Old 04-08-2013, 05:34 PM   #991
GlennR
Playin' in the Fire
GlennR's Avatar
Oddometer: 2,163
What's cheap about making a DIY version of something that's "almost nothing" to begin with? I've got tons of crap cluttering my shop, why spend money on more if I don't need it?
Some of us need to think about saving for more important things....booze, drugs, kid's college funds, etc.
GlennR is online now   Reply With Quote
Old 04-08-2013, 08:33 PM   #992
marchyman
Cam Killer
marchyman's Avatar
Oddometer: 7,534
Making washers out of old bleach bottles takes time that could be better spent on the booze and drugs.
marchyman is offline   Reply With Quote
Old 04-08-2013, 08:41 PM   #993
PFFOG
Richard Alps-aholic
PFFOG's Avatar
Location: Western NY, further from NYC than 6 entire states
Oddometer: 2,759
You obviously haven't seen any of us multi- task
PFFOG is online now   Reply With Quote
Old 04-09-2013, 04:59 PM   #994
wos
Oddometer: 1,697
Originally Posted by scottrnelson View Post
We have a winner for biggest cheapskate of this entire thread.
Sorry, couldn't resist.
cheap yes but I don't ride a KLR, A Vstrom so I can take the insults in stride. I is a Canoodian and the shipping on those things would make it a pain in the ass when I can throw a hole saw in the drill press and punch out enough to experiment with for free.
wos is offline   Reply With Quote
Old 04-10-2013, 08:25 AM   #995
Guano11
Am I Trending?
Guano11's Avatar
Oddometer: 1,400
Handy Rolling Organizer
$50 kitchen cart at IKEA.
Perfect for aerosols, those odd quarts of oil, etc. Middle shelf is adjustable to accommodate odd heights. Tray bottoms are mesh like a parts washer. Comes in turquoise if your garage needs some "Pop!"
Sticker-ready.
Guano11
Time flies like an arrow.
Fruit flies like a banana.
Guano11 is offline   Reply With Quote
Old 04-10-2013, 09:16 AM   #996
Narrdo
Narrdo's Avatar
Oddometer: 186
I like that!
Sent from my DROID RAZR using Tapatalk 2
"A stone's throw out on on either hand from that well ordered road we tread, and all the world is wild and strange."
Narrdo is offline   Reply With Quote
Old 04-14-2013, 08:15 AM   #997
H96669
A proud pragmatist.
H96669's Avatar
Oddometer: 4,716
Originally Posted by wos View Post
might just try to make something like those washers out of old bleach bottles
Had to do that recently but used lids from foodservice buckets. Had to be a very specific thickness/size and my rather large collection of nylon washers did not have that "specific" size/thickness. Probably doesn't even exist anyway.
Ice cream buckets??? Worked so well on my old GMC drain plug that I never replaced it with a proper one in 10 years of ownership. I kind of grew attached to it.
Have tools, will travel!
Old 04-30-2013, 05:58 AM   #998
scottrnelson
Team Orange
scottrnelson's Avatar
Oddometer: 1,496
Can't get the core out of your SuperTrapp muffler to repack it? You don't have a nice straight shot to use a broom handle like in their video where they remove the core from a muffler on some big cruilser?
(Step 2): Get a board and six cheap screws that are the same threads as the ones holding your disks in (don't take a chance of wrecking your good screws). Use one of the disks as a template to drill six holes. Put a screw through each hole as you drill it to keep things aligned. When you have six, insert those screws into the muffler core, tighten and now you can easily twist and pull that sucker out of there. I just invented this method this morning and it was so much easier than any other method I've seen.
(Step 1): Can't get those rivets out that hold the core in place by using a drill? A sharp chisel and a good size hammer will have the heads off of the rivets quickly, then a punch of the right diameter will knock them to the inside easily.
(Step 3): I'm not to this part yet, because I don't have the packing material, but leave the core attached to the board to easily align the holes when you put it back in.
Repacking a SuperTrapp doesn't have to be such a difficult ordeal.
Old 05-01-2013, 02:56 PM   #999
Pike Bishop
Pull Down the Ponzi.
Pike Bishop's Avatar
Oddometer: 10,590
Originally Posted by MookieBlaylock View Post
i had to take the secondary butterflys out of the new ride and they were held in by these tiny (#0) loctited screws. Fuckers would not budge and stripping them was not an option. Enter the $25 heat gun from Home Depot
A soldering gun also works well for this, especially where you don't want to cook nearby parts.
Pike Bishop is offline   Reply With Quote
Old 05-01-2013, 04:04 PM   #1000
barko1
barko1
barko1's Avatar
Oddometer: 3,380
The bastards in my C14 stayed put even with the solder gun
DR650, 98 Bimota SB6R, Kawasaki 14, 67 X-6 Scrambler (apart), SL350K1 (apart), 77 Goldwing 1000, Triumph Thunderbird Sport, Triumph Daytona Super III, DR650, MZ Skorpian Sport Cup, 71 Triumph Daytona 500, KDX220
barko1 is offline   Reply With Quote
Old 05-11-2013, 03:10 PM   #1001
HapHazard
Waiting for Gudenov
HapHazard's Avatar
Oddometer: 2,311
Tire Tank
I was having problems with the bead sealing on my Sportster front wheel, as well as a leaking valve stem.
Checking for the bead leaks without a tank is easy - lay the tire down, and using my wife's indoor plant watering can, fill the depression between the rim and tire and watch for bubbles.
But I couldn't figure how to submerge enough of the valve stem to make sure I'd fixed it (using the bathtub would be pushing my wife's indulgence).
Until:
Big cooler to the rescue!
HapHazard is offline   Reply With Quote
Old 05-25-2013, 05:08 PM   #1002
AustinJake
TE450-KLE-FXDWG
AustinJake's Avatar
Oddometer: 3,844
x-posted from another thread by request:
I screwed 2 eye hooks into the bottom of the garage wall, used 2 tie-downs to secure the bike, and then used my floor jack, I still use this technique on other bikes, I love cheap tricks.
____________________________________
Get fit. Stay safe. Enjoy life. Learn something to help someone in need.
AustinJake is offline   Reply With Quote
Old 05-25-2013, 09:34 PM   #1003
ER70S-2
ER70S-2's Avatar
Oddometer: 6,713
Talking
I'm a cheap trick. So what 'r you doin' tonite?
J/K you perverts.
2004 DR650: 62,605 miles
2013 WR250R
SUZUKI DR650SE INFORMATION INDEX
Originally Posted by Threewheelbonnie View Post
"BTW, I don't do style. It's a dirt bike, not some girlie dress-up thing." -
ER70S-2 is offline   Reply With Quote
Old 05-25-2013, 10:08 PM   #1004
*Gmoney*
don't look here
*Gmoney*'s Avatar
Oddometer: 911
I always use dish soap mixed with water in a spray bottle.
Spray whole tire and rim, kick back wait if its a real slow leak,
fast leaks bubble up instantly.
Mark leak, rinse repair.
When I take my car tires to the tire store and they tell me "we can't find no leak" I pull my trusty soap spray out and embarrass them, by showing them where the bubbles are.
*Gmoney* is offline   Reply With Quote
Old 05-25-2013, 10:23 PM   #1005
*Gmoney*
don't look here
*Gmoney*'s Avatar
Oddometer: 911
Originally Posted by MPH View Post
When doing an oil change (on whatever), as you are getting your tools and drain pails 'n stuff together, take the minute and go downstairs and bring up the big bag of clay cat litter that the ex-GF inadvertantly bought (I use clumping), and put the bag of clay litter next to your work area.
This will guarentee that you don't do any major spill'age.
(YMMV)
Mark
A fireman once told me he has to respond to fires in supermarkets,
clean up in aisle 7 oil spill and they put cat litter on it.
He said some oils mixed with scented cat product equals combustion.
Times are GMT -7.   It's 06:55 AM.
