Old 01-11-2010, 04:32 PM   #691
Rotten Ronnie
Crash
Rotten Ronnie's Avatar
Oddometer: 354
Originally Posted by HaChayalBoded
...just remember to dump the hex bits and replace them with metric as the ones in the kit are SAE.
I just did that this afternoon, but I spent good money on an 8mm hex bit when I discovered that the 5/16" bit IS 8mm.
Bikes I haven't managed to destroy yet:
2009 Kawasaki Versys 650
Ride Reports and other drivel:
http://rottenxxxronnie.blogspot.com/
Rotten Ronnie is offline   Reply With Quote
Old 01-11-2010, 04:36 PM   #692
HaChayalBoded
Brooklyn Bored
HaChayalBoded's Avatar
Oddometer: 7,910
lol, you didn't have to throw em out ya know. Just remove them from the box.
HaChayalBoded is offline   Reply With Quote
Old 01-11-2010, 04:46 PM   #693
tomatocity
Retired and lovin' it
tomatocity's Avatar
Oddometer: 804
9/16" = 14mm
Tim
2012 Yamaha Super Tenere #027, 2005 KLR, 1993 Chevrolet S10,
tomatocity is offline   Reply With Quote
Old 01-11-2010, 04:59 PM   #694
Rotten Ronnie
Crash
Oddometer: 354
Originally Posted by tomatocity
9/16" = 14mm
Damn those revolutionary French and their "Age of Reason and Enlightenment"! I thought Wellington clobbered 'em at Waterloo? :(
Old 01-11-2010, 05:07 PM   #695
HaChayalBoded
Brooklyn Bored
Oddometer: 7,910
9/16" = 14mm
9/16th is 14.288mm.
Sure, you might be able to use it on whatever bolt you happened to try it on, but you might also end up completely stripping an important bolt, and since most brake calipers use 14mm bolts, I would not try to use a 9/16th on it.
There are really only 2 SAE sizes that are close enough to their metric counterparts to work without worrying about stripping said bolt.
5/16= 7.938mm so unless you're using aerospace engineered sockets and bolts, they can be used.
next would be 7/16th=11.113mm but how many 11mm bolts do you use? I have a bunch, only because the metric bolt kits I buy have many 11mm socket heads.
last would be a 1 1\16th inch socket (26.9875mm) in place of your 27mm axle nut.
Here is a good conversion table.
http://www.hamuniverse.com/antfrac.html
Old 01-11-2010, 05:29 PM   #696
tomatocity
tomatocity's Avatar
Oddometer: 804
9/16th is 14.288mm.
I have been mixing mm and inch wrenches and sockets for the last 30+ years and haven't had too many disasters (actually can't remember one).
What is the inch socket for the rotor removal tool? Better to use an inch impact socket instead of a mm standard socket. I definitely use the inch impact sockets on the axles (while in the garage).
Thanks for the conversion chart. Copy, Print, Carry.
Tim
Old 01-11-2010, 06:25 PM   #697
HaChayalBoded
Brooklyn Bored
Oddometer: 7,910
Maybe you were just lucky, I've had to dremel flat grooves in many a bolt in order to use a thick flathead to remove rounded off bolt and allen heads.
Old 01-11-2010, 07:11 PM   #698
motosaint
LTLYLTL!
motosaint's Avatar
Oddometer: 566
Neat little kit.
Nice selection of tools. I've been finding that too many kits have too many bits and I don't like having bits around I will probably never use. This kit will be a good 30% lighter for my requirements.
I'm getting one those tool wraps we've seen here and add the pieces I need.
I really love my rachet screwdriver and I like it when you can put all the bits you need inside the handle. And really, I only use 4 or 5.
I got that Motion Pro tire-iron that doubles as a rachet wrench. Way cool.
That kit has been mentioned already, just remember to dump the hex bits and replace them with metric as the ones in the kit are SAE. The nice thing about that kit is that they have star bits up to 55, perfect for BMWs, in case anyone was wondering, the metric sockets in the kit are 8, 10, 12, 13 and 14mm, the other 5 sockets are SAE, great when pulling over for that rider on the side of the road only to find out its a harley with a bunch of loose nuts and bolts.
My Blog: www.motosaint.com
Twitter: @MotoSaint
My Adventures
Trip through the American Northwest - Maybe - 2010
San Francisco to San Diego Quickly - 2010
My First Big Mexican Ride - 2009
Northern California for 4 Days - 2008
Current Ride
Suzuki 2002 - DR650 (Anna)
MSF BRC Graduate '07
motosaint is offline   Reply With Quote
Old 01-11-2010, 07:27 PM   #699
ravenranger
rave
ravenranger's Avatar
Oddometer: 1,532
The tool roll from Duluth Trading Company is a really nice way to carry your tools. They run about $25 but are definitely worth it. I use one of these on my ST1300.
Welding tubes are also useful for carrying tools on the dirtbike - they're waterproof and, due to limited space, makes you narrow things down to what you actually use.
1989 NX250
2006 ST1300A
2006 Aprilia Caponord
ravenranger is offline   Reply With Quote
Old 01-11-2010, 07:49 PM   #700
WeeBee
Roaming ADV Gnome
WeeBee's Avatar
Oddometer: 1,539
I really like my Custom Leathercraft #1173 Tool Roll - it's made out of heavy Cordura nylon and I only paid $14 for it
Edit - just found it here for only $10
Formerly NorCalTA
WeeBee screwed with this post 01-11-2010 at 07:54 PM
WeeBee is offline   Reply With Quote
Old 01-11-2010, 08:08 PM   #701
ravenranger
rave
Oddometer: 1,532
The Custom Leather Craft roll is nice. That's what I had until I wore it out and then I got the Duluth one - don't think I'll ever wear it out.
1989 NX250
2006 ST1300A
Old 01-11-2010, 08:31 PM   #702
WeeBee
Roaming ADV Gnome
WeeBee's Avatar
Oddometer: 1,539
WTF did you do to wear it out - use it for a bash plate?
Formerly NorCalTA
Old 01-11-2010, 09:06 PM   #703
ravenranger
rave
Oddometer: 1,532
I was carrying it around in the back of my Scout and managed to rub a good sized hole in it.....
1989 NX250
2006 ST1300A
Old 01-11-2010, 11:51 PM   #704
motosaint
LTLYLTL!
motosaint's Avatar
Oddometer: 566
No where for sockets...
Most other rolls have a socket area.. It must be a necessity in my book...
Twitter: @MotoSaint
My Adventures
Current Ride
Old 01-12-2010, 07:54 AM   #705
DR. Rock
Part of the problem
DR. Rock's Avatar
Oddometer: 5,528
Oh my GOD!
I used an impact wrench for the first time yesterday and it totally blew me away. I must say I am smitten. . It pulled the clutch basket nut off in about 2 seconds as if it was only hand tightened but it was actually at some 200 ft. lbs, or kilo cubits or something like that. If you have never experienced the sublime joy of an impact wrench do NOT pass up an opportunity. It was a religious experience. I know you're probably thinking this is off-topic, but I'm brainstorming a way to carry it with my on-bike kit. Seriously.
"I came into this game for the action, the excitement; go anywhere, travel light... get in, get out... wherever there's trouble, a man alone... Now they got the whole country sectioned off; you can't make a move without a form." --Robert De Niro as Archibald 'Harry' Tuttle in Brazil, 1985. The Mobius Trip index | Spot tracking live 4/18-5/4/13 | AdventureLoft™ Tent Space
Times are GMT -7.   It's 04:31 AM.
