Old 07-08-2012, 11:54 PM   #3646
Ni3ous
Double Axle Rider
Ni3ous's Avatar
Oddometer: 221
https://www.google.si/search?hl=sl&c...K8n80QWCm9yaBw
Tènèrè Spirit
Ni3ous is offline   Reply With Quote
Old 07-09-2012, 06:15 AM   #3647
calvin_
calvin_'s Avatar
Oddometer: 9
I remember seeing this cover on youtube, but I couldn't find a manufacturer who has the specific model for the 660.
I'm also interested.
calvin_ is offline   Reply With Quote
Old 07-09-2012, 12:33 PM   #3648
MORT666
MORT666's Avatar
Oddometer: 214
Question suspension pre-load
Hi recently purchased a 2009 xt660z tenere taken it off road today has any on got pet per-load settings for a 13 stoner?
MORT666 is offline   Reply With Quote
Old 07-13-2012, 11:43 AM   #3649
Benere
Benere's Avatar
Oddometer: 4
Have just gotten through this entire thread, have to admit I had to skim a few pages.
But some Great Information in here.
Really Really want one know.
Benere is offline   Reply With Quote
Old 07-22-2012, 03:13 AM   #3650
mattias se
1975mandel
Oddometer: 24
great bike
hello
tenere is a great bike
my youtube is proving that 75mandel http://www.youtube.com/user/75mandel...e=mheesmTD4Ace
http://www.youtube.com/watch?v=XrqH5...5&feature=plcp
http://www.youtube.com/watch?v=RTG03...feature=relmfu
mattias se is offline   Reply With Quote
Old 07-22-2012, 03:33 AM   #3651
mattias se
1975mandel
Oddometer: 24
some photos
http://www.youtube.com/watch?v=3VXPVNX80uw
from sweden at Adventurdays 2012
Old 09-07-2012, 04:10 AM   #3652
OzRob
OzRob's Avatar
Oddometer: 674
Rear brake disk runout
Hi all,
has anyone had any issues with premature rear brake pad wear?, I am lucky to get 6000km, and the rear disk is warm after riding 80 km without touching the rear brake pedal.
The wheel spins freely up on the centre stand ( hot and cold) , however I have noticed that the rear calliper moves a little on the slider pins with the bike in gear and the engine running.
I marked the disk with a marking pen when it is rotating and you can clearly see the disk is warped.
I lubricated the calliper pins with calliper pin grease when I fitted new pads but I have the same issue.
So I thought I had warped the disk somehow....so I fitted a new disk from EBC, and the calliper still has movement approximately 1 to 2 mm, longitudinally along the pins.
Perhaps the hub that the disk bolts on to is not quite 100% true thus this is seen in the movement of the disk.
The bearings are OK.
Can someone out there who has a centre stand, start the bike and select 1st gear then check if their rear calliper is doing the same?
OzRob is offline   Reply With Quote
Old 09-23-2012, 05:47 PM   #3653
Rafael Martins
Oddometer: 23
Originally Posted by Salami View Post
I don't know if your bike is still new, but if so this is something your dealer should fix for you I think
But a short circuit seems pretty likely too me, you can check the high/low beam switch and wiring very easy, this is a good place to start. There is also the well know connector/ regulator issue, but in that case the high/low beam should not make any difference I guess
Hi!
I finally discover the problem few weeks ago.
The stupid mechanic put the Givi crash bars seizing the loom, so there were few short circuit and afected the ECU. The store payd me a new loom and ECU and now everything is fine!
Rafael Martins is offline   Reply With Quote
Old 10-04-2012, 04:03 AM   #3654
Ni3ous
Double Axle Rider
Ni3ous's Avatar
Oddometer: 221
If someone is in search for front suspension:
http://www.ebay.com/itm/290784755156...S:1123&vxp=mtr
Tènèrè Spirit
Old 10-08-2012, 02:32 AM   #3655
FLICKIT
FLICKIT's Avatar
Oddometer: 881
Has anyone used the Off-The-Road OTR pannier racks? ... If so, what do you think of them?
http://www.off-the-road.de/XT-660-Z-...-Z-Tenere.html
They look quite good for the money...
Also... Does anyone know if they're fit on with Akrapovic mufflers?
FLICKIT is offline   Reply With Quote
Old 12-03-2012, 11:14 AM   #3656
mattias se
1975mandel
Oddometer: 24
touratech mudguards ?
http://shop.touratech.se/viewimage.p...e=View%2Bimage
Old 12-03-2012, 12:05 PM   #3657
macrae85
Oddometer: 391
Originally Posted by zakidos View Post
New week, new mods ;-)
I "upgraded" my cockpit to this:
So I can listen to music on my iPhone 4, the GPS is showing me where I'm heading to and the Spot Messenger is tracking my way and could be useful in an emergency. I'm not quite sure how to handle the emergency thing in case I couldn't reach the bike any more... But primarly I'm using the Spot as a tracking device.
Ahh, and I got the Metal Mule radiador shield! So, now I'm hopping on and going for a ride.
Cheers!
SPOT! Supposed to be at least 12" away from all other GPS equipment......not be better on your person
incase the bike goes over a ravine?
macrae85 is offline   Reply With Quote
Old 01-15-2013, 02:19 PM   #3658
TZOX
Oddometer: 5
Hi guys! 3 months ago I bought a Ténéré XT660Z 2008th I have a problem with oil in the airbox. I ordered a new type of breather. I was a little odd that after a 100 km ride I drop 0.2/lit. oil from airbox.to very much! This was happening to me when I was at an authorized dealer replace the oil Yamalube 4 10W40 fully synthetic FS. Which oil do you use? Thanks for your answers!
TZOX is offline   Reply With Quote
Old 01-15-2013, 02:23 PM   #3659
hb7
moto-science
hb7's Avatar
Oddometer: 308
Either overfilled or extended high speed operation, spits oil in the oil box. Usually harmless on the 660.
.2 Liter ? is too much oil , if you are correct.
hb7 is offline   Reply With Quote
Old 01-16-2013, 03:53 AM   #3660
TZOX
Oddometer: 5
Not overfilled.
Which oil do you use? Synthetic or mineral?
Times are GMT -7.   It's 03:53 PM.
