Old 03-30-2014, 08:04 AM   #661
dirty_sanchez
Dirty_Sanchez
dirty_sanchez's Avatar
Oddometer: 2,959
Todd-on something like threaded linkage bolts I'd use a blue removable threadlocker.
Anti-Seize is nothing more than a combination of grit/metal dust/graphite/molybdynum and grease-properly used in high heat applications on a bike on spark plug threads, exhaust header studs, etc.
On linkage bolts, I'd use a blue threadlocker which is easily removed with hand tools on the threads. You already mentioned the linkage fasteners have shown corrosion even after you use an anti-seize on them. A threadlocker in a liquid or stick form completely fills that 70% airgap found in between male and female threads and cures to a hard thermoset plastic which reliably keeps moisture out of the threads, and if we can keep all moisture out of that airspace, we've eliminated rustlock.
If you haven't already-go to page one on this thread, get your favorite Sunday Morning beverage and start reading.
Glad you jumped in with a question. The thread has sorta been quiet for the last few weeks.
Dirty
No, really, the mustache means I love you.
dirty_sanchez is offline   Reply With Quote
Old 03-30-2014, 08:11 AM   #662
dirty_sanchez
Dirty_Sanchez
Oddometer: 2,959
Anti-Seize is nothing more than a combination of grit/metal dust/graphite/molybdynum and grease-properly used in high heat applications or applications where critical torque values are needed to achieve specific clamploads-this is a whole different topic of discussion because we'd be testing different thread finishes, coatings, lubricity factors (aka "K factor").
Places I use anti-seize on my bikes are: spark plug threads, exhaust header studs, front and rear axle nuts, counter shaft nut, chain tension bolts on the swingarm, etc.
Dirty
Old 03-30-2014, 08:26 AM   #663
todd83-900t
Oddometer: 169
Sorry for the confusion but the threads of the fasteners are free of corrosion. It's the smooth part of the bolt's that are rusting. For example, the body of the swing arm bolt or the dog bone bolts that the 640A have.
Yes, I'm a 243 convert and apply it to everything.
05, KTM EXC 450,
2003, KLX-400
todd83-900t is offline   Reply With Quote
Old 03-30-2014, 09:26 AM   #664
dirty_sanchez
Dirty_Sanchez
Oddometer: 2,959
I'd clean the non-threaded shank of the bolt shaft with steel wool or hit it a lick with a wire wheel on a bench grinder to clean it up, then rub down the non-threaded shank of the bolt with firm fingertip pressure with a waterproof grease. I use a synthetic zero-water washout grease, but any waterproof grease would be better than nothing, then reassemble.
Dirty
Old 03-30-2014, 06:31 PM   #665
stainlesscycle
stainlesscycle's Avatar
Oddometer: 2,267
Originally Posted by todd83-900t View Post
Dirty,
What do you put on your suspension linkage bolts and main swing arm bolt to prevent corrosion. I've tried BelRay water proof grease, grease mixed with molypaste and bacon grease. Over the years I've found that if I don't service the suspension every year or so I'll end up with corroded bolts. The bearings are sealed from water but the bolts aren't and most of the grease is wiped off when you assemble the suspension. I'll give Marine anti-seize a try, but I'm tempted to try some type of wax.
What say the Benevolent Loctite Overlord?
the only solution is to service the bolts/linkage more often. i use waterproof grease, but nothing is 100% sealed and they routinely see water/dirt/etc. disassemble, grease, and reassemble is the only reasonable solution. you could zirk fitting some of the pivots - that kind of depends on the design..
current bikes
stainlesscycle is offline   Reply With Quote
Old 03-30-2014, 07:19 PM   #666
sailah
Lampin' it
sailah's Avatar
Oddometer: 5,689
I have a bearing for a Cush KTM 640 on one side that has lost its press fit. I'd call it a nice slip fit. The journal isn't spun but looks like it has slipped. I micd the bearing at 52.00mm and the bore at 52.02mm on average
Anyways the plan is retaining compound. I have some 680 but wondering what the best compound would be knowing that I will need to remove at normal maint intervals? Is 680 overkill?
We're not out here to rough it. We're here to smooth it. Things are rough enough in town.
Nessmuk
Old 03-30-2014, 07:35 PM   #667
dirty_sanchez
Dirty_Sanchez
Oddometer: 2,959
680 would be a fine choice. We're well within the cure through gap.
Clean the OD of the bearing and the ID of the hub with a good residue-free cleaner degreaser. Spread a thin uniform bead of 680 around the OD of the bearing and slip into place. Wipe off any squeezeout, mount the wheel on the bike, torque the axle nut to spec and let sit overnight. By mounting the wheel you'll be squaring up the bearing and seating it to the proper depth.
That's it. By using a retaining compound the bearing fit will be 3 times stronger than it was off of the factory floor.
Use a little heat for removal. The book says to heat the surface up to 500F for 5 minutes, but once you see that first whisp of smoke, the material will have softened enough you'll be able to tap out the bearing from the inside with a drift and tap hammer.
Great application!
Dirty
Old 03-30-2014, 08:07 PM   #668
sailah
Lampin' it
sailah's Avatar
Oddometer: 5,689
Awesome thanks I was worried it was going to be too much. Anything with less heat required to disassemble?
Nessmuk
Old 03-30-2014, 08:12 PM   #669
dirty_sanchez
Dirty_Sanchez
Oddometer: 2,959
If the bearing ever fails-and I doubt it will you could press it out with an arbor press if the throat was deep enough....or you could use an inside jaw slide hammer and a little heat.
It'll be fine.
Dirty
Old 04-17-2014, 11:37 AM   #670
simestd
simestd's Avatar
Oddometer: 284
Originally Posted by dirty_sanchez View Post
Yup. It depends ALOT on the joint design, but yes, in many applications bonding can be as strong as welding.
Wacky stuff I tell you!
Dirty
Hey Dirty,
Along exactly those lines, what Loctite product would you recommend for attaching a rare earth magnet to a smooth aluminum casting. Specifically I want to make make up a magnetic drain plug for my XT225 by bonding a high temperature magnet into this pocket:
From ADV
Tom
'82 XV750, '82 GL500, '02 DR650, '07 XT225
simestd is offline   Reply With Quote
Old 04-17-2014, 11:46 AM   #671
ttpete
Rectum Non Bustibus
Oddometer: 5,950
Originally Posted by simestd View Post
Hey Dirty,
From ADV
I'd go in there with a dremel tool and cut a slot in each of those 3 tits, then drop in the magnet and use an internal snap ring in the slots to keep it there. Last thing you want is a magnet getting loose and jamming in a transmission gear.
15 BMW RnineT
09 Kaw Versys
Old 04-17-2014, 01:46 PM   #672
simestd
simestd's Avatar
Oddometer: 284
I've seen that done - and there was a fellow who did a short production run over on xt225.com. The rub is the magnets that will tolerate high temperatures without becoming demagnetized are only available in limited size ranges and I can't find one that would be a good fit behind a snap ring in that space without an additional layer to hold it in. If I can find an adhesive that will tolerate oil submersion and the typical crankcase temperatures while providing good shear strength then it's a lot simpler just to glue the thing. Look at the goldplug.com plugs - those are all glued - and I'd be buying one over there but due to the oddball drain plug design, they don't make one for the XT225. By the way, I'm just trying to make one for myself and then share the knowledge.
Tom
Old 04-19-2014, 10:28 AM   #673
_cy_
Oddometer: 6,274
@Dirty_Sanchez .. to the red courtesy phone
your assistance is needed here:
http://www.advrider.com/forums/showt...=969129&page=7
seems on R1200GS rear caliper bolts factory spec is a super low 18ft lb .. which IMHO is a fuck up by BMW. no one else no one else in the world that I'm aware of uses 18ft lb torque that low to hold together a mission critical part like brake calipers.
reports of untouched rear caliper bolts backing out causing wholesale destruction to final drive and/or spokes. best theory is rear fender bobbing around helps rear caliper bolt back out.
assuming proper grade fasteners are used .. an 8mm bolt and cast aluminum bolt threads into is capable of holding torque in excess of 18ft lb spec'd by BMW.
loctite apparently states no change in torque value is needed. but when loctite is applied aprox 11% increase in torque will result. which IHMO is a good thing increasing torque to 20ft lb in this particular application.
_cy_ screwed with this post 04-19-2014 at 10:16 PM
Old 04-19-2014, 12:06 PM   #674
dirty_sanchez
Dirty_Sanchez
Oddometer: 2,959
I looked over the Technical Data Sheets for a number of different epoxies for bonding one of those rare earth magnets into a drain plug and settled on E-20HP.
At the 1,000 hour mark, the strength of this adhesive actually goes up to 171%ish of it's full cure strength when in continuous immersion in motor oil. At the 500 hour mark it's strength is 164%.
Chemical / Solvent Resistance
Cured for 5 days at 22C on steel with no induced gap, aged
under conditions indicated and tested at 22C.
Solvent Temp. % Initial Strength retained at
500 hr 1000 hr
Air 87C - 137
Motor Oil (10W-30) 87C 164 171
Unleaded Gasoline 87C 108 82
Water/Glycol (50%/50%) 87C 121 125
Salt/Fog ASTM B-117 22C - 73
95% Relative Humidity 38C - 100
Condensing Humidity 49C - 90
Water 22C - 81
Acetone 22C 76 95
Isopropyl Alcohol
As others have suggested, with a Dremel tool, grind out the plug so you can fit the magnet into the drain plug cavity, clean it out real good with a residue-free cleaner/degreaser, fill the cavity roughly 25% full, slowly fit the magnet into place so that it fits all the way in the bottom of the drain plug. Work clean, wipe off all squeeze out so the male threads in the drain plug don't get fouled by the soon-to-be-cured epoxy.
In keeping this as generic of a thread as possible I don't ever offer up part numbers for my suggestions, so if you want suitable part numbers-PM me and I'll shoot them over to you.
Great Application! Thanks for asking!
Dirty
Old 04-19-2014, 12:13 PM   #675
RFVC600R
SAND EATER!
RFVC600R's Avatar
Oddometer: 2,864
171% full strength?? That's awesome. I think I'm going to make a magnetic plug for my sump.
'83 Honda XL600R 618cc 11:1 Wiseco, XR's Only Exhaust + over sized header
Originally Posted by Carter Pewterschmidt View Post
He's the XL600 Jesus, his bike dies for our sins.
RFVC600R is online now   Reply With Quote
Times are GMT -7.   It's 12:08 AM.
