Old 08-16-2012, 11:23 PM   #826
markjenn
Oddometer: 9,702
Originally Posted by cyclejohn View Post
I have not read through the entire 50 pages, sorry if this is a repeat.
To remove a centerstand from a bike, you will need to take off the centerstand spring. They are strong springs, and difficult to pull off. To easily remove, set the bike on the centerstand. The spring will be streched. Reach under the bike and insert 5 or 6 coins (nickels quarters , etc) in spaces where the spring has been streched. Then when you push the bike off the centerstand the spring will still be stretched, and should easily unhook from centerstand and frame.
I've heard of this one, but I've tried it on a couple bikes and it never worked for me.
- Mark
Old 08-17-2012, 12:25 AM   #827
warewolf
Tyre critic
warewolf's Avatar
Oddometer: 2,169
Send a message via MSN to warewolf Send a message via Skype™ to warewolf
I've done the opposite: fit the spring by inserting coins one by one into each coil to stretch it. It was a near thing, the coins kept wanting to fly out, but it did get the job done.
Cheers,
Colin
KTM LC4 640 Question? Check here first --> KTM LC4 (640) Index Thread
Originally Posted by Steve McQueen
All racers I know aren't in it for the money. They race because it's something inside of them... They're not courting death. They're courting being alive.
warewolf is offline   Reply With Quote
Old 08-17-2012, 05:52 AM   #828
JimVonBaden
"Cool" Aid!
JimVonBaden's Avatar
Oddometer: 41,494
Use large flat washers and stick a rod/wire through it to keep them in place.
Jim
JimVonBaden screwed with this post 08-17-2012 at 04:35 PM Reason: spelling
Old 08-17-2012, 03:22 PM   #829
Contevita
Cigar Adventurer
Contevita's Avatar
Oddometer: 1,108
Originally Posted by JimVonBaden View Post
Use large flat washers and stik a rod/wire through it to keep them in place.
Jim
Brilliant!
Contevita is offline   Reply With Quote
Old 08-18-2012, 01:32 AM   #830
warewolf
Tyre critic
warewolf's Avatar
Oddometer: 2,169
Jim
Awesome!
Cheers,
Colin
Old 08-18-2012, 03:20 AM   #831
Unstable Rider
World Wide Inmate
Unstable Rider's Avatar
Oddometer: 2,119
Damn.. that is a cool idea....
Thus far, I made a puller out of a coathanger and a block of wood for a handle.
Worked, but not as McGiver tech as the washer trick.
´¯`·.¸¸.·´¯`·.¸ ><((((((º>
`·.¸¸.·´¯`·.¸¸.·´¯`·.¸ ><((((º>
´¯`·.¸¸.·´¯`·.¸¸.·´¯`·.¸ ><((((((º>
Everything happens for a reason. "Still seeking the reason"
Unstable Rider is offline   Reply With Quote
Old 08-18-2012, 09:05 PM   #832
Tom S
Can I ride it?
Tom S's Avatar
Oddometer: 3,521
Originally Posted by Unstable Rider View Post
... but not as McGiver tech as the washer trick.
Washers don’t always work. I posted this one before, super easy & works great on a small very tight springs.
http://www.advrider.com/forums/showp...&postcount=670
Tom S is offline   Reply With Quote
Old 08-18-2012, 10:57 PM   #833
ER70S-2
ER70S-2's Avatar
Oddometer: 2,565
Using vice grips directly on the spring loop will kill the spring in the near future, it creates a 'stress riser' and the loop will break off. Something I learned snowmobiling, lots of springs on the exhaust system.
2004 DR650: 46,358 miles of
Originally Posted by Threewheelbonnie View Post
"BTW, I don't do style. It's a dirt bike, not some girlie dress-up thing." -
ER70S-2 is online now   Reply With Quote
Old 08-19-2012, 08:55 AM   #834
Fixnfly
Fixnfly's Avatar
Oddometer: 188
A paintbrush along with a garden hose does an excellent job of cleaning mud/dirt from hard to reach places on a bike or quad. I can make my muddy four wheeler look almost new in about an hour
01 DRZ400S 93GSXR750
Fixnfly is offline   Reply With Quote
Old 08-23-2012, 09:47 PM   #835
Bogfarth
MOTGATT on a Yamahog
Bogfarth's Avatar
Oddometer: 82
Talking And a few more...
Jim
Or you can get a length of cord (shoe lace, waxed string) and simply make a two loops out of it in a figure-8. Slip one loop between the last few coils of the spring, and then wrap it around the coils twice for security. Now run the other end through the loop at the coils to make a handle, and haul on it. A few weeks ago I had pulled the duplex spring off of my V-Star 650's kick stand and couldn't get the *^&$ back on. This did the trick. With thinner cordage, make more loops to spread the stress and lower the risk of punchin' yaself in da mug.
Got a screw or bolt that will turn a little, but sticks and won't come out? Squirt some Liquid Wrench on the offender, slap your wrench or screw driver on the head, and turn it loose-tight-loose. You'll be able to use this "rocking" movement to pop the screw or bolt out without boogering the head all to hell and gone. I did this a little bit ago to pop a made-from-cheese screw holding a heat shield in place. It likely would have snapped in half if I'd bullied it. Remember that patience is key, young Grass-Smoker.
Learned this one here on ADV the other day. Tired of forking over $5+ per O-ring at the dealer? McMaster-Carr has a ton of 'em, including solvent(gas)-proof ones, on their web site ( McMaster-Carr ). All that's needed is the measurements of your dud. Or you can check a local bearing supply shop; odds are they might have the very part you need on the cheap.
Bogfarth
Christopher Robin was sitting outside his door, putting on his Big Boots.
As soon as he saw the Big Boots, Pooh knew that an Adventure was going to happen.
Bogfarth is offline   Reply With Quote
Old 08-24-2012, 09:53 AM   #836
markjenn
Oddometer: 9,702
Originally Posted by Bogfarth View Post
Or you can get a length of cord (shoe lace, waxed string) and simply make a two loops out of it in a figure-8....
This trick works, but my experience is that you have to have very stout bootlaces - I've shredded shoe laces on several attempts. A variation is to not pull directly on the spring, but loop it over some part on the back of the bike and then pull forward - this doubles the mechanical advantage. But be darn sure the bike is well-secured - this is an easy way to have a bike come tumbling down on top of you.
- Mark
Old 08-24-2012, 11:03 AM   #837
H96669
A proud pragmatist.
H96669's Avatar
Oddometer: 2,872
Silly stand springs. I use my brake pliers, the ones designed to remove/install brake springs in automotive brake drums. Work well in most cases.
Have tools, will travel!
Old 09-02-2012, 01:18 PM   #838
FMFDOC
Oddometer: 163
This thread is so awesome!!!
Illegitimi non carborundum!
Tell someone you love them today, because life is short...but shout it at them in German because life is also terrifying and confusing.
So much adventure, you can hear the theme from National Geographic playing in the background...
ANY WAY YOU CAN! http://youtu.be/Gg_G-NeSmW0
FMFDOC is offline   Reply With Quote
Old 09-02-2012, 01:32 PM   #839
Stumpalump
Oddometer: 122
Need a magnifying glass or mirror to see where your head won't fit? Your hand with a smart phone will fit into a tight spot and you can take a picture. Same thing with reading fine print on circuit boards. Take picture then zoom it up to a size you can see.
KTM 950A
Rokon 2X2
Montesa 315R trials
KTM 200 EXC.
XR400
Stumpalump is offline   Reply With Quote
Old 09-02-2012, 01:36 PM   #840
Stumpalump
Oddometer: 122
Super glue will work as lock tight in a pinch and assembly lube will work as an anti seize. Neither are as good as the proper stuff but how often are you proper?
KTM 950A
Rokon 2X2
Montesa 315R trials
KTM 200 EXC.
XR400
Times are GMT -7.   It's 11:42 AM.
