Old 02-12-2012, 02:37 PM   #1306
Rabbot
rain+superbike=adventure
Rabbot's Avatar
Oddometer: 561
one addition
Originally Posted by travelprof View Post
Here is my ever evolving tool kit for my KLR650s.
1. Motion Pro T-6 Chain Tool + T6 Trail Bead
2. Motion Pro Tool Metric + 16 mm and 14 mm sockets
3. Stop & Go portable mini-air compressor + tube repair kit
4. Air pressure gauge 60 psi max (Accu-Gage RA60X)
5. Motion Pro Ball End Allen Set 9PC (1.5, 2, 2.5, 3, 4, 5, 6, 8 & 10 mm)
6. Husky Pro 3/8″ Drive Pearhead Ratchet Model 22800 + 3/8 to 1/4 adapter
7. Motion Pro T6 Combo Lever (27 mm) + 3/8 inch to 1/4 inch adapter
8. Motion Pro T6 Combo Lever (12mm/13mm)
9. Pittsburgh 7 Piece Metric Ratcheting Combo Wrench Set (17, 15, 14, 13, 12, 10, 8 mm)
10. Craftsman Metric Crowfoot Wrenches (17 mm and 19 mm)
11. Jack made from crutch (velcro strap to engage front break)
12. Phillips and flat short screw drivers
13. Screw driver with set of phillips + flat tips from Chapman 7500 tool kit.
14. 3/8 drive metric deep sockets (13, 12, 10, 8 mm)
15. Husky 8-Piece Bit Ratchet Set
16. JB KWIX (fast curing version of JB WELD) Each inside a plastic tube. Popsicle sticks for mixing
17. Black electrical tape wrapped around the tube that holds the orange JB KWIX
18. Blue duct tape wrapped around the tube that holds the blue JB KWIX
19. Red (271) and blue (242) Loctite (thread locker)
20. Zip ties of several sizes
21. Craftsman 7 in. Adjustable Pliers (Germany)
22. Craftsman 6 in. Beak Jaw Adjustable Wrench (Extra-wide jaw)
23. Craftsman 6 in. Long Nose Pliers (USA)
24. Leatherman Wave tool
25. Telescopic magnetic pickup tool
This looks like an excellent kit. I might add a pair of vise grips. While racing an enduro about 30 years back I was able to not only get out of the woods but finish the race after I lost the front axel nut. Found the axel. Clamped vice grips on where nut would normally reside, wrapped aircraft wire around the handle of vice grip and fork tube then electrical tape to hold in the closed position and prevent spinning. Worked like a charm. Wish I invented the idea but I had read about it somewhere.
Rabbot is offline   Reply With Quote
Old 02-16-2012, 09:42 AM   #1307
hilslamer OP
2XRedheadedstepchild
hilslamer's Avatar
Oddometer: 1,785
Originally Posted by cat View Post
Maybe we should get you to do a thread on the first-aid kit sometime, if you've done a lot of work on it like you have with the toolkit. :)
So much of what i've seen is more orientated to band-aids for little cuts, not the kind of injuries you might want to attend to in the bike context. Basically, i don't see the type of wound dressings that would be good for bike crash wounds - big enough. I suppose some of the military stuff would be suitable but i haven't seen enough of it to know what to get.
It's been done well before here...
Originally Posted by jesusgatos View Post
Think there are already a few good first-aid threads on here. Remember there was no shortage of info out there when I was putting mine together.
...correct/agree.
I mostly carry basic stuff for small cuts and abrasions, too...and of course all the pharmaceuticals I listed, just for delaying symptoms and getting to a safer place to rest and get treatment. As far as large/bleeding wound dressings and the like, there are some pretty amazing solutions out there but many are large and heavy so I have never carried them on the bike or on my person either.
When I have had to deal with people with broken bones, we've always managed to make a splint out of available stuff on site - branches of trees, plastic fenders cut into strips, sacrificed elbowpad plastic for a broken wrist, etc. I have never been in a situation where I needed to make a stretcher, but carrying some nylon line or strap could make this possible with any sort of trees available, etc.
hilslamer is offline   Reply With Quote
Old 02-19-2012, 09:20 AM   #1308
Kinsman
Ribs....for her pleasure
Kinsman's Avatar
Oddometer: 4,029
I carry both: paracord and nylon webbing.
Great maids-of-all-work: for rigging a tarp, bear-bagging food, making lashings, repairing gear, splints...lots of stuff.
Chris R
Schreckendgust Field, Montana
Kinsman is offline   Reply With Quote
Old 02-27-2012, 02:21 PM   #1309
hilslamer OP
hilslamer's Avatar
Oddometer: 1,785
I have seen these put to use quite nicely:
http://www.survivalstraps.com/
...if I were to ever design a garment, I think I would incorporate something similar. It's actually not hard to do yourself, just tedious...
Old 02-27-2012, 04:07 PM   #1310
jesusgatos
fishing with dynamite
jesusgatos's Avatar
Oddometer: 2,384
Maybe something like this?
Or this?
jesusgatos screwed with this post 02-27-2012 at 04:16 PM
jesusgatos is offline   Reply With Quote
Old 03-04-2012, 02:42 AM   #1311
2upAussie990
Oddometer: 463
lots of good info here guys, thanks
2upAussie990 is offline   Reply With Quote
Old 03-07-2012, 01:52 AM   #1312
STisma
STisma's Avatar
Oddometer: 147
Found these..... seem usefull
If it can go wrong, it will go wrong!!!
STisma is offline   Reply With Quote
Old 03-08-2012, 08:12 PM   #1313
S H I F T Y
S H I F T Y's Avatar
Oddometer: 705
Is there such thing as the 'best' multi tool leatherman style dealio? I rarely need much on the trail, and I am tired of carrying all these heavy combo screwdrivers and full sized wrenches, pliers, etc.
S H I F T Y is offline   Reply With Quote
Old 03-08-2012, 09:07 PM   #1314
RichardU
Let's Ride
Oddometer: 900
Good question. I have five bikes and do not carry full tools on all of them. My minimum took kit is an M-14 Multitool, a Leatherman Crunch, and a tire repair kit which differs between bikes with and without tubes. You might be surprised how much you can do with just that.
RichardU is offline   Reply With Quote
Old 03-09-2012, 08:38 AM   #1315
Sheep Shagger
Show me your fleece
Sheep Shagger's Avatar
Oddometer: 2,132
--edit--
Guess I should keep up with this thread, rather than reading it ever month or so.
The Motion Pro tool discussed in detail in this thread is designed exactly for what you describe. But you should tailor it to your bike, like add the torx / allens / sockets, what ever you bike needs. Personally I don't find the leatherman style tools useful at all for a bike, except for a compact set of pliers, that's all they are really good for.
Sheep Shagger screwed with this post 03-09-2012 at 09:02 AM
Sheep Shagger is offline   Reply With Quote
Old 03-09-2012, 01:23 PM   #1316
JT
JT's Avatar
Oddometer: 344
Wasn't there a four or five page saga a few weeks ago of how this Motion Pro tool failed in the field? The socket driver spun uselessly in the handle.
edit: found it, Team FTB posted this http://www.advrider.com/forums/showp...postcount=1280 and then many followups. Bottom line, the tool is crap.
JT screwed with this post 03-09-2012 at 01:28 PM
JT is offline   Reply With Quote
Old 03-09-2012, 02:37 PM   #1317
Gonzo_Matt
Random Hero
Gonzo_Matt's Avatar
Oddometer: 2,419
Here's my basic kit, still need to add some things, but I don't see a need to way over complicate things. My KLR didn't come with a stock kit.
On the right side, I have the tractor manual tube held on with 2 stainless clamps.
Stashed inside I have:
1) Lineman's pliers: pliers, cutters, and work well as a hammer
2)Small flat screwdriver with magnet on the handle side
3)Needle nose vice grip
4)Combo wrench, fits both front and rear axle
5)1/4" drive ratchet
6)Socket assortment, modified to remove sizes that the bike doesn't have and added a 1/4" to fit driver bits
7)Small needle nose
8)1/4" driver-doubles as extension for ratchet
9)Allen wrench in correct size to fit bars and forks
10)8,10,and 13mm wrenches
11) Big crescent wrench
I'm going to replace the driver and 1/4" ratchet with a 1/4" extension and use the 13mm wrench as a handle as soon as I make a 1/4" to 13mm adapter.
In the lid I have sand paper in 160 and 400 grit rolled around the edges and a cut off sock stuffed in with a selection of hose clamps and cotter pins.
Still need to locate a stamped spark plug socket
I relocated the stock bag from the rear fender to the front fender and in it I carry:
1)Spark plug caddy-one side is a plug, the other holds misc electrical crimp connectors
2)Motion Pro tire levers, not the fancy Ti ones, mainly because I ride a KLR....
3)Spare 21" tube w/core tool
4) Gutted cheapo tire pump. Paid 50 cents for it at a garage sale, works great. I have a 12V cig outlet on the bike, so with 2 alligator clips, the cord becomes a charger to revive other bike's batteries.
I still want to add a small patch kit up here.
I didn't pull it all out, but in the ammo can I have:
1) Cheap rain gear-neoprene face cover
2) Spare lenses for my goggles
3)Harbor freight ratchet strap -tow strap or to hang the bike(or myself depending on the severity of the failure) from a tree
4)14 Ga wire double the length of the bike
5) Mechanics wire
6) zip ties in various sizes
7) Two short jumper wires
Gonzo_Matt is offline   Reply With Quote
Old 03-09-2012, 02:55 PM   #1318
Mercury264
Once you go Triple...
Mercury264's Avatar
Oddometer: 22,142
Totally disagree. If there was a pattern of failure then fair enough but that was the only one that was reported to have failed right ?
'12 Tiger 800XC
'07 TE510
'02 Sprint ST
'99 XR650L
'99 Speed Triple
Old 03-09-2012, 04:06 PM   #1319
'Flagger
..this space for rent..
'Flagger's Avatar
Oddometer: 2,348
+1 the one reported on was crap. not enough evidence to say they all are.
- B
Proud to be an inmate of AdvRider.
'Flagger is offline   Reply With Quote
Old 03-09-2012, 08:21 PM   #1320
team ftb
Befuddled Adventurer
Oddometer: 1,693
I'm the guy with the failed Motion Pro tool.
That tool is wonderful and compact, I never had any issues with the sockets, hex's or screwdrivers using the tool. It was simply the driver for the sockets is multiple pieces and the pieces began to spin instead of funtioning as one single piece. This sucked (and is horrific when you encounter the failing the piece in the field as I did instead of the garage) but I was able to fix it by welding, as detailed in the thread. My unit is now fixed and I worked with it in the garage for another couple weeks to test it out and then began taking it on rides again as its so wonderfully compact and it fits in a convenient pocket in the Camelbak for easy access. I posted in the thread so that people who own the piece can address any issues before taking it into the field.
One failed unit is indeed not enough to condemn the tool as Flagger pointed out, however according to tech at Motion Pro it has been reported to them more than a few times (as feared by Mercury264), and is not unheard of, so in my eyes you are a gambling man if you rely on this tool without addressing the potential issue I described earlier in the thread.
Here's the tool after I modified (welded solid) the driver, working on my drowned 525 on a river bank in Lao, pictured on the righthand rock
and another time in my left hand after removing the right side engine case.
If I owned a MP multi tool I WOULD NOT rely on it without welding the driver pieces together. Once welded, you can then once again enjoy the convenience the tool has to offer.
Edit: Just to clarify I don't think the tool is crap, it's just not trustworthy in my eyes until the potential weakness in the system (driver) is addressed.
Cheers,
Team FTB
Team "Fingering The Bean"
team ftb is offline   Reply With Quote
Times are GMT -7.   It's 12:34 AM.
