Old 06-27-2012, 03:13 PM   #2086
DualSPRTfan
DualSPRTfan's Avatar
Oddometer: 105
Pissed ok.... now what?
So I gave the Sherp some new blood and performed an oil change, everything went silky smooth...... until I started up the bike.
The bike was not indicating it was in Neutral...??? Ok, so I fiddled with the gears, up down, down up, and nothing I could do, would get the bike into N.
Well I walked it down the drive way fine, so it WAS in Neutral. So WTF? Fiddle some more, nothing. Finally I find Neutral, yup bikes in Neutral, but it's still not indicating on the big green N on the dash.
I drove it around the block once it warmed up, it seems to be shifting fine, clutch is working fine, goes through the gears no problem. But it's got an issue with Neutral.
So what gives, did I do something wrong? Is this common? Is there an easy fix?
Any help would be appreciated.
"Try Again. Fail Again. Fail better " Samuel Beckett Irish writer/poet
DualSPRTfan is offline   Reply With Quote
Old 06-27-2012, 03:48 PM   #2087
Rey & Vann
Vagabundo
Rey & Vann's Avatar
Oddometer: 184
There is a wire connected to a little sensor, usually near the countersprocket that signals neutral. Still connected? If it is, check the lamp continuity of the indicator lamp. Simple stuff first....
Sent from my PC36100 using Tapatalk 2
Rey.
Matador. Guerrero, Casador y Pescador.
GPNF Overnight on a Sherpa
Rey & Vann is offline   Reply With Quote
Old 06-28-2012, 07:12 AM   #2088
DualSPRTfan
Oddometer: 105
Thanks for the reply, I found the wire while going in for a closer inspection, and it was on, but not connected all the way. That was it. I must have knocked it loose when I removed the plate at the bottom when changing the oil.
Trial by error, live and learn.
Old 06-28-2012, 03:37 PM   #2089
BigCanoe
Oddometer: 703
Pissed
Is 2100 a fair price for a 2002 with 14k miles?
2007 Yamaha TW200
BigCanoe is offline   Reply With Quote
Old 06-28-2012, 04:37 PM   #2090
jon_l
jon_l's Avatar
Oddometer: 3,142
BC - Sherpas aren't real common, and if taken care of, they're good, reliable machines. If the condition is good, I'd do it. Check the valves right away; Wifey's valves were very tight at ~ 8000 kms (5000 miles).
CBF1000 & PCX150
jon_l is offline   Reply With Quote
Old 06-29-2012, 09:43 AM   #2091
Cat0020
El cheapo
Cat0020's Avatar
Oddometer: 5,525
Here is a 09 Sherpa on eBay... low starting bid w/reserve.. maybe it's a good deal? no relations.
Mankind is doomed & Physics do not lie
Chances favor the prepared mind.
Cat0020 is offline   Reply With Quote
Old 06-29-2012, 08:18 PM   #2092
flyinfuzz
2 Quarts low
flyinfuzz's Avatar
Oddometer: 1,867
I have a 09 local dealer got it from another dealer with 180 miles on it. it seized the head at app 600 miles. The P dealer did the recall the day before he delivered it. So if anyone bids see if & when the recall was done .
Cotton says : This is as screwed up as a rope with 3 ends
flyinfuzz is offline   Reply With Quote
Old 06-30-2012, 10:14 AM   #2093
BGB
Oddometer: 3
I've got my choice for a small "dual sport"-type bike narrowed down to the Super Sherpa or TW200. I'm trying to figure out which would be better for occasional 2-up riding, but haven't seen much specifics. Can anyone comment on how the Sherpa does with someone on the back? Combined riding weight would be well over 300 lbs, is there a GVWR or cargo capacity to watch out for on these bikes?
BGB is offline   Reply With Quote
Old 06-30-2012, 11:00 AM   #2094
flyinfuzz
2 Quarts low
flyinfuzz's Avatar
Oddometer: 1,867
I am pushing 215 w gear plus 15 -20 lbs of extra gas & gear on my Sherpa. Jack up the spring and don't plan on getting in any hurry. Passenger room might be the limiting factor on either bike .
Old 07-01-2012, 06:31 AM   #2095
seasider
Just a rider
seasider's Avatar
Oddometer: 388
Originally Posted by gsstampeder View Post
I googled Super Sherpa high fender and found this
http://www.dual-star.com/index2/Bran...h%20Fender.htm
is that not the colour you were looking for?
Ok......after a week of multiple attempts trying to actually speak with someone at this company and a currently defunct fax they give on their answering machine i have given up on them (Dirt Star).
Any other suggestions for locating the high fender in dark green???
PS. Silver one looks kool but not what the woman wants
Lost time is never found
seasider is offline   Reply With Quote
Old 07-01-2012, 10:33 AM   #2096
NCJ
NCJ's Avatar
Oddometer: 3,249
Weight of rider, passenger, baggage, and accessories must not exceed 364 lb. according to the owners manual.
Looks like you have some leeway there. Curb weight (fueled up, ready to go) is 282 lb.
The Sherpa's an excellent machine.
NCJ is offline   Reply With Quote
Old 07-01-2012, 04:51 PM   #2097
mel brooks
Dirt Chick
mel brooks's Avatar
Oddometer: 1,707
It's just a KLR 250 stock fender.
I think 2000 to about 2003 is the olive green. Check to make sure.
If I remember correctly, it aint cheap.
KLX 351 Super Moto, 292cc Super Sherpa
“Everytime I start thinkin’ the world is all bad, then I start seeing some people out having a good time on motorcycles and it makes me take another look.”
Steve McQueen, On Any Sunday
mel brooks is offline   Reply With Quote
Old 07-02-2012, 02:43 PM   #2098
McJamie
STROMINATOR
McJamie's Avatar
Oddometer: 1,380
So who has made changes/improvements to the seat. Other than lack of fuel range, this seems to be the limiting long-range factor for me.
If you get far enough away, you'll be on your way home.
Piss off, I'm in my Happy place.
McJamie is offline   Reply With Quote
Old 07-02-2012, 06:04 PM   #2099
flyinfuzz
2 Quarts low
flyinfuzz's Avatar
Oddometer: 1,867
Seat concepts is the way to go.
Old 07-03-2012, 12:45 AM   #2100
DualSPRTfan
Oddometer: 105
Eek Point me in the right direction
Alright, I have search here and also the yahoo group, checked out the links and have seen a plethora of parts for the Sherpa.
Now, perhaps I am even more confused as to what I should buy/mod/add to the bike.
Soooooo this is what I am looking at.
Seat - seat concepts or WALMART ATV seat cover? Which one? I guess it depends on price and comfort, and looks. How does the Walmart cover attach?
I need a rear tail light, anyone know of a good place to get one? Also from what I can see, the brake light does not change intensity when the brake is pressed, front or rear. Is there a relay or switch that can be replaced?
Rear rack? Which one do you recommend, also I would like to add a fuel pack or canister of some sorts to extend the range if needed, is there a rack better suited for this?
New Tires, totally confused about this one, I am not sure if I should just go stock with the Bridgestones, or get something else. I plan to do some off road riding and want to be prepared.
Fuel Cap for the gas tank is cracked and need a replacement for that.
Larger foot pegs would be a plus of me, any recommendations for that?
Help with the above would be appreciated, sorry for being such a rookie.
Times are GMT -7.   It's 09:51 PM.
