Old 09-08-2011, 04:43 AM   #1171
Subutai
Oddometer: 555
Originally Posted by team ftb View Post
I loooked at one of those once and they are quite intricate and decently made. However they look an absolute pain in the arse to use in the real world so I never bought one. If anyone has some actual experience using them for more than adjusting the mirrors I'd love to hear how practicsl they are in usage.
I have the metric one and have used it plenty. Fear not, it will pull it's weight. I've also all the add-on tips for it and they all fit in the pouch. Beautiful piece of equipment, handy around everywhere where you have phillips, flathead, torx screws or small bolts. Has a bottle cap opener also and the material is very strong, if you chip or scratch it you're doing something wrong.
Subutai is offline   Reply With Quote
Old 09-08-2011, 07:29 AM   #1172
RichardU
Let's Ride
Oddometer: 903
Originally Posted by soul_adventurer View Post
im wondering whats the best way or the 'knack' to folding up spare tubes. ive tried heaps of ways but i still get a pretty bulky package. i wrap them in a plastic bag then duct tape the whole thing. any suggestions would be grateful.
Remove the valve core. "Fold" the tube once so the valve is at the top. Start rolling up from the bottom and squeeze out all the air. Reinsert the valve core. Fold any way you want -- it won't get any smaller.
RichardU is offline   Reply With Quote
Old 09-08-2011, 07:55 AM   #1173
team ftb
Befuddled Adventurer
Oddometer: 1,775
Thanks for the feedback Autodialect. I'll give one a go and see if it works for me then.
Cheers,
Team FTB
Team "Fingering The Bean"
team ftb is offline   Reply With Quote
Old 09-08-2011, 07:59 AM   #1174
team ftb
Oddometer: 1,775
Originally Posted by scott_01_xr400 View Post
By the way, I have an extra one that is brand new if anyone is interested. They are like $60 new. I would sell it for $38 shipped to you (48 state US).
Scott i just heard a friend is coming over to Thailand from the states to visit me in two weeks and can bring your extra MP tool for me. I'm gonna give you a PM to buy your tool. Can you confirm that it is the metric version? I'll be curious to see whether I will adopt it or not as it will save some space if I end up adopting it. Thanks.
Cheers,
Team FTB
Old 09-08-2011, 04:45 PM   #1175
tmotten
Lefthand ride Dutchy
tmotten's Avatar
Oddometer: 2,501
I've got both the motion pro t-handle and the metric tool. Bought the metric tool but they send me the t-handle and told me to keep it while they sent the correct tool. Good service.
Been working it out last night and reckon I'm better off with my old setup of a 10mm gear wrench and an adapter like this.
You can get them like this as well.
You only need 1 drive, and the rest sockets and wrenches. I do like the double sided allan keys though because they're not as easy to loose and easy to carry in the pouch. You'll need a deep 8mm socket to drive those, or a spanner. Job done.
tmotten is offline   Reply With Quote
Old 09-08-2011, 05:30 PM   #1176
GSJon
GSJon's Avatar
Oddometer: 1,688
Where can one find these?
Jon
ADVMax: BMW's do not break down - they fail to proceed.
GSJon is offline   Reply With Quote
Old 09-08-2011, 08:17 PM   #1177
tmotten
tmotten's Avatar
Oddometer: 2,501
I just googled 10mm wrench to socket adapter for the top ones. I've got a set of it and maybe even from RS components who hosts that image. The second one is from gearwrench. I personally prefer the top (I have both) because I just leave it on my 10mm hinged gear wrench with a wobble extender to keep it in place and keep it in my camelbak. It slides off the wrench otherwise. Both do, although it has an o-ring to help that, but the smaller the better for me.
Old 09-08-2011, 09:31 PM   #1178
HaChayalBoded
Brooklyn Bored
HaChayalBoded's Avatar
Oddometer: 7,928
I've got a couple of those, I keep it on a second 10mm wrench I carry. I found I often need a second 10mm and sometimes need a second 1\4" drive. This gives me that. Usually you only need a second 1\4" drive to hold something still to remove or tighten from the other side.
They work great. I have th eone with the knurled outer lip, it's made by gear wrench, bought a whole kit just for that and a 10mm to 1\4" hex converter like in the first pic.
That converter on a 10mm deep socket wrapped in hockey tape is my screwdriver.
HaChayalBoded is offline   Reply With Quote
Old 09-09-2011, 12:08 AM   #1179
tmotten
tmotten's Avatar
Oddometer: 2,501
True. Only I find that a good pair of pliers like the knipex cobra which now come in a real stubby version can do that. When you really begin tightening it you don't need a lot of torque on the other end so a pair of pliers don't really do any damage. Friction does most of the work.
Old 09-12-2011, 09:11 AM   #1180
team ftb
Oddometer: 1,775
Motion Pro spark plug tool
Wondering if I'm not seeing something. I purchased the Motion Pro spark plug tool
http://www.motionpro.com/motorcycle/partno/08-0239/
to outfit my toolkit. I purchased this combo as I wanted the 3 inch 3/8 wobble extention that comes in the package to combine with my six inch 3/8 extension to reach some deep tank bolts on my large tanked YZF. The extention and plug socket fit fine and also work around my KTM frame stellar. However, the female end of the 3" extention is 1/4" and the male end is 3/8" that goes into the plug socket 3/8". Why would they have differing shaft sizes cast in? For example, I mean if i've got a 3/8 drive unit I want it to work with all my 3/8" kit, If I'm using a 1/4" drive unit I want it to work with all 1/4" stuff. Why the combinmation of needed shaft sizes on one piece of kit that would disallow this? I cannot use this extention with my 3/8 stuff due to it having the 1/4 female end in it instead of 3/8. Luckily I can use a phillips screwdriver to remove the plug but I would prefer it better if it would work with my 3/8 driver as well. if I was using a 1/4" driver it would work in the extention but then the 3/8" male end on the extention would not work with any of my 1/4" drive sockets. What is the logic of doing this? Am I just not seeing or understanding something?
Cheers,
Team FTB
Old 09-12-2011, 09:29 AM   #1181
DirtDabber
cultural illiterate
DirtDabber's Avatar
Oddometer: 8,359
A 1/4" drive rachet is lighter to carry in a tool kit. The extension allows you three options of driver allowing you to use a wrench if you need a lot of torque and a small 1/4" rachet for speed. I think this will be one of my next tools just for that feature.
I wonder where that road goes?
DirtDabber is offline   Reply With Quote
Old 09-12-2011, 10:39 PM   #1182
team ftb
Oddometer: 1,775
Dirtdabber I understand that I can use a 1/4 inch driver which is nice and light and its also nice to have the screwdriver and 14mm wrench option to drive the extention. The issue I see is if I bring a 1/4 driver and related 1/4" sockets, i then cannot use the Motion Pro 3" extension with 1/4" sockets since it has a 3/8" male end instead of 1/4". Why would the extention not be 1/4" on both the male and female ends to allow the extention the ability to work with 1/4" sockets? In my eyes both male and female ends of the extention should be the same size to facillitate uniformity in the tool kit. Whats is the advantage of having the female end of the extention 1/4" and the male end 3/8"? Anybody?
Cheers,
Team FTB
team ftb screwed with this post 09-13-2011 at 04:30 AM
Old 09-13-2011, 04:42 AM   #1183
DirtDabber
cultural illiterate
DirtDabber's Avatar
Oddometer: 8,359
The 3/8" side is notched to allow for the socket to wobble. You could not do that if it was 1/4 because there would not be enough metal and it would break. The 1/4" side is designed to take a wrench to break nuts free if needed and then use a weaker and shorter 1/4" drive to finish. If that side was 3/8" then the "nut" part would be huge and then clearance could become an issue and it may not fit any wrench in a standard tool kit.
Bottom line is that it is designed as a compromise tool that does several things and when you do that you lose function somewhere. Here that lost function is a 1/4" drive extension. Just look at it as a long 1/4 to 3/8 adapter.
Old 09-13-2011, 04:43 AM   #1184
Motoriley
Even my posing is virtual
Motoriley's Avatar
Oddometer: 2,686
Extension
Get a 3/8" to 1/4" adapter, 3 $, problem solved. Then for some larger sizes you can 3/8" use sockets as well.
04 Toyota Sienna, new wipers for 2011!!
Electricity (120 AC), Indoor Plumbing, new kitchen tap for 2010!!!
Color tube TV, Microwave Oven (yes she rotates!),Washer & Dryer,Paved Driveway,
Website - http://www.apormc.com/
Vids - http://www.youtube.com/user/Motoriley?feature=mhum
Motoriley screwed with this post 09-13-2011 at 04:44 AM Reason: I canut spiel.
Motoriley is offline   Reply With Quote
Old 09-13-2011, 07:21 AM   #1185
Sheep Shagger
Show me your fleece
Sheep Shagger's Avatar
Oddometer: 2,179
All sparkplug sockets are 3/8", so this allows you to use any sparkplug socket. You could just get a 3/8 to 1/4 adapter if you want to use it as a 1/4 extension.
Sheep Shagger is offline   Reply With Quote
Times are GMT -7.   It's 05:31 AM.
