Old 09-26-2007, 10:32 AM   #1
Burtonridr OP
Wanderlost
Burtonridr's Avatar
Oddometer: 3,739
The XT350 thread
Use this thread to ask questions,share tips, share good links, photos & stories about yamaha's great little XT350.
Bike Specifications for quick reference:
Displacement:346.00 ccm (21.11 cubic inches)
Engine type:Single cylinder
Stroke:4
Carburetor:
24mm Teikei
Power:27.00 HP (19.7 kW)) @ 8000 RPM
Compression:9.0:1
Bore x stroke:86.0 x 59.6 mm (3.4 x 2.3 inches)
Valves per cylinder:4
Fuel control:DOHC
Cooling system:Air
Gearbox:6-speed
Transmission type
final drive:
Chain
Physical measures
Weight incl. oil, gas, etc:150.0 kg (330.7 pounds)
Dry Weight:
262 pounds
Overall Height:
88.2"
Overall Width:
34.1"
Overall Length:
47.6"
Ground Clearance:
10.8"
Wheel Base:
55.9"
Seat Height:
33.7"
Chassis and dimensions
Front Fork
Telescopic forks w/ 10" of travel
Rear Shock
Single Rear Shock w/ 8.6" of travel
Front tyre dimensions:3.00-21
Rear tyre dimensions:110/80-18
Front brakes:Single disc
Rear brakes:Expanding brake
Speed and acceleration
Top speed:135.0 km/h (83.9 mph)
Other specifications
Fuel capacity:12.00 litres (3.17 gallons)
Have beer, will fly
"This forum requires that you wait 30 seconds between posts. Please try again in 1 seconds."
Burtonridr screwed with this post 12-19-2008 at 10:37 AM
Burtonridr is offline   Reply With Quote
Old 09-26-2007, 10:34 AM   #2
Burtonridr OP
Wanderlost
Burtonridr's Avatar
Oddometer: 3,739
Here are a few websites with some good mods and tips
http://www.geocities.com/xt350pilot/
http://www.pbase.com/corky1/xt_350_project_bike
Have beer, will fly
Old 09-26-2007, 10:49 AM   #3
Burtonridr OP
Wanderlost
Burtonridr's Avatar
Oddometer: 3,739
For a rear rack try
http://www.cycleracks.com/
For a clarke 4 gallon gas tank try
http://www.justgastanks.com/makers.php?type=1
For moose guards, protaper handle bars, bar risers, heated grips, luggage, etc try
http://www.happy-trail.com/
Have beer, will fly
Old 09-26-2007, 12:10 PM   #4
Truckin_Thumper
low profile
Truckin_Thumper's Avatar
Oddometer: 28,890
Corky has some decent info, but nothing like what is needed, seems these XT's are getting more poplular.
Saw one go on fleabay for a hair over 2500.00 2000, 2000 miles, it was a nice specimen. Oh, this was just a day or two ago.
I can help out a bit, I have wrenched enough on mine to help others out.
For a good daigram and part numbers, start here
http://www.xtremepowersports.com/OEM...oem_parts.html
Mine. '99 all stcok, runs like a champ and 8300 miles
gimmie the button!
Truckin_Thumper is offline   Reply With Quote
Old 09-26-2007, 12:17 PM   #5
Burtonridr OP
Wanderlost
Burtonridr's Avatar
Oddometer: 3,739
Truckin, you know of a way to protect a saddle bag across the rear of the bike from the muffler?
Have beer, will fly
Old 09-26-2007, 05:01 PM   #6
Truckin_Thumper
low profile
Oddometer: 28,890
You'll have to make yer own frame, make room for an aluminum heat shield.
Thats the only way.
gimmie the button!
Old 09-27-2007, 06:38 AM   #7
Burtonridr OP
Wanderlost
Burtonridr's Avatar
Oddometer: 3,739
Thats the only way.
Thats what I figured... the xt225 stuff doesnt work on ours huh?
Anyone know how to make the thing easier to kick start?
Mine is an absolute bear to start. Maybe its just me, maybe it will just take time to get used to its quirks. But it also seems like it is lacking fuel when cruising at about 4k rpm. Im gonna pull the spark plug tonight and see what the crystal ball tells me.
Anyone know if the electrical system can handle heated grips?
Anyone know how to re-wrap the generator to put out more watts?
Is the thing I read true, does the xt350 generator put out around 28v and/or cause problems with the electrical system?
Have beer, will fly
Old 09-27-2007, 06:40 AM   #8
Burtonridr OP
Wanderlost
Burtonridr's Avatar
Oddometer: 3,739
Is it normal for the headlight to flash with the turn signal? It seems like its because of lack of watts or something?
Have beer, will fly
Old 09-27-2007, 09:15 AM   #9
Fauster
BACON AKBAR!
Fauster's Avatar
Oddometer: 476
Ahhhh, my first DS, first thumper, first....bike!
Mine was a '94 and I put 5000 trouble-free miles on 'er.
My experience with the charging system was that it was anemic. The headlight would dim at idle. And starting could be a real bear. Surprisingly, it was most finicky when it was warm (not hot). It needed just the right amount of choke or else I would kick start myself into exhaustion.
Still....good memories.
I like bananas 'cause they ain't got bones!
PA ADVrider Relay Rider
Fauster is offline   Reply With Quote
Old 09-27-2007, 09:58 AM   #10
Truckin_Thumper
low profile
Oddometer: 28,890
Plugs
Airbox and Clean the carb (use ALOT of SeaFoam)
BTW, anyone got a SuperTrapp or similar they wanna sell?
gimmie the button!
Old 09-27-2007, 09:59 AM   #11
Burtonridr OP
Wanderlost
Burtonridr's Avatar
Oddometer: 3,739
Found a few more good resources,
http://www.imbris.net/%7Etoadie/
Roberts XT350 site
http://www.imbris.net/%7Etoadie/XT350mods.htm
Has links to download shop manuals (clymer manual)and parts lists, as well as other usful carb, chain, sproket, etc info
http://xt350.ve7lyd.com/
Edit 12-9-08: those links above are broken.... I have a full electronic copy of the clymer manual if anyone wants one, shoot me a PM.
Have beer, will fly
Burtonridr screwed with this post 12-09-2008 at 09:23 PM
Old 09-27-2007, 10:07 AM   #12
Burtonridr OP
Wanderlost
Burtonridr's Avatar
Oddometer: 3,739
so does anyone know if the electrical system can handle heated grips? They would be soooo nice in a month or two
Have beer, will fly
Old 01-30-2008, 05:06 AM   #13
R'oli
Oddometer: 204
I am looking for a Suzuki DR 350, but can not find one, how does the XT 350 compare..?
R'oli is offline   Reply With Quote
Old 01-30-2008, 05:45 AM   #14
Jeff@TheQuadShop
TAT survivor
Jeff@TheQuadShop's Avatar
Oddometer: 4,865
The XT350 is a nice bike but the DR is better. Better suspension, better power, later models came with e-start, more aftermarket support....
1998 RMX 250 singletrack bike
1999 DR350SEX Dual Sport bike
1996 XR600R adventure bike
KY state Vet A offroad champion
TAT, KAT and TWVT survivor
Jeff@TheQuadShop is online now   Reply With Quote
Old 02-02-2008, 07:53 PM   #15
TheRiderman
TheRiderman's Avatar
Oddometer: 24
I just bought my XT350 today. It is really fun. I have never rode any other bikes, but the 350 is just fun. I have not had it much out of 2nd gear on my farm but it has alot of power.
Heres a pic.
TheRiderman is offline   Reply With Quote
Times are GMT -7.   It's 07:14 PM.
