Old 03-28-2015, 02:23 PM   #1
team ftb OP
Befuddled Adventurer
Oddometer: 1,730
High Quality P&S waterpoof camera
So here's the question. For years I've used a Luminix waterproof P&S camera to document my travels. It's been reliable and taking decent enough pictures.
However lately it has been acting up pretty bad and I've had this issue despite firmware reloads etc.
The picture are either blown out or not looking crisp with exposures etc.
Lately I have used my Canon S100 that takes what seems to my uneducated eyes better pictures.
Ideally what I would like is the same picture taking quality in a weatherproof P&S. I believe it is the image sensor that is the key behind the quality of the Canon S95 and 100series cameras. Are the any manufacturers making a comparable weatherpoof camera in the P&S size?
Cheers,
Team FTB
Team "Fingering The Bean"
team ftb is offline   Reply With Quote
Old 03-28-2015, 03:09 PM   #2
K1W1
K1W1's Avatar
Oddometer: 1,841
Photos 2 and 3 are user error not camera error. You have large amounts of bright sky which is causing the camera to have exposure problems with the dark areas. Photo two looks like you might be pointing straight towards the sun on the right side of the image.
There are a ton of what camera should I buy threads on this forum and invariably you will get 500 replies and 700 different recommendations all based on "I have a camera X and its great". The reality is that in 2015 there is no such thing as a bad camera available on the market. Any camera you buy will work fine if used correctly and within its design capabilities.
Stick with the LUMIX and spend some time learning photography technique.
K1W1 is offline   Reply With Quote
Old 03-28-2015, 06:02 PM   #3
GSWayne
Old Guy nOOb
GSWayne's Avatar
Oddometer: 3,068
Based on this review: http://www.dpreview.com/articles/249...camera-roundup
I got the Olympus TG-3 and I am happy with it. For higher quality weatherproof (not waterproof) use I have a Pentax K-30 DSLR that I also like very much. Pentax has lots of weatherproof lenses also.
It isn't the conditions its the decisions
Don't bring a motorcycle to a car fight
GSWayne is offline   Reply With Quote
Old 03-29-2015, 12:41 AM   #4
toecutta
06 R1200GS Adventure
toecutta's Avatar
Oddometer: 163
hi team ftb
i have had 3 lumix cameras now. drowned 1 diving (>25m and it kept going for an additional 18 months), 1 the LCD craped out after 18 months of daily salt water use, the current is going strong. I too have noticed that their ability to handle back-lit conditions seems to drop off over time but have not worried about it as i give these little cameras a hard life. always in my bag and in salt water at least 2-3 times a week. the mrs is now looking for an upgrade (each camera had a primary "owner" in the family... i got the last update)
i have used sony P&S in a ikelite housing.. u can attach red filters for green water and GREATLY increase the quality of "wet" shots BUT.. its just a little too bulky for a every day convenient carry
i look forward to responses to this post as well (PS.. i am currently biased towards the canon range at the moment for next camera... just for a change)
toecutta is online now   Reply With Quote
Old 03-29-2015, 04:52 AM   #5
Grinnin
Forever N00b
Oddometer: 2,779
dpereviews reviews a lot of cameras and usually has an annual review of waterproof P&S cameras. They critique image quality and let you compare images from different cameras side-by-side.
2014:
2013 included a Lumix:
http://www.dpreview.com/reviews/2013-waterproof-roundup
Then their "feature search" allows you to specify "waterproof" then select different sensor sizes:
http://www.dpreview.com/products/sea...&ref=mainmenu#!
While that search doesn't show any small P&S with larger sensors, it does show that about half of recent cameras use BSI-CMOS sensors which combine the advantages of CMOS and reduce some of the disadvantages (like light smear from bright spots).
So you can search for a newer sensor technology or just use the side-by-side image comparisons.
Good luck.
"The belief that there is only one truth, and that oneself is in possession of it, is the root of all evil in the world."-- Max Born, Nobel Physicist
Grinnin is online now   Reply With Quote
Old Yesterday, 05:46 PM   #6
team ftb OP
Oddometer: 1,730
K1W1 - No doubt I am the first person to be in need or proper technique when taking pictures and well understand a lot of my pictures are shot using incorrect technique. One of the basics I know is get the sun behind me and do that everywhere I can. I chose the pictures above specifically knowing the the sun was to my quarter in both the pictures and yet the sky is continually over exposed. This is my grumble with the camera, it overexposes the sky even in situations it should not, or at least I think it should not, haha. It was not always like this, just over the last year. My prior Lumix Waterproof Camera did the exact same trait after two years of use. Hence why I'm looking for a change. Granted I'm in SEA where the sun is strong and frequently pics are shot at midday during the rides which is the least opportune time.
Anyway your advice is noted and appreciated, thank you.
Cheers,
Team FTB
Old Yesterday, 05:54 PM   #7
team ftb OP
Oddometer: 1,730
Yes I read that review doing some research and have utilized that sight before when choosing my prior Lumix's. Thank you. It ranks at the top of the heap along with the Lumix in lots of tests, I was wondering if there was any other compact choices that may blur the lines of water and weatherproof I may be overlooking. i don't go diving with the camera I just frequently go swimming in the rivers unintentionally.
Above is with the Lumix with no sky and is acceptable.
I would love my Can S100 but don't want the bulk of a diving housing. I looked at the commercial plastic bag housing but they looked unergonomic in terms of handling and bulk also. Maybe another option is a simple Ziplock bag kept handy for the river crossings.
Cheers,
Team FTB
Old Yesterday, 05:58 PM   #8
team ftb OP
Oddometer: 1,730
2014:
Good luck.
Thank you for the detailed response and suggestions Grinnin and I'll take a look to see if I can deduce which camera would offer what I'm looking for, much appreciated.
Cheers,
Team FTB
Old Yesterday, 05:58 PM   #9
Roland44
Oddometer: 806
2014:
Good luck.
I'm in the market for a new camera as well. Very helpful info, thanks!
Roland44 is offline   Reply With Quote
Old Yesterday, 06:12 PM   #10
toecutta
toecutta's Avatar
Oddometer: 163
is that curryinahurry with you FTB? if its not its his evil twin! :-)
Originally Posted by team ftb;
[IMG
http://withgusto.smugmug.com/Other/updated-pics/i-7GcFxQk/0/L/P1070630-XL%5B1%5D-L.jpg[/IMG]
Old Yesterday, 10:40 PM   #11
Wakizashi
Classic Adventurer
Wakizashi's Avatar
Oddometer: 32
Actually, IMHO, the limiting factor is not the sensor size but rather the need for the waterproof cameras to have one layer of additional toughened glass over the lens element. This results in a decrease of contrast and an increase in lens flare.
Like you I use a Lumix (TS4) for riding, and my wife's Sony RX-100 for "better quality" shots. The reduction in contrast is quite apparent irrespective of resolution.
James P., Assero Gear
Style. Comfort. Protection.
Wakizashi is offline   Reply With Quote
Old Today, 01:21 AM   #12
WIBO
Will it buff out?
WIBO's Avatar
Oddometer: 3,726
I'm in the kind of same position...take camera out of pocket whether it be raining or dry..point and shoot and ride after a pause. Video quality is a great seller for me. I take the odd clip here and there...needs to be compact too when not riding,fast enough to take out of pocket and film banter and stupidity of my fellow riders when it happens spontaneously
I wonder what this will turn out to be like...seems to be ideal....????
http://www.adorama.com/IPCDMCTS6O.html
Any thoughts from Inmates that know more than I do?
The Suit:What would you consider to be your greatest weakness?
Me: Honesty.
The Suit: Honesty? I don't think honesty could be construed as a weakness.
Me: I don't give a fuck what you think.
WIBO is online now   Reply With Quote
Times are GMT -7.   It's 04:03 AM.
