Old 07-02-2012, 01:11 PM   #736
aposaric
Garden mechanic ;-)
aposaric's Avatar
Oddometer: 270
When you have stuck pistons on your old brake calipers, especialy when you are on the road, the easyest way to get them out is to put a 13 mm ( or something simmilar in size) wrench in your caliper between the pistons, so it acts as a limiter. It prevents the "unstuck" pots to jump out.
1. put a wrench between the pots - secure it with some duct tape.
2. unscrew the bleed niple for few turns
3. atach a bike tire pump ( or a compressed air ) to the niple
4. pump the air and wait for the pots to slowly start to go out. first the loose ones are going to go out, keep pumping and make enough pressure to loosen the stuck ones ( you can use some wd 40 to help the stuck ones )
5. Once the all pots are moving, take your rubbler pliers and just pull all of the pots out, clean the oil passages and all of the servicing you were planing in the begining
My camera is dead so no pictures at the moment to make it a little bit easier to understand :-)
cheers
aposaric is offline   Reply With Quote
Old 07-02-2012, 02:49 PM   #737
P B G
Oddometer: 10,001
I always do the same but just crank on the brakes and see if that will do before using air pressure.
Usually if that gets them moving they'll come out will little fuss.
Old 07-02-2012, 02:55 PM   #738
scottrnelson
Team Orange
scottrnelson's Avatar
Oddometer: 1,447
You should be able to generate considerably more pressure by squeezing the brake lever than you could get out of an air compressor. But I've never tried to unstick a stuck caliper piston, so what do I know?
Old 07-02-2012, 03:31 PM   #739
P B G
Oddometer: 10,001
Ya I've never used the airtool thing either.
Air pressure behind a metal projectile is a gun.
Old 07-02-2012, 03:35 PM   #740
aposaric
Garden mechanic ;-)
aposaric's Avatar
Oddometer: 270
Usualy it works on the newer bikes, but I just finished servicing on a 22 year old tokico 4 pots from a zzr 600 d, and on each caliper 2 pots were stuck on one side, so only one side worked. If you pump the brake to much you just bend the disc, so my way it is much easier, and a lot cheaper because you don't bend a 300$ discs :-) . Most of the air compressors wil go to 8 bar presure, at least the ones on the gass stations, but even a 5$ hand bycicle pump will go over 12 bars if you put your muscles into it :-) I found a tons of 22 year old gunk inside, all rubbery and gelly shit, but after thurally cleaning it with wd 40 and carb cleaner ( amazing stuff, even removes the old paint from the calipers. I just replaced the rubber seals, put the new oil inside and they work amazing, as good as new, alhough 4 pot tokicos from the nineties are shit to begin with ;-)
Old 07-02-2012, 10:09 PM   #741
kc0stp
Lurker
Oddometer: 23
At least on the car side of things (never heard #'s for bikes) vacum assisted brakes generate in the area of 1100psi (with hydroboost brakes being double that) if thats not enough to break the pistons loose 200psi of air isnt going to cut it. Now I will admit both those numbers are for power assisted brakes but manual brakes shouldnt be to far off. (personally I find a good grease gun works better as it also helps lube them as it forces the pistons out.)
Help stop world hunger
Protected by Amsoil
kc0stp is offline   Reply With Quote
Old 07-03-2012, 03:32 PM   #742
P B G
Oddometer: 10,001
Then you flush out all that grease?
In regards to crushing the rotor... one would assume you do this job with the wrench stuck through there, or a c-clamp around it anyway, and not on the rotor.
Old 07-04-2012, 02:09 PM   #743
Fixnfly
Fixnfly's Avatar
Oddometer: 359
I've got into the habit of putting dates on anything that could "spoil" over time. Stuff like paint, car wax, rain X, JB weld, sealants, threadlocker, etc. I always had a problem under-estimating how old some of my stuff actually is.
01 DRZ400S 93 GSXR750 13 Z1000
Fixnfly is online now   Reply With Quote
Old 07-05-2012, 02:17 AM   #744
tgeliot
Topher
Oddometer: 1,354
Another good thing to write the date on is the batteries in your smoke/CO detectors.
Topher
1989 Transalproject. 2008 Suzuki V-Strom 650
I don't have a bucket list, I have a post-bucket list. So far it includes
1) Coroner's report is to read "Death by misadventure."
2) Dixieland jazz band at my funeral.
tgeliot is offline   Reply With Quote
Old 07-05-2012, 03:05 AM   #745
fallingoff
Oddometer: 3,677
always replace them on ur birthday
fallingoff is offline   Reply With Quote
Old 07-05-2012, 05:35 AM   #746
PineyMountainRacing
Oops....
PineyMountainRacing's Avatar
Oddometer: 2,292
Originally Posted by luxlogs View Post
Lord Help You if You Break One of Those Curly Fry Lights. EPA disaster zone, better not tell anybody.
So what's the deal with these bulbs? I use them in the shop because they don't get so hot. But I have broken a few.
PineyMountainRacing is online now   Reply With Quote
Old 07-05-2012, 06:18 AM   #747
P B G
Oddometer: 10,001
Just like any flourescent, they contain mercury. Which is in a vaporized form while the bulb is running.
Old 07-05-2012, 06:32 AM   #748
JimVonBaden
"Cool" Aid!
JimVonBaden's Avatar
Oddometer: 52,243
In 20 years they will be like asbestos, a seemingly good idea (forced on the public), but really a very bad idea.
The slight savings in electricity is far offset by the environmental damage, not to mention the high initial cost, and not nearly as long a life as predicted.
Jim
PS I use them in my video lighting systems because they do not put out much heat.
Old 07-05-2012, 08:42 AM   #749
trc.rhubarb
trc.rhubarb's Avatar
Oddometer: 1,989
*snip*
They can be had cheaply and it enables me to run 4 lights on the exterior of my home for the cost of one incandescent. Mercury is good for you! The government just knows that if we all had balls of it to play with, we wouldn't get any work done.
Side note - I have IE spell running and it wants to change your screen name to "Cambodian". Just thought that was funny for some reason.
2007 BMW GS Adventure / 2000 Ducati 900ss / 2010 Harley Ultra Limited / 1975 BMW R90/6 / 2006 DRZ400S
Follow me here
trc.rhubarb is offline   Reply With Quote
Old 07-05-2012, 08:43 AM   #750
ttpete
Rectum Non Bustibus
Oddometer: 5,825
Jim
More than a slight savings. The equivalent to a 100 watt incandescent in lumens draws only 23 watts.
LEDs are even more efficient, and once they get the price down, they'll obsolete CFLs. I have LED yard lighting that replaces four 100 watt incandescent floods and draws only about 30 watts.
15 BMW RnineT
09 Kaw Versys
Times are GMT -7.   It's 01:54 PM.
