top is good for working on things at a more waist height. When the job is done, just put the cart back under the workbench.
FistFullofDirt is offline   Reply With Quote
Old 01-08-2009, 02:47 PM   #249
JaySoy
JaySoy's Avatar
Oddometer: 336
Not really a trick, but something I find super convient if you take your bike apart as much as I seem to.
I hate dealing with stipped out Phillips heads and starting in hex head bolts with the tip of my finger (like for seats and stuff).
I'm slowly ousting all the bolts on my bikes in favor of these:
So I can use one of these instead of a screw driver or rachet.
JaySoy is offline   Reply With Quote
Old 01-09-2009, 06:59 AM   #250
Jonex
zipper suited sun god
Jonex's Avatar
Oddometer: 1,357
Electric angle grinders are about the handiest tools ever. I must have 10,000 hours on mine by now, and I made it even handier:
I took a 5/8-11 nut, turned its corners off on my mini lathe, and welded it to a short stump of stainless round stock which has a 3/8 threaded hole in it (and a matching relief cut in its end to receive the 5/8" nut).
This piece is an adapter for cut off wheels and they're spaced out from the handle so it's very usable. Now I don't have to run the air compressor every time I want to lop off a hunk of something.
Jonex is offline   Reply With Quote
Old 01-09-2009, 08:24 AM   #251
Jonex
Jonex's Avatar
Oddometer: 1,357
Need to mix up a little bit epoxy?
Stomp on a beer/soda can, and use its bottom as a mixing container. It's the perfect size and shape - the epoxy doesn't run away from the mixing stick as easy as when using a flat surface.
When you're done, throw out the can. If you save your cans, it's a tiny bit heavier now. Shhhhhh......
Old 01-11-2009, 10:56 AM   #252
ridewestKTM
ridewestKTM's Avatar
Oddometer: 1,707
Is this new?
When threading a shaft with a die I have always found that it won't track straight. This time I got a piece of threaded rod the same as the desired and put the shaft in my tail stock. Then I screwed the die onto that threaded rod -backward (ie not "start this way). Then put trhe shaft to thread into the headstock and put the shafts end to end with some pressure. Holding the head motionless I turned the die towards the new shaft.
It really went straight.
new or not new?
ridewestKTM is offline   Reply With Quote
Old 01-11-2009, 08:27 PM   #253
scooteraug02
Dog Rancher
Oddometer: 4,531
I use the plastic from laundry detergent containers. I can cut out mini application knifes/blades out of the plastic as well as little plates. Epoxy can run away with my method though unless you use the bottom part.
Old 01-11-2009, 09:59 PM   #254
2wheelsrbest
Oddometer: 280
1--You CAN reuse regular zipties most times. To un-do one, slip the point of a small screwdriver or otherwise pointy object between notched side of tie and the catch. Pry back the catch and it will release.
2--When you replace the head of your Sonicare toothbrush head, grab the little magnets off the base. They are glued on, but easily removed with pliers. Stout little magnets are useful for all sorts of stuff.
3--Sheets of cardboard were mentioned earlier. Bicycle shops are a good source of them, if you need another source.
2wheelsrbest is offline   Reply With Quote
Old 01-11-2009, 10:22 PM   #255
markjenn
Oddometer: 10,457
Wow, this IS being frugal. Zip ties at HF run about .7 cents apiece.
- Mark
Times are GMT -7.   It's 05:37 AM.
