Old 04-19-2014, 01:06 PM   #676
dirty_sanchez
Dirty_Sanchez
dirty_sanchez's Avatar
Oddometer: 2,887
I looked over the Technical Data Sheets for a number of different epoxies for bonding one of those rare earth magnets into a drain plug and settled on E-20HP.
At the 1,000 hour mark, the strength of this adhesive actually goes up to 171%ish of it's full cure strength when in continuous immersion in motor oil. At the 500 hour mark it's strength is 164%.
Chemical / Solvent Resistance
Cured for 5 days at 22°C on steel with no induced gap, aged
under conditions indicated and tested at 22°C.
Solvent Temp. % Initial Strength retained at
500 hr 1000 hr
Air 87°C - 137
Motor Oil (10W-30) 87°C 164 171
Unleaded Gasoline 87°C 108 82
Water/Glycol (50%/50%) 87°C 121 125
Salt/Fog ASTM B-117 22°C - 73
95% Relative Humidity 38°C - 100
Condensing Humidity 49°C - 90
Water 22°C - 81
Acetone 22°C 76 95
Isopropyl Alcohol
As others have suggested, with a Dremel tool, grind out the plug so you can fit the magnet into the drain plug cavity, clean it out real good with a residue-free cleaner/degreaser, fill the cavity roughly 25% full, slowly fit the magnet into place so that it fits all the way in the bottom of the drain plug. Work clean, wipe off all squeeze out so the male threads in the drain plug don't get fouled by the soon-to-be-cured epoxy.
In keeping this as generic of a thread as possible I don't ever offer up part numbers for my suggestions, so if you want suitable part numbers-PM me and I'll shoot them over to you.
Great Application! Thanks for asking!
Dirty
No, really, the mustache means I love you.
dirty_sanchez is offline   Reply With Quote
Old 04-19-2014, 01:13 PM   #677
RFVC600R
SAND EATER!
RFVC600R's Avatar
Oddometer: 2,677
171% full strength?? That's awesome. I think I'm going to make a magnetic plug for my sump.
'83 Honda XL600R 618cc 11:1 Wiseco, XR's Only Exhaust, big tube header, 6 Sigma stage 3 carb mods
Originally Posted by Carter Pewterschmidt View Post
He's the XL600 Jesus, his bike dies for our sins.
RFVC600R is online now   Reply With Quote
Old 04-19-2014, 01:24 PM   #678
dirty_sanchez
Dirty_Sanchez
Oddometer: 2,887
Yeah, it's kinda interesting how different fluids and chemical exposures can effect full strength of adhesives.
Old 04-19-2014, 01:57 PM   #679
dirty_sanchez
Dirty_Sanchez
Oddometer: 2,887
Cy-Thanks for asking for my input on that thread. Even bigger thanks for all of the battery research on your Battery Thread-something that is so far above my level of understanding I'm overwelmed.
Now on to the question on the Rear Brake Caliper bolts for the big BMW's. For shits, I looked up the front and rear brake caliper bolt torque spec for the 690 and it is 18.4lb/ft or 25nm or 221in/lb. So this torque spec must be in the ballpark.
The question after looking over the thread and the bickering you referenced is that will adding a blue or red threadlocker increase or decrease the torque needed to adequately secure that brake caliper. -The question was phrased incorrectly- read on.
As I have mentioned earlier in this thread most of us don't have tools at our disposal to measure clamp load, but most of us have a repeatable device known as a torque wrench.
Torque required to achieve a certain clamp load on dry non-lubricated threads will be considerably greater than the same clamp load on lubricated threads. Thread galling and deformation is also more likely to rear it's ugly head on dry threads as well.
For reference, most anti-seizes have a "K Factor" or "Lubricity Factor" of roughly 0.11 to 0.16. Blue threadlocker liquids and sticks have a lubricity factor of 30 weight motor oil, which has a lubricity or K factor of roughly 0.13.
Clamp load will be greater (your parts will be held together much more strongly) for the same torque value on lubricated threads than they ever will be if they were assembled with non-lubricated threads.
What does this mean? Use a blue threadlocker (I suggest 243) on those NEW cleaned and degreased brake caliper bolts and torque them down to the recommended 18ft/lbs. with a calibrated clicker-style torque wrench and be done with it. By lubricating the threads we'll have a ball park increase in clamp load of no more than 10%...but this is just an educated guess.
Are we clear as mud now?
Dirty
Old 04-19-2014, 02:54 PM   #680
_cy_
Oddometer: 6,054
Dirty
thanks for your feedback .. it's obvious that you are the go to person on Adv for loctite technical questions ...
Justice has been saying basically the same thing in busted caliper thread. now you've verified it.
Old 04-19-2014, 03:19 PM   #681
just jeff
Oddometer: 867
Just for a reality check....10% of the stated 18ft/lbs is 1.8ft/lbs. I wonder who among us has a torque wrench sensitive enough or operates it well enough for this to matter.
jj
ErikMotoMan: "People struggle with many things in their lives. But the answer to struggle isn’t MORE struggle. It’s peace. If you want more joy, peace, love, happiness… you have to GIVE those things first. You have to THINK those things. You have to have faith that they’ll come to you, despite what you may see. The truth isn’t in what you see with your eyes. It’s what you feel in your heart."
just jeff is offline   Reply With Quote
Old 04-19-2014, 04:36 PM   #682
dirty_sanchez
Dirty_Sanchez
Oddometer: 2,887
jj
Ding Ding Ding!!
It's not like we're building a spaceship destined for a mission to Mars that's dependant on uber critical torque specs.
Dirty
Old 04-19-2014, 04:52 PM   #683
simestd
simestd's Avatar
Oddometer: 268
Thanks for the in-depth and complete research there Dirty! PM inbound shortly for more specific part number and availability information
Tom
'82 XV750, '82 GL500, '02 DR650, '07 XT225
simestd is online now   Reply With Quote
Old 04-19-2014, 05:02 PM   #684
simestd
simestd's Avatar
Oddometer: 268
Careful which magnets you choose
Not to go off thread, but the rare earth magnets can be made of different materials and most will loose a significant portion of their strength if exposed to typical crankcase temperatures.
K&J Magnetics has a good blog post explaining the thermal properties of various types of super magnets.
This is where I'm sourcing the magnets I am using.
Tom
Old 04-19-2014, 05:11 PM   #685
ttpete
Rectum Non Bustibus
Oddometer: 5,758
jj
You're not going to do it with a 100 ft/lb wrench, which is what I suspect is the problem behind all of the torque wrench disasters we see. It's just not accurate at either end of its range. I have nice small beam type wrenches that are plenty accurate at that figure.
15 BMW RnineT
09 Kaw Versys
Old 04-19-2014, 05:58 PM   #686
ohgood
ohgood's Avatar
Oddometer: 2,633
18 lbs? Why not just use a quarter inch drive and not try to kill it?
I'll likely strip out every bolt I turn tomorrow, now that I got worse about it
scrolling through the words to get to the pictures is cool, but i'm really just here for the tracks and waypoints... post some ok ?
ohgood is offline   Reply With Quote
Old 04-19-2014, 06:28 PM   #687
ttpete
Rectum Non Bustibus
Oddometer: 5,758
If you're doing it in in/lbs, the figure is 216.
15 BMW RnineT
09 Kaw Versys
Old 04-19-2014, 06:32 PM   #688
_cy_
Oddometer: 6,054
bonified tool nut here ... beam torque wrenches are typically more accurate than click types. part of problem is folks don't unwind their wrenches, so spring takes a set. always unwind after use, unless you've got an internal beam clicker.
here's pics of different types of torque wrenches, including several 1/4 in drive in lb. one beam 0-120 in lb, one screwdriver style 2-36 in lb and clicker style 10-150in lb.
Snap-on electronic torque meter to calibrate other wrenches and to document precise settings. with 1/4in, 3/8in and 1/2in torque sensors. which are sitting on Snap-on 1/2 dr beam 0-200ft lbs
note the in oz setting on Snap-on electrotorque meter
Old 04-19-2014, 07:25 PM   #689
just jeff
Oddometer: 867
Very cool but not many home mechanics out there spend the thousands of dollars represented in that collection ON THEIR BIKES let alone their tools!!
Old 04-20-2014, 03:14 AM   #690
NZRalphy
NZRalphy's Avatar
Oddometer: 206
Hey Dirty
Mate brilliant info and I have learnt a LOT of stuff here. It's kind of like going to a Loctite seminar but in my own time. Happy. So many questions have been answered. MrsR kept looking over my shoulder for the last days 'Are you STILL reading that? humph'. I am now a loctite nerd, loving it.
Thank you. Oh and be sure your boss gets to see your effort to help us at this site.
NZRalphy is online now   Reply With Quote
Times are GMT -7.   It's 01:46 AM.
