Old 05-17-2013, 08:00 AM   #1546
RidingDonkeys
Purveyor of Awesome
RidingDonkeys's Avatar
Oddometer: 8,585
I like things that serve multiple purposes. I keep a few Nite-Ize Figure 9 carabiners in my kit for camping anyhow, so I have them when I'm most trips. They come in several different sizes, but all function the same. They could easily work in the setup suggested above. They are great for guy-lines on your tent too.
Sit Stay Ride: The Story of America's Sidecar Dogs
More info at www.sidecardogs.com
Clinging to sanity, one motorcycle at a time.
RidingDonkeys is offline   Reply With Quote
Old 05-17-2013, 08:48 AM   #1547
team ftb
Befuddled Adventurer
Oddometer: 1,688
Originally Posted by mpatch View Post
It weighs less and is smaller than a piece of cordage.
http://www.petzl.com/us/outdoor/mult...nders-0/tibloc
The only issue I see with the Petzl Ascender is that you have to use rope diameters suited for climbing. In looking for a compact pulley system you would be wanting the smallest strongest rope you could get away with (ie 5mm Spectra, Dyneema, etc.) in order to save weight and packing volume. The Petzl necessitates a more traditional diameter rope near 10mm in diameter which will add a lot more bulk to the package.
Cheers,
Team FTB
Team "Fingering The Bean"
team ftb is offline   Reply With Quote
Old 05-17-2013, 11:33 AM   #1548
jesusgatos
fishing with dynamite
jesusgatos's Avatar
Oddometer: 2,384
Originally Posted by Rave View Post
Or you could just ride smaller, lighter bikes and ride over/around just about anything you might run into. Haha.
jesusgatos is offline   Reply With Quote
Old 05-17-2013, 01:10 PM   #1549
GSJon
GSJon's Avatar
Oddometer: 1,619
You could throw in a few of these Harken blocks with a 23,000 kg working load (46,000kg breaking load) and a few hundred feet of Vectran line an be good to lift most anything. You may need a separate pannier to carry them but Mohammad will not be struggling to move the mountain.
Then again a stick of dynamite would do about the same thing
Jon
ADVMax: BMW's do not break down - they fail to proceed.
GSJon is offline   Reply With Quote
Old 05-17-2013, 02:31 PM   #1550
DiscoDino
DiscoDino's Avatar
Oddometer: 1,819
I don't think you are using the full potential of the bike:
You seem to be on an uphill, I would then turn that heavy GS1200 around, point it downhill...tie the tree via that first pulley as you did, then tie the end of the rope to the bike...I am sure you will exert more than 2x the force the gentleman is trying to exert with his legs.
For what it's worth to the group, A friend and I both carry similar z-drag/pulley setups on our bikes as part of our toolkit (this is a toolkit thread right?) Anyhow, they've been useful many times for multiple purposes (as seen in the photo). I consider it essential kit when I go real far out where no cars ever come by.
Adventurer transitioning from 4x4 to 2x1
'07 G650Xch - Under Mod-struction
DiscoDino is offline   Reply With Quote
Old 05-17-2013, 02:37 PM   #1551
dddd
Oddometer: 474
I think I may have commented that here earlier, but here it is again:
prussik only works well when their own rope diameter is 25% or more smaller than the main rope. So, the aramid/spectra ropes are awesome for strengt/weight ratio, but they are not easy to grab, they don't make good prussik either, and its next to impossible to find a smaller rope that will hold the main rope spec load. In that case, a mechanical ascender (if it fits) is probably the right device.
A regular static 5mm rope does a decent prussik rope, and since it is doubled, it can _almost_ hold their spec (knots cut the max load in less than half; 2x 1/2= 1). So you can have a 7mm main static rope (which can support half its spec too). Unfortunately, if you buy 100 feet, that isn't compact anymore...
could learn to be jedi and use your mind...
dddd is offline   Reply With Quote
Old 05-17-2013, 02:48 PM   #1552
dddd
Oddometer: 474
Here too, I would simply tie the trunk to the standing tree and pull the middle perpendicularly (then tighten and pull again, and so on, with other trees further away if needed)
Old 05-17-2013, 06:36 PM   #1553
mpatch
Oddometer: 972
Or just lift the bikes over the log and be done with it or buy a real bike and ride over the log.
mpatch is offline   Reply With Quote
Old 05-17-2013, 06:43 PM   #1554
dddd
Oddometer: 474
unfortunately, this is not a tool for this toolkit thread.
Old 05-17-2013, 07:13 PM   #1555
mpatch
Oddometer: 972
Everybody should know how to tie a dozen or so basic knots: termination, directional, friction, midline etc. One of life's skills just like starting a fire, simple first aid, changing a tire, driving a manual, riding a motorcycle, knowing cardinal directions by the stars, etc......
Old 05-18-2013, 08:52 AM   #1556
Rave
Rave's Avatar
Oddometer: 31
Thanks DiscoDino. That's definitely a good pointer, and I'll definitely keep that mind next time I break this out of the toolkit. In retrospect, it looks so obvious. We were in somewhat of a rush, so we just threw up the rigging real quick and moved it as quick as we could.
Rave is offline   Reply With Quote
Old 05-18-2013, 09:51 AM   #1557
LoneStar
WhoopDeDoofus
LoneStar's Avatar
Oddometer: 1,205
Originally Posted by beechum1 View Post
I just bought one of these tonight. Going to test it out before I pack it. Hopefully it will work though. I'd really like to save a few oz rather than quick drinking beer!!
Hey Beechum did you ever get one of these and if so what do you think of it?
LoneStar is offline   Reply With Quote
Old 05-18-2013, 05:48 PM   #1558
woodmnctry
woodmnctry's Avatar
Oddometer: 185
Where to find this beast??
woodmnctry is offline   Reply With Quote
Old 05-18-2013, 06:06 PM   #1559
RidingDonkeys
Purveyor of Awesome
Oddometer: 8,585
Everything you need to know is here.
Old 05-18-2013, 10:04 PM   #1560
LoneStar
WhoopDeDoofus
LoneStar's Avatar
Oddometer: 1,205
Thx RD
Motorcycle Superstore carries them for $35 - Baron 18-n-1 UltraWrench
Times are GMT -7.   It's 01:19 AM.
