Old 08-30-2007, 04:04 PM   #16
SimpleSimon
Aspiring advrider
SimpleSimon's Avatar
Oddometer: 3,345
Nice write up! I just went through this exercise myself before a long ride last week. The only thing I didn't do was adjust the steering.
5f? Is that like riding down a 90 degree cliff face into a lake of fire? I thought 4f was bad. Abdelhub
"Assembled Spectator Scoring With Incriminating Photographic Evidence" or A.S.S.W.I.P.E. - Granparacer
SimpleSimon is offline   Reply With Quote
Old 08-30-2007, 04:55 PM   #17
Brooklyn Rob
Do'h!
Oddometer: 471
Keith:
This is one of the coolest threads ever. We rock.
If you want, I could break some more shit for my 18k service. I'm sure our F650 brothers would eagerly await the next chapter of the saga.
P.S.: Couldn't you rig up some of your numerous bottlecaps as valve shims? They looked about the right size to me.
Rob
Brooklyn Rob is offline   Reply With Quote
Old 08-30-2007, 05:04 PM   #18
brewer90
brewer90's Avatar
Oddometer: 503
For future reference you don't need to remove the oil tank to drain it. Just put the bike on the sidestand and let it drain. The few extra drops you get out aren't worth the extra time. Of course you had to remove it anyway for the valve check.
Also you can pull the cams without having to remove the tensioner which will prevent you from having to take the whole damn bike apart. It takes a little patience to get the move just right but nowhere near as long as what you went through removing everything.
brewer90 is offline   Reply With Quote
Old 08-30-2007, 05:04 PM   #19
Brooklyn Rob
Do'h!
Oddometer: 471
Hi Poops.
Old 08-30-2007, 05:16 PM   #20
canuck479
Oddometer: 84
I might also suggest zip tying the cam sprockets to the cam chain befor removing from the cams that way going to gether is much easier and timing is not an issue. Also plugs should always be checked after the valves.
What fun is being an adult if you can't act like a kid
canuck479 is offline   Reply With Quote
Old 08-30-2007, 05:17 PM   #21
brewer90
brewer90's Avatar
Oddometer: 503
Originally Posted by Brooklyn Rob
Hi Poops.
You consider that pooping on a thread? You've been around here long enough to know what poop looks like and suggestions on time savings isn't it.
Old 08-30-2007, 05:24 PM   #22
Hondo
What if its a Samsquamch?
Hondo's Avatar
Oddometer: 7,728
Once finished, this looks like a Hall of Wisdom thread.
Great writeup!
LC8World.com - KLRWorld.com Forums - Nighthawk Forums
"Life's an adventure, and I refuse to live a boring one."
Hondo is offline   Reply With Quote
Old 08-30-2007, 05:31 PM   #23
dakarboy OP
ugly and stupid
dakarboy's Avatar
Oddometer: 1,408
hey rob, guess what got here about 20 mins ago?
the reason the tank is pulled is because in most shops, bikes are tied to lifts and its easier to remove it and let it hang then move the bike around.
the oil line can be worked around, but why? you run the risk of rounding the tensionor bolt out. which gives you alot more room to work when yanking out the cams.
why in gods green earth would i want to ziptie the sprockets to the cam chain? makes no sense. they gotta come out.
i am having alot of fun with this though. i have probably two more posts before i am finished.
2003 F650Dakar
1980 SP1000
"IN THE ABSENCE OF REAL TORQUE VALUES, HE-MAN TORQUE SPECS WILL PREVAIL"me
dakarboy screwed with this post 08-30-2007 at 05:36 PM
dakarboy is offline   Reply With Quote
Old 08-30-2007, 05:38 PM   #24
brewer90
brewer90's Avatar
Oddometer: 503
I see your point on the oil tank/lift.
You don't need to work around the oil line or even touch the cam chain tensioner bolt. Zip tie the cams to the cam chain so you don't lose your timing. Remove the cam carriers and set aside. Now wiggle the front cam until it comes loose. You now have enough room to replace the both the intake shims. Repeat on the back cam for the exhaust. I'll try to find a picture which will explain this better than I can.
Here is a pic
Old 08-30-2007, 05:41 PM   #25
Brooklyn Rob
Do'h!
Oddometer: 471
No need to get your knickers in a wad.
My message is to someone who knows who they are.
Old 08-30-2007, 05:44 PM   #26
brewer90
brewer90's Avatar
Oddometer: 503
No problem. I thought your knickers were in a wad. Hi Poops whomever you are.
Old 08-30-2007, 05:44 PM   #27
dakarboy OP
ugly and stupid
dakarboy's Avatar
Oddometer: 1,408
I see you point on the oil tank/lift.
You don't need to work around the oil line or even touch the cam chain tensioner bolt. Zip tie the cams to the cam chain so you don't lose your timing. Remove the cam carriers and set aside. Now wiggle the front cam until it comes loose. You now have enough room to replace the both the intake and exhaust shim and repeat on the back cam. I'll try to find a picture which will explain this better than I can.
the only time you should touch those bolts is if you are working on a central tunnel dohc 4 cyld. just pull the cams on singles and anything with side driven cams. and as for the timing, you put it together the way it came apart.
2003 F650Dakar
1980 SP1000
Old 08-30-2007, 05:47 PM   #28
Brooklyn Rob
Do'h!
Oddometer: 471
Those brown shirted assholes!
Wait, I seem to recall another group of a holes in brown shirts...
Old 08-30-2007, 06:14 PM   #29
dakarboy OP
ugly and stupid
dakarboy's Avatar
Oddometer: 1,408
you lost me rob.....
did you still want to come over and wrap this up? we might be done by two or three pessimistacally, midnight optimistically....damn, two big words back to back did i spell em right jeb?
2003 F650Dakar
1980 SP1000
Old 08-30-2007, 06:17 PM   #30
dakarboy OP
ugly and stupid
dakarboy's Avatar
Oddometer: 1,408
oh, i just got it. a little slow on the uptake...
2003 F650Dakar
1980 SP1000
Times are GMT -7.   It's 05:21 PM.
