Old 08-13-2007, 09:05 AM   #46
valvecrusher
tractus pro pensio™
valvecrusher's Avatar
Oddometer: 1,749
just in time
As above, it was stated to use a white board for notes to self.
My contribution is also about notes and records.
I keep a maintenance book for each of my bikes(and cars). Just a pocket notepad will do..
Write the bikes model on the front, and include every bit of maintenance that you do, date and mileage, along with notes of imporatance.. ie:
That part is nicked/ needs future replacement...etc
Eliminates the confusion of what you did, when you did it, and what you did it too.
Plus, the new owner ALWAYS gets a jolt when he realizes you took the time to document maintenance..plus it sometimes helps keep it on the 'good' end of the market scale.
On the cutout cardboard for bolts, i do that too. I use the gasket in the kit to trace a pattern onto cardboard. Then i use hole-punchers, just like you had in elementary school to punch the holes out for the bolts.
Then i take them out of the case, and place them directly into the cardboard cutout, in the respective hole.
If this part is to be apart for more than a day, i place $1 store masking tape over each bolt head to keep it in place. Then i bag it in a clear cellophane sandwhich bag, or gallon whatever bag.
I use the masking tape to tape the bag shut, and write on it with a black permanent marker..
All plastic bags go into one container, the lid taped shut and written on it it's contents.
Honda NX250??
I prefer to ride, and when i do, it's 'un Equi
valvecrusher is offline   Reply With Quote
Old 08-13-2007, 10:38 AM   #47
kellyk7
Who knows
kellyk7's Avatar
Oddometer: 1,746
Originally Posted by Spam16v
clean up your damn tools every time you use them. sounds complicated doesn't it? be amazed how much time and effort it saves. don't overcomplicate things, fix the simple stuff first. then advance onto bigger and better things.
Your kidding right?
doing this takes all the fun outa cleaning the shop,, = reward for shop cleaning is like getting a free pass to tool world. Look Honey New tools..
There's a fine line between "RED ASS" and "DUMB ASS"
"Life isn't about waiting for the storm to pass... It is about learning how to dance in the rain" - HAWK
kellyk7 is offline   Reply With Quote
Old 08-13-2007, 01:51 PM   #48
MookieBlaylock
MookieBlaylock's Avatar
Oddometer: 2,581
i had to take the secondary butterflys out of the new ride and they were held in by these tiny (#0) loctited screws. Fuckers would not budge and stripping them was not an option. Enter the $25 heat gun from Home Depot
MookieBlaylock is offline   Reply With Quote
Old 08-13-2007, 02:12 PM   #49
ydant
Dirty Adventurer
ydant's Avatar
Oddometer: 104
No heat gun, and a lighter wasn't getting it hot enough, so I solved the loctite problem recently using a dremmel with a cutting wheel. I intended to just cut the damn nut off, but the side effect was the metal got hot enough to break the loctite long before the nut was cut all the way through. Whatever works!
ydant is offline   Reply With Quote
Old 08-16-2007, 07:33 AM   #50
R_W
wannabe
R_W's Avatar
Oddometer: 4,126
Fiberglass tricks.
Need to clamp an irregular surface? Use old innertubes to get even pressure.
Need to vacuum bag one thing and no vacuum pump? FOODSAVER Use a vacuum cleaner to get most of the air out, then use a foodsaver (with check valve in the line) to do the final pull. Make sure to buy it from somewhere with easy returns REALLY handy for getting epoxy to pull into hairline cracks that you just can't grind open.
Red hair and black leather, my favorite color scheme...
R_W is offline   Reply With Quote
Old 08-18-2007, 09:26 PM   #51
openboatt
Don't harsh my mellow
openboatt's Avatar
Oddometer: 276
Big foam blocks for oil heads
I ride oilheads. When I change trans and final drive fluids I lean my GSs over on a big closed cell block I have extra for seat pedestals for white water canoes (mebbee 10-12 inch-thick chunks). Works great. Of course you have to be able to pick the pig back up. But most of us have had practice with that... obt
openboatt is offline   Reply With Quote
Old 08-27-2007, 07:12 AM   #52
lightsorce OP
Inner Banks Swamp Rider
lightsorce's Avatar
Oddometer: 220
Laugh Shop Trick
A lot of you probably already use this one. Aerosol brake cleaner works really well for cleaning greasy parts and grimy small engines. Be careful around the plastics though.
lightsorce is offline   Reply With Quote
Old 08-27-2007, 09:33 AM   #53
BobbyC
BobbyC's Avatar
Oddometer: 1,353
I use a rolling cart like this:
1/4" sockets, extensions, etc are invaluable when working on a bike.
Pick set. You'll be surprised how handy they are when you have them around.
-Bobby
'08 KTM 450 EXC-R
"I LOVE my bike!!!"
BobbyC is offline   Reply With Quote
Old 08-27-2007, 12:28 PM   #54
praetorian
praetorian's Avatar
Location: South-Central L.A. (Leland(NC) Area that is!)
Oddometer: 98
I can not believe how much I use mine. I just got them about a year ago and I wonder how I ever did anything in my garage without them.
praetorian is offline   Reply With Quote
Old 08-29-2007, 06:58 AM   #55
openboatt
openboatt's Avatar
Oddometer: 276
Pick set
Maybe we're talking about the same thing, and it's probably been mentioned, but old dental tools work great for getting into hard to reach places etc. obt
Old 08-29-2007, 07:28 AM   #56
eric2
®egister this:
eric2's Avatar
Oddometer: 3,800
great stuff, a few small items from me.
1) use nitrile gloves for working on the bike. No need to clean your hands later
2) save your plastic cottage cheese, or other disposable plastic containers for yourself and tech days. hand them out with sharpies and small paper bags so everyone can stay organized.
3) store your unused RTV in the freezer and it will never harden and force you
to cut the ends of the tube to get the remainder out. (make sure to hide it from SWMBO's sight)
4) a spare alternator belt fits nicely under the seat on a 12GS by the tailight
5) when doing complex disassembly, re-attach the screws and bolts to their original mount points after taking a piece off.
Eric
'06 R12GS, '13 s1000RR
Originally Posted by Big Steve View Post
I've yet to see a poor person driving a real gas hog......
lottery: A tax for people bad at math
eric2 is offline   Reply With Quote
Old 08-29-2007, 09:44 PM   #57
Rogue_Ryder
速 Flat Biller 速
Rogue_Ryder's Avatar
Oddometer: 7,702
Valve Lapping Compound
Do all your phillips screw heads on your bike look like shit? Try using some of this stuff in the head of the screw it'll let your screwdriver (MAKE SURE YOU USE THE CORRECT SIZE SCREW DRIVER) get more bite on the screw head and not mess up the screw head either. This works good on Body Panel Removal, Carbuerators and things that using an impact driver on don't make sense.
Apparently not many know this trick 'cause it seems like every used bike I buy has f'ed up screw heads on it and I need to use Vice Grips or dremel the screw heads for slotted to get them off
Braaaap!!!!
Rogue_Ryder is offline   Reply With Quote
Old 08-30-2007, 04:00 AM   #58
motu
Loose Pre Unit
motu's Avatar
Oddometer: 4,591
You used to be able to buy very expensive very small tubes of stuff for removing tight Phillips head screws without rounding them off.Very good stuff.
Then I noticed it was just valve grinding paste......
motu is offline   Reply With Quote
Old 08-31-2007, 05:55 AM   #59
xdbx
Motorcycle Connoisseur
xdbx's Avatar
Oddometer: 2,512
my bolt organizing method
this may seem a bit off, but my method for keeping bolts organized is this.
When you dissassemble whatever it is, lets say a side panel, take the bolt out and lay it on the floor according to where it goes. Take the panel off. Thread the bolts back in some back in their appropriate holes.
The benefit of this is twofold. First, you wont lose any hardware. Second, if the piece wont go on right, you know you've forgot a bolt!
**** Remember, especialy if your'e doing an oil change, thread them in all teh way so they dont rattle out. I rode around teh blcok to heat up the oil.... and forgot
xdbx is offline   Reply With Quote
Old 09-01-2007, 12:54 AM   #60
Allgo
No Whammy,No Whammy,STOP!
Allgo's Avatar
Oddometer: 1,051
Make yourself two, maybe three babies. After a couple of years, their tiny hands will be a big asset in the shop.
Also, buy EVERYTHING from Walmart. Then take it back immediately when you are done with it. Saves a lot of space. I call it Walrenting.
Allgo is offline   Reply With Quote
Times are GMT -7.   It's 11:46 PM.
