Old 05-02-2009, 05:10 PM   #271
Old Nubbins
Old Nubbins's Avatar
Oddometer: 434
[quote=DevilNinjaDog]
Originally Posted by boldrider
Damn straight. My wife is a nurse and brought me three of these things. I use them EVERYWHERE. They fit into tiny spaces, hold stuff great and lock. Totally badass!
I always thought those were called 'roachclips'
Old Nubbins is offline   Reply With Quote
Old 05-05-2009, 10:02 PM   #272
eakins
Butler Maps
eakins's Avatar
Oddometer: 19,244
Originally Posted by jimmy2020
every time I remove a bolt or set a torque, I write the info or size on the bike with a sharpie on or near that area.
on the same note everytime i remove & put back a bolt i hit it w/ blue locktite stick.
Alaska
Butler Maps website:
http://www.butlermaps.com
Old 05-06-2009, 07:22 AM   #273
PackRat
Huey Guns
PackRat's Avatar
Oddometer: 1,455
A trick I've used for years is attaching the drill press chuck key to a bicycle inner tube about 16 inches long (just punch a round hole and stretch the tube over the chuck key). That makes it hard to misplace, pads your hand when applying pressure, and if someone (?) leaves it in the chuck when it is turned on, the tube will slap around loudly, but harmlessly, while wrapping around and holding the chuck key against the chuck while you duck, cuss, and shut off the switch.
"Packrat" IBA# 11205, AARP, ATP, CFI, A&P, USMC
__________________________________________
Rigor Mortis will be the first indication that I've grown up!!
Yungas Rd.-Bolivia, Alaska '08 - Labrador '10 -
PackRat is offline   Reply With Quote
Old 05-06-2009, 08:46 AM   #274
bomber60015
Anatomically Correct
bomber60015's Avatar
Oddometer: 14,614
is there a reason this thread isn't stickied (or whatever the past pluperfect may be) . . . . . . .
attach a haccksaw blade to the edge of the bench -- make a great tool to cut pieces of wet/dry sandpaper to a convenient size.
Old 05-06-2009, 01:20 PM   #275
HowlingMad
drags knuckles
HowlingMad's Avatar
Oddometer: 1,361
Good idea. I use one of those corporate ID badge things.
HowlingMad is offline   Reply With Quote
Old 05-08-2009, 07:15 AM   #276
Motoriley
Even my posing is virtual
Motoriley's Avatar
Oddometer: 2,686
Blue Masking Tape
I love this blue masking tape. Comes off even after 60+ days with no residue. Doesn't shrivel when wet and turn into that impossible to remove crud when dry like regular tape. Keep the cheap stuff around though for normal use.
04 Toyota Sienna, new wipers for 2011!!
Electricity (120 AC), Indoor Plumbing, new kitchen tap for 2010!!!
Color tube TV, Microwave Oven (yes she rotates!),Washer & Dryer,Paved Driveway,
Website - http://www.apormc.com/
Vids - http://www.youtube.com/user/Motoriley?feature=mhum
Motoriley is offline   Reply With Quote
Old 05-08-2009, 07:23 AM   #277
P B G
Oddometer: 10,001
Originally Posted by RandyB
Interesting. We used a mix of 3 parts CLP (The new stuff, no teflon) and 1 part ATF to clean weapons in Iraq. It worked better than anything I've used. It'll even remove copper fouling.
That's quite similar to the bore solvent known as "Ed's Red" Made from ATF, Stoddard Solvent (or acetone), lanolin and maybe something else I am forgetting.
Old 05-08-2009, 07:42 AM   #278
HighScore
No More, all done.
HighScore's Avatar
Oddometer: 928
Best hand cleaner EVER
Liquid dish soap (Palmolive or Sunlight)
Fistfulls of White sugar
Lots of soap
lots of sugar
Cuts through grease better than even the orange hand cleaner stuff.
Lots of soap lots of sugar lots of water
(old farmer's trick)
HighScore is offline   Reply With Quote
Old 05-08-2009, 08:30 AM   #279
RandyB
Oddometer: 5,072
Barbasol shaving cream cuts the grease well too.
I've been shot, cut, burned, blown up, fired, busted, promoted, reprimanded and decorated. What are you going to do? Ban me?
Blessed be the Lord my God, who prepares my hands for war and my fingers for battle. Psalm 144:1
RandyB is offline   Reply With Quote
Old 05-09-2009, 05:43 AM   #280
ibafran
villagidiot
Oddometer: 1,289
Awwright, I give up. What's CLP?
"beware the grease mud. for therein lies the skid demon."-memory from an old Honda safety pamphlet
ibafran is offline   Reply With Quote
Old 05-09-2009, 06:43 AM   #281
P B G
Oddometer: 10,001
Breakfree CLP
Cleaner Lubricant Protectant.
Mil-L-63460
Old 05-09-2009, 08:04 AM   #282
RandyB
Oddometer: 5,072
Originally Posted by P B G
Breakfree CLP
Mil-L-63460
Close. Breakfree is the civilian version and has teflon. CLP is the military version and doesn't. We're all green now, and I ain't talkin' uniforms. Depleted uranium good. Teflon bad....
Old 05-09-2009, 10:18 AM   #283
P B G
Oddometer: 10,001
I agree teflon bad, I personally use gunzilla.
Can you get the non-teflon CLP commercially?
Old 05-09-2009, 11:51 AM   #284
RandyB
Oddometer: 5,072
Maybe at a surplus store. Or you can just let the spooge settle to the bottom (of the bottle, pervs) and pour off the carrier.
Old 05-09-2009, 02:07 PM   #285
Voltar
Jr Asst Road Captain
Voltar's Avatar
Oddometer: 1,671
I keep a long thin rare Earth magnet in my toolbox. It is handy to stick onto a screw driver or socket extension when you need to hold a screw/nut.
BTW- very powerful rare Earth magnets are in every disk drive. Next time you throw out a drive, harvest the magnet.
- Voltar
My projects and stuff:
http://www.whiskeytangohotel.com/
Voltar is offline   Reply With Quote
Times are GMT -7.   It's 09:48 AM.
