Old 02-20-2013, 11:32 AM   #916
Tom S
Can I ride it?
Tom S's Avatar
Oddometer: 4,433
Originally Posted by stainlesscycle View Post
10 second master link pliers - cost $0.00
Explain their purpose.
Tom S is offline   Reply With Quote
Old 02-20-2013, 11:49 AM   #917
EvanADV
Big Bearded Boy
EvanADV's Avatar
Oddometer: 1,338
I need to devote a couple hours to reading this thread! Got about 15 pages in and there is some great info in here. I will try to remember any tricks of my own to share if they haven't been covered already.
Current Steeds: '08 FJR1300 | '02 DR650
Former Steeds: '99 DR650 | '02 DR650 | '09 DL650 | '07 B1250
9 states left to ride: WI, MN, ND, SD, UT, OK, KS, AK, and HI.
First Trip on 2 Wheels. 10,000 miles. 21 years old.
NC to Maine for Lobster Dinner
EvanADV is offline   Reply With Quote
Old 02-20-2013, 12:06 PM   #918
Tallbastid
Let's get tropical
Oddometer: 1,344
I find the 5 gallon water cooler tubs to be awesome for taking oil to be recycled. The small opening at the top makes it unlikely any will slosh over and spill in the Jeep and it'seasy to pour thatnks to said opening. The square shape also makes it easy to push the passenger seat forward and clamp the oil between the dash and the passenger seat.
Just make sure you don't return the bottle after you're done storing oil in it! I spraypaint 'oil' on mine to make sure it's never returned.
2013 Tay-Nay-Ray
Tallbastid is offline   Reply With Quote
Old 02-20-2013, 01:17 PM   #919
richarddacat
abnormal character
richarddacat's Avatar
Oddometer: 3,360
I use plastic cat litter containers, the opening is larger, also square and less likely to be reused as a water container. Since we use them all the time, after a visit to Jiffy Lube for a dump I go next door to the recycling bins.
* 05FJR/88K75c/97M3 *
Mid-TN Tag Riders
richarddacat is offline   Reply With Quote
Old 02-20-2013, 01:26 PM   #920
stainlesscycle
stainlesscycle's Avatar
Oddometer: 2,264
installing and removing master link clips. i have modified them a little more so the one unground side is now shorter than the other. instant on/off for master link clips. i now have 45 seconds into their construction. not pretty but very effective.
current bikes
stainlesscycle screwed with this post 02-20-2013 at 01:32 PM
stainlesscycle is offline   Reply With Quote
Old 02-20-2013, 04:58 PM   #921
Tom S
Can I ride it?
Tom S's Avatar
Oddometer: 4,433
Gotcha. Never had any trouble just poppin’ ‘em off & on with a screwdriver.
Old 02-20-2013, 05:44 PM   #922
stainlesscycle
Oddometer: 2,264
no chance of bending, losing or damaging them with the pliers. i could pound nails with a socket wrench, but i use a hammer (most of time).
i can barbarian with the best of them, but the right tool for the job makes life a little easier - and i do a few chains a month...
current bikes
Old 02-24-2013, 11:00 AM   #923
CatSailor
CatSailor
CatSailor's Avatar
Oddometer: 29
Clogged Carburetor Fix, Blind Bearing Removal, Exhaust Studs
Usually in the spring or summer my friends start bringing their engines to my garage that have been sitting since last summer. Usually a 6" section of stripped multi conductor lamp cord does the trick. Depending on the size of the clogged jet, 1-3 strands twisted and GENTLY worked through the jets gets the problem fixed.
Blind bearing removal w/o a puller: pack the recess behind the bearing, place a shaft in the center of the bearing and hit it with a hammer. The bearing will pop out.
A foiled gum wrapper wrapped shiny side out around an old buss type fuse will get you home - fix the reason of the blown fuse 1st!
2002 XR650R
2002 WR250F
It is impossible to make anything fool-proof because fools are so ingenious.
CatSailor is offline   Reply With Quote
Old 02-24-2013, 11:15 AM   #924
marchyman
Cam Killer
marchyman's Avatar
Oddometer: 7,428
Why do I seem myself with a face fill of splattered grease if I try this?
marchyman is offline   Reply With Quote
Old 02-24-2013, 01:49 PM   #925
HapHazard
Waiting for Gudenov
HapHazard's Avatar
Oddometer: 2,259
Curly - Izzat you?
HapHazard is offline   Reply With Quote
Old 02-24-2013, 05:34 PM   #926
ttpete
Rectum Non Bustibus
Oddometer: 5,844
I use torn up paper towels soaked in water for this. It's less messy.
15 BMW RnineT
09 Kaw Versys
Old 02-26-2013, 10:45 AM   #927
scooteraug02
Dog Rancher
scooteraug02's Avatar
Oddometer: 4,522
Home Depot and Lowes have these concrete mixing tubs that would be perfect for changing transmission fluid or some thing big and they are about $13.
scooteraug02 is offline   Reply With Quote
Old 02-26-2013, 10:48 AM   #928
scooteraug02
Dog Rancher
Oddometer: 4,522
I read on another site that Lacquer Thinner will clean jets. I haven't tried it yet. He said even new bikes sitting on the showroom floor will clog the jets.
scooteraug02 screwed with this post 03-05-2013 at 07:50 AM
Old 02-26-2013, 12:30 PM   #929
dad2bike
Cranky Old Fart
dad2bike's Avatar
Oddometer: 4,012
Those are awesome as parts cleaning tubs too.
Sent from outer space with my Thunderbolt with Tapatalk.
Tom
2006 950 Adventure "Big Orange", 2009 690R "Ginger",2003 525 EXC,
To Think is to Create!
My2Wheels
690 WIKI
dad2bike is offline   Reply With Quote
Old 02-27-2013, 12:57 PM   #930
zap2504
Dave E.
Oddometer: 618
Also Hoppe's #9 solvent for cleaning guns.
zap2504 is offline   Reply With Quote
Times are GMT -7.   It's 01:38 AM.
