Old 01-04-2013, 03:21 PM   #556
dirty_sanchez
Dirty_Sanchez
dirty_sanchez's Avatar
Oddometer: 2,914
Originally Posted by DockingPilot View Post
Thanks Dirty,
*only 3 threads ? not the entire threaded shank or shaft ?
If you really want to, but it's an overkill. Apply the threadlocker where the male and female threads actually come in contact with each other once the fastener is tight.
Dirty
No, really, the mustache means I love you.
dirty_sanchez screwed with this post 01-04-2013 at 03:28 PM
dirty_sanchez is offline   Reply With Quote
Old 01-04-2013, 03:25 PM   #557
DockingPilot
Hooked Up and Hard Over
DockingPilot's Avatar
Oddometer: 9,549
Appreciate your help.
Frank Reinbold
"Every bike I ever had, was the best bike I ever had, when I had it"
DockingPilot is offline   Reply With Quote
Old 01-04-2013, 05:13 PM   #558
snakeroll
snakeroll's Avatar
Oddometer: 6
This was a good thread! I learned things that I didnt even know that I didnt know!
snakeroll is offline   Reply With Quote
Old 01-05-2013, 06:48 AM   #559
dirty_sanchez
Dirty_Sanchez
Oddometer: 2,914
Originally Posted by indr View Post
Not Loctite specific but thought this would be the place to get an answer.
Re-installing the oil pressure switch on the bike calls for using silicone sealant on the threads.
Would some of this work or do I need expensive automotive silicone sealants?
Wrong product, flat out. If you don't want to run the risk of leaks get yourself down to the local NAPA/Auto Shack parts place and buy a tube of sensor-safe RTV. You'll know it's the right product because right on the package it'll say "Sensor Safe" OR might say something to the effect of "Safe on O2 Sensors".
Don't get anything labelled Red High Temp RTV. It's crap and your brake fluid will break the stuff down causing a leak in short order.
Make the purchase then remove the cap and take a whiff. If you smell vinegar, it's not sensor safe. Vinegar smell tells you it won't stand up to oils fuels, or any petroleum based fluids. Return it. You should be safe with the purchase of a Black Sensor Safe RTV.
Take a whiff of the product. You're looking for a clean smell. These are in the oxime cure family of RTVs and are safe on electrical components, fuels, oils, greases, and any other fluid found on a bike.
What you have pictured is what is called an acetoxy cure RTV. As this RTV cures one of the by products is a flashing off of acetic acid gas which wreaks havoc on electrical components.
I've covered acetoxy vs. oxime cure RTVs in great detail earlier in this thread, it shouldn't take too long to locate the information if you want to feed your head.
Dirty
Old 01-06-2013, 03:36 PM   #560
wheels
Practicing to retire
wheels's Avatar
Oddometer: 143
Which Loctite for metal to plastic?
Hi Dirty, I'm working on a late model Ducati air box. The cover that get's you access to the air filter has three screws that hold it in place. The allen bolts thread into a metal insert that is embedded in the plastic body. One of the inserts pulled out. I'm not sure what type of plastic the body is, it looks like ABS, but not sure. Question is what's the best adhesive to bond the metal insert to the plastic.
Thanx
Jim
Jim
"Full Tilt Bozo Panic"
wheels is offline   Reply With Quote
Old 01-07-2013, 09:16 AM   #561
dirty_sanchez
Dirty_Sanchez
Oddometer: 2,914
Thanx
Jim
After looking over Loctite's Metals and Plastics bonding guide I'd go with 401. A 3gm tube is likely all you'd need given the application.
pn. 40104 Locite 401 Instant Adhesive, 3gm tube
The insert is likely knurled and the injection molded plastic will likely be very rough. This is good because because both surfaces have a good mechanical profile which increases the surface area which makes for a strong bond. Clean it out with a liberal shot of Electrical Contact Cleaner and blow out the hole. Let it dry completely.
You'll have about 15 seconds to press the insert into the airbox body. I'd grip the bolt head with a pair of vice grips, screw the insert onto the bolt 3 or 4 threads worth, apply the adhesive inside of the stripped out airbox hole, then firmly press the insert back into the airbox and maintain pressure for 2 minutes.
Let everything sit for a few hours or overnight if possible before you button her back up.
Dirty
Old 01-07-2013, 12:01 PM   #562
ttpete
Rectum Non Bustibus
Oddometer: 5,822
Thanx
Jim
I'd probably just stick a wellnut into the hole and screw the cover back on.
15 BMW RnineT
09 Kaw Versys
Old 01-07-2013, 01:40 PM   #563
wheels
wheels's Avatar
Oddometer: 143
That's a good idea Pete, and it's plan B, but I'd have to secure it anyway. If a wellnut got loose in the airbox and got in the intake that wouldn't be good.
Jim
Old 01-07-2013, 01:41 PM   #564
wheels
wheels's Avatar
Oddometer: 143
Dirty
Thanx Dirty, that's exactly the plan.
Jim
Old 01-24-2013, 08:25 PM   #565
a109drvr
a109drvr's Avatar
Oddometer: 48
Hey Dirty,
Read this whole thread, quite an education - thanks!
I've got a few questions about my dodge truck. For sealing differential covers would you recommend 598 RTV? These covers don't use gaskets. The repair manual calls for red Mopar silcone sealant or equivalent.
Can I use 518 on my transmission pan and get rid of the gasket? It perpetually weeps every time I change it whether I use an oem or aftermarket gasket. Clearance shouldn't be an issue without the gasket.
Lastly, is there anything I can use that will stop the corrosion on brake caliper bleed valves? I don't have a problem with them sealing, but I'm in the rust belt and tired of using cans of kroil and hoping I don't snap them off.
a109drvr is offline   Reply With Quote
Old 01-24-2013, 08:29 PM   #566
dirty_sanchez
Dirty_Sanchez
Oddometer: 2,914
Another question, similar to the one I asked before.
On the stator engine cover, at the point where the wires run from the inside to the outside, there is a removable rubberized seal used. This itself doesn't properly seal the oil in so, a dark reddish silicone adhesive is also used around the edges to provide a proper seal.
Does Loctite make a similar product? Something that sticks to both metal and rubber...
I was looking for a Loctite product that matches your criteria for sealing crankcases and came upon this: http://www.henkelna.com/cps/rde/xchg...=8797922295809
It's resistant to oils and chemicals. Would this work for both my previous and this current application?
Cheers.
Indr- I saw this post the other day and forgot to get back to the answer.
Ding Ding Ding!
The link of the product posted is exactly what I'd go with. Good call!
Dirty
Old 01-24-2013, 08:45 PM   #567
dirty_sanchez
Dirty_Sanchez
Oddometer: 2,914
Originally Posted by a109drvr View Post
Hey Dirty,
For stamped assemblies like a rear diff. cover, the gaps are all over the place. Around the bolt heads you'll have a minimal gap, then when you tighten up the bolts, the cover will bow ever so slightly as you torque the bolts. Don't ever use a red RTV on anything that involves fuel, oils, or ethylene glycol-the RTV will break down and leave a drip/puddle on the carport floor. You want to use an RTV like the aforementioned 598, Instant Gasket, or any other RTV that says somewhere on the tube "Sensor Safe" These types of RTV's fall into the oxime cure family rather than the vinegar smelling rtv's which are acetoxy-cure RTV's.
For what it's worth there are many different colors of RTV's in each of the two main single component RTV retail consumers have acess to.
As far as the Transmission pan, more than likely, it is a stamped part like the differential cover. The same holds true with gaps that are all over the place. For wildly fluxuating mating gaps, this is when we choose a suitable RTV.
Gasket Eliminators like 515, 518, 510, etc are for rigid gasketed assemblies where once two parts are mated and torqued up, the gaps are minimal- normally no larger than 0.005" to 0.010". An example of a rigid assembly on an engine would be where the jug mates to the case, or the jug mates to the head, or where the engine case halfs mate.
Good questions-keep 'em coming.
Here a stump the band question for everyone-
Who knows why its so difficult to bond glass?
Dirty
Old 01-25-2013, 10:41 PM   #568
nnichols
Slave to the Machine
nnichols's Avatar
Oddometer: 149
Dirty
I'll bite. Is it because its too smooth and not enough pores or grains to attach to?
Nathan - 08 KLR650 - Moore, OK
nnichols is offline   Reply With Quote
Old 01-26-2013, 04:35 AM   #569
buickid
Lets ride!
Oddometer: 310
Low energy material?
2005 Yamaha Zuma YW50, 2009 Kawasaki Super Sherpa KL250
buickid is offline   Reply With Quote
Old 01-26-2013, 06:02 AM   #570
DC2wheels
Castle Anthrax troll
DC2wheels's Avatar
Oddometer: 2,540
It probably has something to do with the fact that glass is actually a "super-cooled liquid"?
It VERY SLOWLY flows. Look at a very old pane of glass- it is thicker at the bottom than at the top.
'92 K100RS
'12 DRZ400
sugarhillctd on the world-wide K11OG forum
I got my MotoMatters calendar, did you?
DC2wheels is offline   Reply With Quote
Times are GMT -7.   It's 01:11 PM.
