08-22-2011, 05:29 PM
#1531 | |
Oddometer: 2,070
If someone is willing to take the time and patience, there are some serious gains to be made for jetting the bike properly with the snorkel removed from the top of the airbox. I tried it once, and there was definitely more grunt at the top end. But there was a HUGE lean spot at low/mid RPM that basically made the bike almost unrideable. Not impossible to sort out, but I'm not sure even where to start with that.
"Give big space to the festive dog that makes sport in roadway. Avoid entanglement of dog with wheel spokes." |
08-22-2011, 08:30 PM
#1532 |
Oddometer: 718
thanks
I pulled the pin, took some work, and I replaced the float valve. I also replaaced the counter sprocket seals and I swoitch out the petcock with the Yamaha one. No more leaks
I hope anyways
08-24-2011, 03:10 PM
#1533 |
Oddometer: 20
Dr Jeckle Carb Mods
Do the carb mods increase or decrease the fuel consumption?
Mine now consumes about 4.1lt/100km, is that too much? |
08-25-2011, 03:53 AM
#1534 |
Southern Ontario
Oddometer: 1,982
Wifey's Sherpa is in the shop, so I can't sneak out and check myself. I want to order her a RAM ball that mounts by replacing one of the top clamp bolts. Product is here:
http://www.gpscity.ca/ram-mount-moto...am-b-367u.html ![]() Would someone please confirm whether the Sherpa uses 8mm bolts? Thank you in advance. |
08-25-2011, 04:58 AM
#1535 | |
Oddometer: 20
08-25-2011, 10:22 PM
#1536 |
Oddometer: 166
08-26-2011, 06:33 AM
#1537 |
El cheapo
Oddometer: 4,873
Seems to me common sense that increase jet size = increase fuel consumption..
08-26-2011, 07:29 AM
#1538 | |
Oddometer: 2,070
So it's more complicated than just bigger = more fuel consumption.
08-26-2011, 09:28 AM
#1539 | |
El cheapo
Oddometer: 4,873
Never in my experience that running the same engine with richer fuel intake by increasing jet size would consume less fuel. |
08-26-2011, 11:19 AM
#1540 |
Oddometer: 20
![]() ![]() Its a nice debate , Anyone else with consumption facts from Dr Jeckle΄s carb mods?? How about a FCR???lol , Seriously has anyone tried that?? if it actually does consume more , it will be a shame , because basically Im lookin to decrease the cosumption that the short Thibetian guy has, 4ltrs/100kms is not that low isnt it, ?? I think our bike is a litle hungry on fuel! Ps I'll go with Mr Tomatoe, I've seen a similar situation on a FCR'ed DRZ 400SM that was consuming a litle less fuel than before ,thats with reasonable throtle opening offcourse. pantheman screwed with this post 08-26-2011 at 11:29 AM |
08-26-2011, 11:59 AM
#1541 |
Oddometer: 2,070
If the DrJeckle mod makes it consume more gas, I never noticed. I got about 60-70 MPG before and after the mod. My riding style and what I was riding (back roads, dirt, single track, etc.) had a lot more of an effect on the mileage.
Someone on the Super Sherpa yahoo group put the flat-slide carb from an XR250R in a Sherpa. Join the group and take a look in the message archive, and you'll find the info.
08-26-2011, 05:32 PM
#1542 | |
Oddometer: 2,025
There is a mixture which is most efficient; a reduction in jet size that gives a leaner mixture will also result in increased fuel consumption. The mixture that gives most power is slightly richer than the most economical mixture, so the job of a well set up carby (or fuel injection) is to provide the most efficient (and therefore economical) mixture at all throttle settings except full throttle, when it should be slightly richer for maximum power. Of course emissions considerations further complicate matters, and it is possible the standard Sherpa carby settings are leaner than ideal for economy in order to minimise emissions. |
08-26-2011, 05:35 PM
#1543 |
El cheapo
Oddometer: 4,873
We're not talking about efficiency nor economy, just fuel consumption.
08-26-2011, 06:09 PM
#1544 |
Oddometer: 149
I expected my economy to go down after the jetting, but after 2000 miles with the rejet, I don't think anything has changed. First 6-7 tanks netted an average of about 72mpg with a best of 81ish. When I fill up I always check my MPG on my phone and I typically get between 71-75 for normal commuting duties with the re-jet. Today I got 65mpg, but I have been bad this week using more throttle than needed (long work week, I take it out on traffic).
2002 KLR650 2000 Super Sherpa Traded ![]() 1973 Yamaha 175 - - - For Sale |
08-27-2011, 03:52 AM
#1545 |
Oddometer: 20
My filter oil cap ,bleeds oil , what do I have put there??? Is it a part I can find only from Kawasaki or I can just go and buy a Viton O-ring and seal it???
