Old 01-29-2013, 03:51 PM   #2461
ScienceOfDirt
U-Boat Rider
ScienceOfDirt's Avatar
Oddometer: 1,722
Originally Posted by jon_l View Post
Few dual sports come with comfy seats, but my wife's Sherpa seat is much more comfortable than the stock WRR seat, and better than the DR650 I had before it.
I'd hate to make bike buying decisions based on the OEM seat though. An aftermarket seat or an upholstery shop can cure most factory 2x4 seats. The Seat Concepts seat on my WRR cost ~$200 professionally installed.
It's more a width of the seat issue. I should have mentioned that. I've found that no matter who makes the aftermarket seat, none add any width to them. I like the wide KLR seat. I don't like the narrow WR seat.
Friend: That was some trail shortcut. Me: Yep. See how fast we got lost.
ScienceOfDirt is offline   Reply With Quote
Old 01-29-2013, 04:39 PM   #2462
jon_l
jon_l's Avatar
Oddometer: 3,142
Actually, they do. This is DR650:
And an upholstery shop can add / carve foam to get even more width.
CBF1000 & PCX150
jon_l is offline   Reply With Quote
Old 01-29-2013, 08:10 PM   #2463
ScienceOfDirt
U-Boat Rider
Oddometer: 1,722
Interesting. Do they add to the seat pan, or is it just foam. I think I need to talk to seat concepts. Thanks.
Old 01-29-2013, 08:17 PM   #2464
zenduddhist
zenduddhist's Avatar
Oddometer: 153
They just provide the foam and the seat cover. You then replace the foam and cover on your own seat pan. I personally took mine to a upholsterer and had them do it. $30.00 locally. I really like mine. 2nd one I have had. 1st one was on a Suzuki DR-Z 400
1969 Triumph Bonneville T120R
1972 Norton Commando 750
1974 Norton Commando 850
1974 Vespa Rally 200
1975 Norton Commando 850
1980 Vespa P200e
2010 Triumph T-100 w/sidecar
2011 BMW R1200RT
2013 Honda CB1100
2013 Vespa GTV300E
zenduddhist is offline   Reply With Quote
Old 01-30-2013, 09:58 AM   #2465
SkiFly01
Govna Racepipe
SkiFly01's Avatar
Oddometer: 593
So Newcastleadam and I tore into the sherpa last night to start on the clutch pack because it was slipping so bad. Found it was just roasted
Thanks to tomatoe333 for recommending new clutch springs cause these were about 1mm under spec, clutch discs were reading 1.9mm where the spec limit is 2.62mm. New EBC discs and springs will be replacing it along with new jets for the carb to help out. Also, we did correct the chain guide to fit in its proper place holder.
Kai
2008 BMW GSA
2000 Kawasaki Super Sherpa
SkiFly01 is offline   Reply With Quote
Old 01-30-2013, 11:57 AM   #2466
tomatoe333
tomatoe333's Avatar
Oddometer: 2,292
Originally Posted by SkiFly01 View Post
Don't forget to clean the oil pickup screen, bottom center in the picture. Looks pretty clean in there otherwise!
"Keep the standard settings will be useful to learn more about the bike. One should reach a sufficient technical level, when then humbly questioning calibration of your motorcycles."
tomatoe333 is offline   Reply With Quote
Old 01-30-2013, 12:51 PM   #2467
SkiFly01
Govna Racepipe
SkiFly01's Avatar
Oddometer: 593
Yep, we shot it up with some brake parts cleaner, very nice copper color now without spots.
Kai
2008 BMW GSA
Old 01-30-2013, 09:24 PM   #2468
newcastleadam
Artful Tagger
newcastleadam's Avatar
Oddometer: 3,455
New clutch bits installed and rejetted the carb. The header no longer glows, so that's good. Also go the KLR250 finished up, looking forward to the weekend!
Adam
86 KLR250 01 KLR685 06 K1200LT
As ever, buyer and seller of all things KLR
KLR Doohickey Wrench available!
The North Florida Tag-O-Rama wants YOU!
newcastleadam is offline   Reply With Quote
Old 01-31-2013, 12:56 AM   #2469
Rx4Pain
Rx4Pain's Avatar
Oddometer: 136
Western TAT On A Super Sherpa Video
Guys, I uploaded the slide show/video that me and a buddy put together after our summer adventure last year. Thought I would share it here.
Here's the link. http://youtu.be/cul6v9N4uDo
Enjoy!
Ken
Rx4Pain is offline   Reply With Quote
Old 01-31-2013, 12:59 AM   #2470
Rx4Pain
Rx4Pain's Avatar
Oddometer: 136
SkiFly, did you go with the standard 130/20 jetting setup, or something different? I ask because I still feel that there is a bit missing in throttle response/initial "snap" on my Sherpa. Wondering if you did anything different?
Ken
Old 01-31-2013, 07:07 AM   #2471
SkiFly01
Govna Racepipe
SkiFly01's Avatar
Oddometer: 593
No Rx4Pain, we found that it had the #20 in it already but installed the #130 and found when we ran our replacement tank with no filter it put a bunch of crap in the bowl of the carb, so a second cleaning took place.
Anyways here is what the old vs new clutch springs ended up looking like.
The best though was finding this collection of muck when I went to replace the seals behind the sprocket.
Kai
2008 BMW GSA
Old 01-31-2013, 07:15 AM   #2472
tomatoe333
tomatoe333's Avatar
Oddometer: 2,292
The case guard and sprocket cover from a KLX250 are a bolt-on replacement for the big Sherpa cover. If you're going to do any real muddy riding, I'd recommend changing over. I don't have the Kawasaki P/N's in front of me, but they're easy to find on an online fiche.
Old 01-31-2013, 08:48 AM   #2473
greer
Oddometer: 3,764
Sherpa needle mods
Our Sherpa has less than 100 miles on it, so maybe it's too soon to know, but it sure feels dead thru the low to mid range revs. I've read vague references to shimming the needle but no specific details. Can you all point me to more reading on that? Last night we swapped the jets and noticed an easier start and warm-up right off. No chance to ride it yet, though. Thanks
Sarah
'08 DR650
greer is offline   Reply With Quote
Old 01-31-2013, 12:43 PM   #2474
tomatoe333
tomatoe333's Avatar
Oddometer: 2,292
Did you drill out the cover over the mixture screw and set it to 2-3/4 turns out?
If not, do that before you mess w/ the needle. I would shim the needle on mine w/ an appropriately sized washer when the weather was cold (<40 degrees), but I never thought the bike needed it when it was warmer.
Old 01-31-2013, 01:00 PM   #2475
greer
Oddometer: 3,764
Yes, we did.
Sarah
'08 DR650
Times are GMT -7.   It's 02:35 AM.
