Old 12-17-2012, 09:29 PM   #1426
EduardoMas
Spartan Overlander
EduardoMas's Avatar
Oddometer: 407
Fasteners:
Obviously different trips need different spare sets. Donor screws aside, for long travels I stash M6 and M8 (12”) and a little hacksaw blade (use with visegrip) inside a bicycle tube and cable tie it sealed. 12” spans the width of my bike. They travel with the set of longish tire irons. Cut to length, add a nut and washer and voila, an M6 x 107.53 hex head screw, in the bush .
For shorter trips, alen set screws M6x35, M6x50, M8x(I forget), one each with washers, jam nut and flanged nuts attached. This way you have just about any “bolt length” I need.
The added benefit of the rod/set screw approach: If threads in aluminum cases are stripped, jam a set screw to use all threads at the bottom, use red loctite and then tighten with a nut instead of biting into precious little aluminum threads.
When overlanding I carry those little special things like a valve screw and jam nut (XRR), subframe bolts and an M6 tap, often the posse needs something.
Eduardo
XR650R
KTM300
Simplicity is the ultimate sophistication.
EduardoMas is offline   Reply With Quote
Old 12-17-2012, 11:47 PM   #1427
markjenn
Oddometer: 10,425
Originally Posted by jesusgatos View Post
Instead of carrying a clutch cable for any specific bike, I carry a long bicycle cable and by using some quicksteelto create a cable-end...
Like to hear more about this. I've broken a couple clutch cables over the years and have managed to ride the bike clutchless to someplace to get it fixed - no fun in traffic. I try and carry a spare clutch cable now. I don't go so far as I see some though where they carry the spare double-routed alongside the original.
I've heard of using hose clamps to attach the cable to the lever, but how can you make a cable end out of steel putty?
- Mark
Old 12-18-2012, 12:05 AM   #1428
jesusgatos
fishing with dynamite
jesusgatos's Avatar
Oddometer: 2,384
Originally Posted by team ftb View Post
JesusGatos - I'll be needing the bar end handguard bits at least and most likely a Scotts mount.
Cool. Send me a PM to let me know what you need and I'll set those parts aside for you.
Originally Posted by mpatch View Post
One that I had never thought of was some bars leaks.
Handy if you have a leak in the fins or somewhere you can't use epoxy to seal it up. Weighs nothing and takes up hardly any space, especially if you only carry a little bit. I cut down the tube that it comes in (the silver one) and then tape different tubes together to make them easier to carry.
- Mark
I carry a universal brake cable that has a mountain bike end and a road bike end. That way you can just cut off whatever end you don't need, which might change depending on what kind of cable you're trying to replace (clutch, throttle, etc.). Those cables are usually long enough to get two cables out of one length, so if you're on a long trip, cut it to the length you actually need. Anyway, after you cut off the end that you don't need - run it through the housing, then cut it to the finished length and put a small 180-degree bend/kink/knot/whatever in it. Just want to give the quicksteel something to bite. Roll-up a little ball of quicksteel and mold it around the cable to create a new cable-end.That's all. Stupid-simple.
GatosBros · Crux Studio · Trails Less Traveled
jesusgatos is offline   Reply With Quote
Old 12-18-2012, 08:38 AM   #1429
reenmachine
Rain or Shine
Oddometer: 515
Can someone please expound on tubeless tire repair in the field? Is there another thread on this perhaps?
Plug kit, fix-a-flat, what? Hand pump, CO2, ???
In my case, if it matters, this isn't 3rd world outback but more like 50 miles from cell range in the US (for now).
'14 KTM 1190 Adventure
'11 BMW G650GS
'02 Yamaha FZ1
reenmachine is offline   Reply With Quote
Old 12-18-2012, 08:51 AM   #1430
Rotten Ronnie
Crash
Rotten Ronnie's Avatar
Oddometer: 354
I usually pack along a wee air compressor that runs off of my battery
Slime "Tire Top Off" for $15 dollars CDN at Wally Mart
Slime Sticky String repair kit (they work on steel belted tires that will shear mushroom plugs)
Tire Pressure gauge.
That should do punctures just fine for a tubeless tire.
Have a look at the aerostitch gear or the BMW kits if you have the money to spend.
For CO2 you will need about 5 cartridges for a tubeless tire, the hybrid pump/cartridge style would seem to be a good route. For my DR I carry a few CO2 cartridges and a wee bicycle pump along with a spare front tube, patch kit and two 9 inch irons.
You could consider internal patches for the tubeless tire, but that would mean you would need to add a trailside jack, possibly a bead breaker, and the longer 16" tire irons (3 work best). That's assuming that you would want to remove the rim, break the bead, spoon off the tire, repair the tire, wait for the glue to set up on the internal patch, then spoon it back on and inflate. I figure you'd need some sort of lubricant like wd-40, or tried and true soap and water to get it back onto the rim. Swap out the valve stem caps with the aluminum type that have a valve core removal tool built onto it if you plan on going this route.
Google search "Stop n Go" for some put together kits. If you just worry about punctures, you can save a ton of weight and keep your kit down to the minimum for North American touring.
Bikes I haven't managed to destroy yet:
2009 Kawasaki Versys 650
Ride Reports and other drivel:
http://rottenxxxronnie.blogspot.com/
Rotten Ronnie is offline   Reply With Quote
Old 12-18-2012, 11:22 AM   #1431
jon_l
jon_l's Avatar
Oddometer: 3,149
I keep meaning to pack a small (4"-6") hacksaw blade but have not come up with method off carrying it that won't eat into my spares kit.
Duct tape the saw blade to inside of a plastic side-cover or other relatively flat surface.
CBF1000 & PCX150
jon_l is offline   Reply With Quote
Old 12-18-2012, 11:27 AM   #1432
MasterMarine
Oddometer: 1,566
Or you could tape it to one of your tire irons.
MasterMarine is offline   Reply With Quote
Old 12-18-2012, 11:42 AM   #1433
jesusgatos
jesusgatos's Avatar
Oddometer: 2,384
Cut it to whatever length you want to carry and then use it to slit your wrists if you can't find somewhere to put it.
Old 12-18-2012, 10:46 PM   #1434
beechum1
Grimace Soup
beechum1's Avatar
Oddometer: 8,316
Originally Posted by LoneStar View Post
Tommu thx - can't seem to find the heads for it tho - saw this on there as well - anyone used one of these for any length of time?
Says it fits 8-25mm and eliminates the normal slop of an adjustable - about $35.
http://www.baronscustom.com/catalog/...215/index.html
I just bought one of these tonight. Going to test it out before I pack it. Hopefully it will work though. I'd really like to save a few oz rather than quick drinking beer!!
Originally Posted by Boondoggle View Post
Watching Dakar is like watching people who've built their own world, and for just a couple of weeks they get to live in it.
Old 12-18-2012, 11:52 PM   #1435
reenmachine
Rain or Shine
Oddometer: 515
Thanks for the advice! I ordered a Stop-n-go motorcycle tubeless patch kit and a Slime mini compressor from amazon and they'll be here Friday. I already own a small manual hand pump for my mountain bikes and I'll probably throw it in there for good measure.
'11 BMW G650GS
'02 Yamaha FZ1
Old 12-19-2012, 04:31 AM   #1436
team ftb
Befuddled Adventurer
Oddometer: 1,703
Since inside my airbox lid is already occupied with spare levers taping the hacksaw blade to a tire iron wins out. Thanks for shining a light to the obvious.
Cheers,
Team FTB
Team "Fingering The Bean"
team ftb is offline   Reply With Quote
Old 12-19-2012, 07:37 AM   #1437
LoneStar
WhoopDeDoofus
LoneStar's Avatar
Oddometer: 1,206
Anxious to hear your thoughts on it
Tempted to add one to my "collection"
LoneStar is offline   Reply With Quote
Old 12-19-2012, 09:28 AM   #1438
JAB
Unsprung Weight
JAB's Avatar
Oddometer: 1,245
Saw blades
I'm sure it's a matter of preference, but I carry a "Sawzall" type blade rather than a regular hack saw blade. A bit more compact and more stiff. YMMV.
1991 Honda XR628R
1978 Yamaha XT500
JAB is offline   Reply With Quote
Old 12-19-2012, 09:38 AM   #1439
Peirre O`Bollox
Peirre O`Bollox's Avatar
Oddometer: 153
I would suggest using the 45g CO2 cartridges and monster air chuck from genuine innovations http://www.genuineinnovations.com/mo...air-chuck.html as 1 x 45g cartridge should be enough to inflate 1 tyre to a working pressure without having to switch between the smaller 16g carts
I know its an old school technique but ...........Why not use an existing oversize open end spanner from your tool kit, that fits the majority of bolt heads, and a few pennies or washers to pack out the jaws to fit the slightly smaller bolt heads
I accept no responsibility for swearing, drinking, motorcycle riding or your pregnant teenage daughter.
Peirre O`Bollox screwed with this post 12-19-2012 at 09:50 AM
Peirre O`Bollox is offline   Reply With Quote
Old 12-19-2012, 09:46 AM   #1440
beechum1
Grimace Soup
beechum1's Avatar
Oddometer: 8,316
I don't understand. seems like you'd have me set the pennies or washers for each 1/6th or 1/3rd turn of the fastener?
Times are GMT -7.   It's 01:32 AM.
