Old 11-09-2009, 08:12 PM   #241
warewolf
Tyre critic
warewolf's Avatar
Oddometer: 2,169
Send a message via MSN to warewolf Send a message via Skype™ to warewolf
Originally Posted by dirty_sanchez
Warewolf- Using Nylon insert nuts along with a threadlocker are sort of a belt AND suspenders sort of thing. Nylon insert nuts are designed to be a one use only type nut believe it or not.
Ta, yes I did know nylocks are single use. They are heaps harder to get on when new - it's a bit of a give-away.
The context was rear sprocket nuts. KTM says to use 243 on the bolts, but the nuts are not nylocs but something else with an ovalised bore.
Cheers,
Colin
KTM LC4 640 Question? Check here first --> KTM LC4 (640) Index Thread
Originally Posted by Steve McQueen
All racers I know aren't in it for the money. They race because it's something inside of them... They're not courting death. They're courting being alive.
warewolf is offline   Reply With Quote
Old 11-09-2009, 08:25 PM   #242
dirty_sanchez
Dirty_Sanchez
dirty_sanchez's Avatar
Oddometer: 2,096
243 is a new and improved version of the old 242.
243 is a slight bit stronger than 242.
No need to shake the bottle at the beginning of the day, and it's not as picky about working on less than perfectly cleaned and degreased threaded fasteners.
I use belts and suspenders by the way.
Dirty
No, really, the mustache means I love you.
'09 KTM 250SXF for Sale, take a look: http://advrider.com/forums/showthrea...7#post21410167
dirty_sanchez is offline   Reply With Quote
Old 11-10-2009, 05:19 AM   #243
FakeName
Wile E Coyote SuperGenius
FakeName's Avatar
Oddometer: 1,160
Good question.
It's worth $64,000.
Good Question.
Dirty
And I collect- how?
2011 White 990 Adv R
2003 565exc
FakeName is offline   Reply With Quote
Old 11-10-2009, 05:39 AM   #244
dirty_sanchez
Dirty_Sanchez
Oddometer: 2,096
Have you ever heard of the "Free Beer Tomorrow" sign?
Get with me tomorrow. OK?
Dirty
Old 11-10-2009, 08:13 AM   #245
PETDOC
Oddometer: 1,163
Yep, localized heat in the form of a soldering iron, a blow torch, flaming WD-40, etc until you see that first whisp of smoke and you're ace in the hole. Be warned, an oil seal or some other part that does not play well with heat or open flame might be in close proximity to that heat source.
Dirty
Dirty,
I had to remove the rear pivot pins on my BMW R1150GS, which had been set at the factory with a Loctite-like product, requiring 240 degrees F before unscrewing. The pivot pins are screwed into the finished swingarm and in close proximity to a rubber boot over the rear U-joint. While many have used a torch for this, I found a heat gun and laser temp gauge worked fine. I caused no discoloration or damage to surrounding parts, and have subsequently removed the replaced pivots pins (loctite 271) using the same technique with the same result.
2004 R 1150 GS
PETDOC is offline   Reply With Quote
Old 11-10-2009, 11:04 AM   #246
dirty_sanchez
Dirty_Sanchez
Oddometer: 2,096
Doc- Good to hear you were able to control the heat.
I tell folks to be ware of the damage to ruber parts in close proximity to rubber plastic parts all of the time.
Glad you took care of the problem without any mishaps.
Dirty
Old 11-10-2009, 04:39 PM   #247
datchew
Don't buy from Brad
datchew's Avatar
Oddometer: 7,403
Yep, 567PST. Good for 400F, 10,000psi, NSF 61 rated, prevents stainless from galling, and makes for a rather nice compliment to Russian Caviar-or spread lightly on toast with jam.
The pn. for a 6ml tube is 56707
Dirty
AWESOME!! I already have a BIG tube downstairs that i use for petcocks and other gasoline-type stuff. Helloooooo stainless NPT fittings!
Can I also use it for a salad dressing?
On tap:Nada
Aging: 3 experiments in mead - blackberry, apple, and straight honey
datchew is offline   Reply With Quote
Old 11-10-2009, 07:33 PM   #248
dirty_sanchez
Dirty_Sanchez
Oddometer: 2,096
567PST, 15 year old balsamic vinegar, and Rotella 5w40 Synth makes for an epic sensation salad.
Yes, you may use it!
Dirty
Old 11-10-2009, 08:48 PM   #249
NordieBoy
Armature speller
NordieBoy's Avatar
Oddometer: 6,766
Dirty
And you'll feel all clean and tingly afterwards.
Also the weight loss will make the bike feel like it's got 5 extra HP.
NordieBoy is offline   Reply With Quote
Old 11-22-2009, 12:00 AM   #250
bushnbikes
bushnbikes's Avatar
Oddometer: 48
Loctite 648 - is 262 a reasonable alternative?
Hi Dirty,
Great thread! Thank you.
I have a couple of questions relating to securing the starter cluch mechanism to the back of my magneto rotor on my KTM990. I removed the 6 x 6mm HT cap screws without heat (but a little hand-held effort) and found a greenish-blue clearish lacquer thread compound on the bolts. It was difficult to chip away but I managed to clean up both the male and female threads. As a final prep I degreased them with a few applications of brake cleaner and screwed the bolts in & out a few times.
Questions:
Loctite 648 (& 15Nm) is spec'd in the manual - but 648 is not listed in the Australian catalogue. I note from the German site it is "Festigkeit: Hoch" -high strength. Can you please advise the properties of this compound that differ from Loctite 262? I noted somewhere 603 was an option but I was unable to find that here either.
Will 262 do the equivalent job to 648 for this application? I have bought some. Is there a better choice (that is available in Australia).
Do you think with high tensile bolts and (??) stainless female threads that I should be able to break the threadlock without heat in the future?
I've noted through this thread that heat is the removal solution for red loctite. Does the heat temporarily melt the compound or does it permanently destroy the chemical bonds? I'm thinking to the future when I have to remove it again and not wanting to apply too much heat to the associated magnets in the rotor. I was thinking of just heating the bolts locally and letting them cool if I couldn't shift them initially (next time around).
I've included a photo of the back of the rotor and the starter clutch mechanism where the bolts come through. I think it is subject to faily high operating temperatures, certainly synthetic oil and probably shock loads when the clutch catches on starting.
Cheers
BnBs
bushnbikes is offline   Reply With Quote
Old 11-22-2009, 12:54 AM   #251
Andy-Gadget
Any bike can go anywere
Andy-Gadget's Avatar
Oddometer: 1,251
Ah, NPT, the only pipe thread system in the world with a DESIGNED in leak path, what were they thinking.
NPT has made my life hell in the past, as I live in an english dominated engineering world, BSP just works, NPT has to be MADE to work, and yes, the fix is loctite or equivalent.
"If a man empties his purse into his head, no man can take it away from him.
An investment in knowledge always pays the best interest"
Benjamin Franklin.
'95 Sport 1100 Guzzi,'84 Cali 2 Guzzi, '95 Guzzi mille, '84 R65LS, '84 R100, '82 R100RS, '05 DL650, '72 Bultaco Sherpa T 350, '78 Montessa 348, "00 XR650R
Andy-Gadget is offline   Reply With Quote
Old 11-22-2009, 06:45 AM   #252
dirty_sanchez
Dirty_Sanchez
Oddometer: 2,096
Bushn-
I'm not doubting you can't find 648, but it is listed as a worldwide available product in the US catalog.
Retaining Compounds are products designed to strengthen bearing fits and prevent keyed assemblies from wallowing out.
It is important to think of retaining compounds such as 648, and all of the 6XX series products as a threadlocker on steroids. Retaining compounds are STRONG as compared to traditional threadlockers. RC's are designed for cylindrical engagement while threadlockers are designed for mechanical threaded engagement.
Since RC's and TL's are designed for different sorts of applications, we show strength values in shear strength for RC's but show breakloose and prevailing torque for threadlockers. Gap filling ability isn't even mentioned in the threadlocker data.
One thing we need to consider in this particular application is to wonder why KTM (who no doubt has a Austrian Loctite Rep working closely with them to assist in spec'ing products) has chosen a retaining compound instead of a threadlocker for this application.
262 more than likely will work just fine in your application, but there are more suitable and stronger products to suggest.
The following link is from the Loctite Austrailia. If you can't find 648, go with another product with a similar sheer strength.
http://au.iloctite.com/en/loctite-64...-648-retaining
You are correct, heat will very likely be needed to soften the material enough for you to loosen the fastener. One the material is heated to the point you see that first wisp of smoke, loosen it up. As suggested before, full size blow torches are an overkill. As the chief purveyor of peace, love, and glue for ADVdom, small blow torches used by crack/meth-heads is the ideal source of localized heat without putting too much heat into your parts.
Once a threadlocker or any other anaerobic chemistry has had heat applied to it, and then let cool, without loosening the assembly, the ultimate strength has been sacrificed and the assembly should be taken apart and have threadlocker, retaining compounds reapplied.
Dirty
dirty_sanchez screwed with this post 11-24-2009 at 04:46 AM
Old 11-22-2009, 07:26 AM   #253
FakeName
FakeName's Avatar
Oddometer: 1,160
Huh.
So what about higher temp uses, like exhaust manifolds or even brake rotors- does the heat compromise the integrity of the bond?
Thanks again. Still waiting on the $64k check for my last question- will you ask accounting??
2003 565exc
Old 11-22-2009, 07:53 AM   #254
dirty_sanchez
Dirty_Sanchez
Oddometer: 2,096
Originally Posted by FakeName
Huh.
Times are tough in "Sticky Land". We have been on a rice and beans, beans and rice diet for 6 months with no-name saltines topped with gov't cheese on Sundays. Can we issue an IOU....tomorrow?
We're handing out free beer tomorrow by the way as well.
As a rule, unless the bottle or tube explicitly says HIGH TEMPERATURE, anaerobic chemistries like threadlockers, thread sealants, gasket eliminators, and retaining componds are all good for 300F
Threadlockers like 294, 246, 266, and 272 are good for 450F.
The two newest threadlockers we have happen to be resistant to 650F. These are a blue medium strength 2422, and a red high strength 2620.
For the two specific applications you mentioned above, 2422 would be suitable.
Dirty
Old 11-22-2009, 09:43 AM   #255
bushnbikes
bushnbikes's Avatar
Oddometer: 48
KTM990 / Loctite 648
Hmm, very interesting Dirty. That link you gave me had just the information I was looking for earlier. I obviously didn't look for long enough! I think you realise I'm not putting the threadlock/ retaining compaound on the shaft/ keyway and it is going on the six threads in the photo.
I think from looking at the TDSs in the link that the 262 would have to be a temporary solution. I need to get it back together and operational to ship it to NZ soon. So I'll use the 262 as a back up.
I can also see why KTM chose the 648. It got some good properties. I will try Loctite Australia again today (once everyone wakes up and goes to work -it's 04:30hrs here ).
If I can't get the 648 I'm going to try for the 620 then the 603. The 620 seems to have some very interesting heat/ aging properties and similar strength and resistance properties to the 648.
Thank you for your help. May you have many hours of great riding.
Cheers
BnBs
Bushn-
Dirty
Times are GMT -7.   It's 02:31 AM.
