Old 12-19-2012, 09:56 AM   #1441
Peirre O`Bollox
Peirre O`Bollox's Avatar
Oddometer: 153
The technique only really works on bolts that are readily accessable with an open end spanner, so your only likely to have to set the pennies or washers for each 1/6th or 1/3rd turn of the fastener while initially cracking off the tension, after that its highly likely you`d be able spin the bolt/nut off by hand anyway. it would be easier for you to try it, than for me to explain it
I accept no responsibility for swearing, drinking, motorcycle riding or your pregnant teenage daughter.
Peirre O`Bollox is offline   Reply With Quote
Old 12-19-2012, 09:57 AM   #1442
beechum1
Grimace Soup
beechum1's Avatar
Oddometer: 8,311
ok, I do understand it. Not all of my bolts come off that easily.
Originally Posted by Boondoggle View Post
Watching Dakar is like watching people who've built their own world, and for just a couple of weeks they get to live in it.
beechum1 is online now   Reply With Quote
Old 12-23-2012, 01:40 PM   #1443
divimon2000
divimon2000's Avatar
Oddometer: 619
Electrical tool- DVM
I don't care to carry my full DVM and have seen the simple continuity checker with light is this a good way to go? I guess you can do everything you need to with that as opposed to the simple Voltage checker, yes?
divimon2000 is offline   Reply With Quote
Old 12-23-2012, 03:03 PM   #1444
jesusgatos
fishing with dynamite
jesusgatos's Avatar
Oddometer: 2,381
Originally Posted by team ftb View Post
Since inside my airbox lid is already occupied with spare levers taping the hacksaw blade to a tire iron wins out. Thanks for shining a light to the obvious.
The subframe tubes are another great place to stash things like tire levers and hacksaw blades. Hose-clamps are a little bit more secure than tape or zip-ties, and are re-usable.
Originally Posted by JAB View Post
I'm sure it's a matter of preference, but I carry a "Sawzall" type blade rather than a regular hack saw blade. A bit more compact and more stiff. YMMV.
That's a great idea. Almost certainly a better option than a hacksaw blade.
A fuse tester is pretty small and could be made to serve as a test-light / continuity checker, but something like a little LED light with two short wire leads would be even better. Pretty sure you can buy individual LED's with pre-wired leads, and maybe you could dip it in some kind of clear epoxy/resin to make it a little bit less delicate?
GatosBros · Crux Studio · Trails Less Traveled
jesusgatos screwed with this post 12-23-2012 at 03:13 PM
jesusgatos is offline   Reply With Quote
Old 12-23-2012, 05:54 PM   #1445
old2wheeler
Former nÔÔb
old2wheeler's Avatar
Location: La Veta, CO except for the wind, it'd be heaven
Oddometer: 720
NO.
The continuity check light will only test continuity. You can not use it on a live circuit. You can test a fuse with it, but you must remove the fuse first. With a multimeter set on dc volts (or a 12volt light as described below) if you can access both contacts of the fuse, you put the voltmeter (or light) on each end/side of the fuse with power on; if the meter reads zero volts(or light does not right) the fuse is good (Because you will not read voltage across a simple conductor). If you read 12 volts across the fuse (or the light lights), that is because the fuse has blown and opened the circuit. So having the smallest meter you can find allows more versatility.
You could carry both a battery powered continuity checker as you suggested AND a 12 volt bulb (neon or LED would be best) so that you could do much more than just the continuity checker alone.
Roderick (Rod) {AKA o2w} House
DEFINITION OF A VETERAN
A Veteran - whether active duty, retired, national guard or reserve - is someone who, at one point in their life, wrote a check made payable to "The United States of America", for an amount of "up to and including my life."
old2wheeler is offline   Reply With Quote
Old 12-24-2012, 12:14 AM   #1446
MKJ
Married w/ Children
MKJ's Avatar
Oddometer: 557
Originally Posted by reenmachine View Post
Thanks for the advice! I ordered a Stop-n-go motorcycle tubeless patch kit and a Slime mini compressor from amazon and they'll be here Friday. I already own a small manual hand pump for my mountain bikes and I'll probably throw it in there for good measure.
Tire plugs. You need 6 ply tires for them to work. Bridgestone ED77 (front) and ED78 (rear) work well. This is proven, not theory.
MKJ is offline   Reply With Quote
Old 12-24-2012, 01:26 AM   #1447
markjenn
Oddometer: 10,419
In my experience, the key thing you tend to be doing with roadside electrical repairs is checking for voltage, not continuity. In my toolbox at home, I have both a continuity checker probe with a battery and light and I also have a probe with a long ground lead and a light for checking battery voltage in various places, but I almost never use them. I just haul out my multimeter.
Speaking of multimeters, my old Radio Shack one died. It was perfect for a toolkit as it was self-contained and small. (I did hate screwing with the three watch batteries which it tended to eat all too often):
Radio Shack has discontinued selling it or anything similar. I did a little research and ended up getting a bigger Extech MN35 for the shop for about $20 which a like a lot, but it is little too big for a bike toolkit:
If anybody has any suggestions for a tiny toolkit multimeter, I'm all ears. HF has a $5 one but it is probably pretty fragile, although at this price it can almost be considered a consumable. I'd like something that you can close up and and be self-contained with no exposed display/leads, etc.
- Mark
Old 12-24-2012, 06:35 AM   #1448
RidingDonkeys
Purveyor of Awesome
RidingDonkeys's Avatar
Oddometer: 8,585
Originally Posted by RidingDonkeys View Post
I haven't used the 1/4 adapter. I'll play with it today and report back.
I played with the Husky set and the 1/4" adapter over the past few days. I did some minor maintenance on the bikes, and then used them for some odds and ends around the house. I bought this set with a tool kit in mind, but it never has really made it there. The adapter is OK for socket use. It is mediocre, and gets small jobs done. The adapter falls out while changing sockets, but that is a minor inconvenience. For small things, it works.
I pack tools for two hacks. A Bonnie hack and a Ural. The Ural toolkit will handle everything as stock, but I ultimately want one kit for both bikes. The Husky won't make the grade. I have a small ratcheting screwdriver kit from Northern. The ring around it holds 6 bits. I kept 2 Phillips bits, one standard, and 3 allen bits common to both bikes. I have one adjustable crescent wrench, and a set of Kobalt spline sockets. That accomplishes all the major work a hack requires on the road, and all the little crap that may come up too. This configuration will stay, and the Husky set will hang out on the work bench for light duty.
Sent from the voices in my head and transcribed by their drinking buddy...
Sit Stay Ride: The Story of America's Sidecar Dogs
More info at www.sidecardogs.com
Clinging to sanity, one motorcycle at a time.
RidingDonkeys is offline   Reply With Quote
Old 12-24-2012, 07:22 AM   #1449
Stan_R80/7
Beastly Gnarly
Stan_R80/7's Avatar
Oddometer: 1,374
- Mark
These are still being made. They are sold on Ebay direct from China. Ebay's feedback message system helps when a defective unit arrives. YMMV.
Stan_R80/7 is offline   Reply With Quote
Old 12-24-2012, 07:55 AM   #1450
divimon2000
Oddometer: 619
Ahh, thanks guys, I get the useage of the two, but now I see there is more need to check for voltage than a specific wire. I'll get the light as well or LED.
Old 12-24-2012, 08:50 AM   #1451
tommu56
tommu56's Avatar
Oddometer: 1,357
voltmeter
Some thing like this with an disconnectable positive lead and an extension wire to were you need to test .
Yes you don't have a regular VOM
It serves double duty .
http://www.bikemeters.com/cgi-bin/we...nfig=ent-datel
led pen
http://www.hopkinstowingsolutions.co...o_12_volt.html
http://shop.advanceautoparts.com/web...ntent=10711125
a led pencil type
picture was copy righted click link
even a trailer tester with wires with bullet connectors on it
tommu56 is offline   Reply With Quote
Old 12-24-2012, 12:34 PM   #1452
markjenn
Oddometer: 10,419
Thanks, see something similar to the old Radio Shack one, but more clunky.
I'm going to take a fllyer on one of these for a toolkit multimeter. $9.50 shipped (from China) on Ebay:
I like that it uses AAA batteries rather than watch batteries. That was my biggest gripe with the RS one.
- Mark
Old 12-24-2012, 12:41 PM   #1453
markjenn
Oddometer: 10,419
That's clever, gotta get me this gizmo.
- Mark
Old 01-08-2013, 05:42 PM   #1454
markjenn
Oddometer: 10,419
- Mark
As followup, I just got mine and while it is definitely a cheap/POS DMM, it works fairly well, is relatively small, and is very nicely protected with the cover on. So a good candidate for a bike toolkit DMM.
One gotcha. It ships with some cheap chinese AAA batteries which have a slightly shorter body and longer terminals, probably because this makes them $0.0001 cheaper to make since this reduces the size of the battery very slightly. As I usually do, I replaced them immediately with higher-quality batteries (Duracell) and the DMM wouldn't turn on. I finally traced it down to this slight variance in battery dimensions causing one of the batteries not to be able to spring-load up against a contact. A blob of solder on the contact to make it sit slightly more proud solved the problem.
- Mark
Old 01-08-2013, 09:46 PM   #1455
LoneStar
WhoopDeDoofus
LoneStar's Avatar
Oddometer: 1,205
Thanks for the heads up Mark - I just received mine today and made sure it worked but haven't swapped batteries yet.
Also have the previously discussed Radio Shack version but prefer AAA batteries so will see how this one does
LoneStar is offline   Reply With Quote
Times are GMT -7.   It's 04:46 PM.
