Old 01-02-2013, 03:28 AM   #901
arcanum
Oddometer: 316
make room for carb removal
This would be an individual choice according to bike model. Mine is a cb450sc Nighthawk
When taking carbs off the bike to clean them,consider making more room for the removal. On a recent Nighthawk carb clean,I took the rear fender, air filter box& battery,and then I had an easier time to get the carbs off and back on. I also took off one side of the engine mount off so I could get the carbies off with the throttle cables attached. I had a cardboard box placed at a comfortable height stuffed with rags and a clean towel on top to catch any little part that dropped during dis-assembly.
This paid off big time,because it took two or three attempts to get the carb sorted. The carb sinch stayed at factory setting because the control cables stayed attached.It was also easy to see that the accelerator pump worked by directly viewing the little squirts of gas because the cables were still attached. Of course,you must use your own judgement about how your own bike dis-assembles whether or not you wish to try this method
arcanum is offline   Reply With Quote
Old 01-02-2013, 09:20 AM   #902
JimVonBaden
"Cool" Aid!
JimVonBaden's Avatar
Oddometer: 52,984
Spill proof tank draining on a BMW.
Use an old Quick Disconnect and a piece of hose to drain the tank:
Jim
JimVonBaden is online now   Reply With Quote
Old 02-12-2013, 01:37 PM   #903
stsmike
Oddometer: 30
Wheel polishing
I found this in the NGWclub.com site (Goldwing), so its not mine. A member there purchased some Lester wheels for his GW. He wanted to polish the outer edge, while powder-coating the spokes and hub. The wheel was pretty beat up, so he had a lot of work to do. He built this ingenious rig to spin the wheel while he sanded/polished it.
He clamped a board to his drill presses table. This board extended out a few feet from the press. He drilled a hole in the end that protruded away from the press and installed a bolt that could be used as an "axle". He slid the wheel (with bearings) over the bolt and secured it with a washer and a nut; thus allowing the wheel to spin freely on the bearings. A belt slipped over the wheel and then the chuck (although I would feel better about chucking up a small pulley and shaft) allows the drill press to spin the wheel!
This would allow sanding and polishing go very much faster and would keep things "even".
Sorry, I thought I knew how to post pics
http://i287.photobucket.com/albums/l...2723Medium.jpg
http://i287.photobucket.com/albums/l...2732Medium.jpg
http://i287.photobucket.com/albums/l...2735Medium.jpg
http://i287.photobucket.com/albums/l...2739Medium.jpg
Stolen (shamelessly) from here: http://www.ngwclub.com/forum/viewtop...38587&start=75
stsmike screwed with this post 02-12-2013 at 02:09 PM
stsmike is online now   Reply With Quote
Old 02-12-2013, 03:13 PM   #904
GlennR
Playin' in the Fire
GlennR's Avatar
Oddometer: 2,134
stsmike,
Good repost. That gives me some good ideas. There's a lot you can do with a drill press. Btw, I have a "radial arm" drill press that has a 17" reach. Came from Harbor Frt for about $225. Best deal I ever got from them.
GlennR is online now   Reply With Quote
Old 02-13-2013, 10:36 AM   #905
scooteraug02
Dog Rancher
scooteraug02's Avatar
Oddometer: 4,521
You used this Instead of this
scooteraug02 is offline   Reply With Quote
Old 02-13-2013, 02:56 PM   #906
stsmike
Oddometer: 30
Thanks Scooter!!
Old 02-13-2013, 05:17 PM   #907
marchyman
Cam Killer
marchyman's Avatar
Oddometer: 7,470
Jim
Huh? Doesn't the fuel normally come out the line that is floating in the air and go into the tank where you connected a hose? It is the return line from the fuel pressure regulator that is dangling in your photo, isn't it. Or do I have it wrong?
marchyman is offline   Reply With Quote
Old 02-13-2013, 06:12 PM   #908
JimVonBaden
"Cool" Aid!
Oddometer: 52,984
No, when unplugged a QD is sealed. I used a male QD to plug into the female QD to get the fuel going.
Jim
Old 02-14-2013, 11:32 PM   #909
Interceptor
Interceptor's Avatar
Oddometer: 60
Cool2 ABS Brake Fluid System Flush
While doing an ABS system flush on a friends RT, we floated a plastic bottle cap in the front brake reservoir .
This stopped brake fluid from squirting out when squeezing the brake lever.
Interceptor is offline   Reply With Quote
Old 02-15-2013, 12:58 AM   #910
warewolf
Tyre critic
warewolf's Avatar
Oddometer: 2,584
Brilliant! I had a bike once that would fountain brake fluid from the res on the most gentle of squeezes, it was very frustrating.
Cheers,
Colin
KTM LC4 640 Question? Check here first --> KTM LC4 (640) Index Thread
The Stable
warewolf is offline   Reply With Quote
Old 02-15-2013, 08:55 AM   #911
H96669
A proud pragmatist.
H96669's Avatar
Oddometer: 4,669
I like that better than dropping a coin in the reservoir. I shall be doing the plastic trick in the next couple days.
Hum....maybe I'll even cut a piece of plastic just the right size and keep that with the other "special tools".
Have tools, will travel!
Old 02-15-2013, 03:52 PM   #912
JimVonBaden
"Cool" Aid!
Oddometer: 52,984
Damn, great idea!
Jim
Old 02-19-2013, 03:55 PM   #913
fritzcoinc
Enjoying my last V8
fritzcoinc's Avatar
Oddometer: 7,005
I thought a squirt like that ment air in the system?
Regards
Fritzcoinc
96 XR650L, 96 Guzzi Sport, 07 BMW K1200GT,
86 Husky 400 XCE, 00 Husky Te 610 e, 1999 Husky TC610 SM, 2000 Cagiva GC; Google: TX7
fritzcoinc is offline   Reply With Quote
Old 02-20-2013, 07:52 AM   #914
bomber60015
Anatomically Correct
bomber60015's Avatar
Oddometer: 13,153
not necessarily air . . . some (most) ,maser cylinders will discharge fluid from the hole that supplies it to the piston bore, until the piston covers the hole . . . this isn't often seen, as the reservoir is most often covered during use, yes?
"Here is your country. Cherish these natural wonders, cherish the natural resources, cherish the history and romance as a sacred heritage, for your children and your children's children. Do not let selfish men or greedy interests skin your country of its beauty, its riches or its romance. T.R.
Old 02-20-2013, 09:43 AM   #915
stainlesscycle
stainlesscycle's Avatar
Oddometer: 2,267
10 second master link pliers - cost $0.00
current bikes
stainlesscycle is offline   Reply With Quote
Times are GMT -7.   It's 07:35 PM.
