09-12-2007, 10:48 AM
#91 | ||
erm
Oddometer: 1,120
before reading this and I found it better than a razor. It's the inlet manifold gasket and quite fiddly getting a razor to the far end.
09-13-2007, 05:47 AM
#92 | |
Dirty_Sanchez
Oddometer: 2,094
We all have used scrapers of some sort in the past to remove gaskets but we're just making the mating surfaces even worse by the introduction of additional scratches and gouges on the mating surface of the gasket. It's foolish to make the mating surface even rougher by scraping. Chisel contains methylene chloride. It will take the paint off if you're not careful. You should wear eye protection while using it. It will burn the crap out of your lip or the back of your hand if the slightest drop touches it. Bank robbers like it because it eats their fingerprints (I'm joking). It is a Loctite product. And now for my usual disclaimer: I'm ADVrider's very own unofficial official Loctite Factory Rep and I approved this message. Does anyone know where I can get a bucket of ohm's? Dirty
No, really, the mustache means I love you. '09 KTM 250SXF for Sale, take a look: http://advrider.com/forums/showthrea...7#post21410167 |
09-13-2007, 09:21 AM
#93 | |
Location: South-Central L.A. (Leland(NC) Area that is!)
Oddometer: 98
Just a note of caution. I am a Pharmaceutical Manufacturing Tech and I use MeCl (Metthylene Chloride) on a daily basis. According to its MSDS sheet it is a know Carsenogen, Tetatagen, & Mutagen. A minimum of a half face respirator w/ a methylene Chloride filter or an OV(organic vapor) filter should be used when ever you are using a Methylene Chloride based product. Where I work we are not even allowed in the process room where MeCl is being used without haveing another person with us. If you can smell it, you are over-exposed to it. Again, with the proper PPE, it is a great product. Robert |
09-13-2007, 09:36 AM
#94 | |
renewed hope
Oddometer: 1,891
09-13-2007, 09:54 AM
#95 | |
Oddometer: 384
Peter |
09-13-2007, 10:24 AM
#96 | |
Oops...
http://www.mobilemrt.com http://www.dorkpunch.com "I've been going to this high school for SEVEN YEARS. I'm no dummy!" -Charles De Mar. |
09-13-2007, 01:53 PM
#97 | |
Oddometer: 98
09-15-2007, 09:37 PM
#98 |
bar napkin engineering
Oddometer: 1,285
Garage tips
My daughter and I just got back from the dentist. My dentist and I are on a first name basis and saves some of his old dentist tools for me. Some of them come in very handy as o-ring picks. They work great in the tricky spots. 2HE
Motorcycles are my life. Not my lifestyle. My Smugmug: http://twinheadlighternie.smugmug.com/ Dakota Motorsports |
09-24-2007, 06:55 PM
#99 |
Old Enough To Know Better
Oddometer: 5,516
If this has been covered before now, sorry but I don't remember seeing it.
I keep safety glasses, ear muffs, and gloves on or next to the bench with mounted power tools. No excuses not to put on the safety gear before flipping the switch. Except day before yesterday. I had left two pairs of gloves inside the spare bedroom that's been doubling as a "clean" engine assembly room. So when I got the bright idea to smooth some grooves off of the outside of a clutch hub for the M900, I lazily started spinning it on a shaft by holding it at a shallow angle to the bench belt sander - without gloves becasue they were in the house. So when the hub suddenly climbed the shaft to my left hand .... you know where this is going.... A hub that weighs about a pound spinning at about 1000 rpm has a lot of energy. I was lucky that the first spring mount that connected with my little finger right at the last joint didn't make it through the joint or out through the nail. After putting up with the throbbing for 24 hrs, both pairs of gloves went out to the garage on my next trip back out there. If I'd been wearing the leather gloves that usually stay there for all the bench tools, I would probably just have a purple fingernail at most instead of four deep lacerations and a purple nail and a couple more minor booboos to the back of the hand and the thumb. Ya'll be safe - keep the safety gear right at the bench.
Mark J Merritt Island, FL When a person asks you for advice, they don't want advice. They want corroboration. |
09-25-2007, 07:01 PM
#100 | |
Dirty_Sanchez
Oddometer: 2,094
No matter how hot the part gets, this Cat would never use gloves while using a bench grinder. I've seen a finger get ripped off when a finger inside of a glove got caught between the wheel and the part rest years back. Dirty
09-26-2007, 07:14 AM
#101 |
it is known, dammit!
Oddometer: 2,154
Apply a thin coat of copper paste on the thread of every bolt, screw and nut you have on your bike when it´s still new and you´ll always be able to loosen them easily when you want to, they won´t rust fast.
My European Ride Reports: Through the Dolomites To Castle Neuschwanstein Three Days in the Alps Erding, Pilsen, Passau |
09-26-2007, 09:06 AM
#102 | |
Team Listo
Oddometer: 18,298
You've never owned a KTM have you? Same idea, but with Loc-Tite! |
09-26-2007, 10:07 AM
#103 |
Dave E.
Oddometer: 460
plastic fluid jugs
Great for all sorts of uses. I cut the side/bottom out of a windshield washer fluid jug and use it for a giant flexible scoop - I pour a jar of hardware into it when I'm looking for a bolt/washer/nut/screw and can pour the contents back into the jar when finished. Cut the sides of another jug into large strips so you can put them under tire irons to avoid scratching wheels. Drill a hole in the cap of another jug the same size as the OD of a 1/4" fuel line and use as a gallon aux fuel tank. Cut a rectangular hole in the side of an antifreeze fluid jug as an oil change catch basin (using the original spout to pour the oil into a recycling container).
09-27-2007, 08:16 PM
#104 | |
Oddometer: 2,710
09-27-2007, 08:20 PM
#105 |
Oddometer: 2,710
When loosening a bolt that you're sure is getting ready to snap off, have patience and tighten the bolt again and then back it back off a bit and soak with penetrating fluid, you will find yourself gaining ground slowly but surely on every loosening cycle.
