Old 08-25-2010, 01:45 PM   #1516
xt4ever
xt4ever's Avatar
Oddometer: 80
Originally Posted by SkidMarx
Buy a new one. About $16. My dealer had them in stock. I suspect they're common to several bikes.
Yes, they are. For instance, the DT125 uses the same
HTH
-JL
xt4ever is offline   Reply With Quote
Old 08-26-2010, 03:25 PM   #1517
truck6driver
The Fireman
Oddometer: 7,449
So what year YZ125 forks fit the steering head on the XT. My first ride with my son on the XT confirms what you guys say, the forks really need attention . Instead of rebuilding them I might just convert them.
Ray
When the system fails you, what then?? Do you fight it or just surrender and give up? If all seems doomed what is left to fight for? Is it just me or does the world seem to close in on you when you seem to be making ground? Options are dwindling down, what comes next? And in the words of Pink Floyd "Is there anybody out there". All I know is I WILL SURVIVE.
truck6driver is offline   Reply With Quote
Old 08-26-2010, 03:32 PM   #1518
Aivasovsky
Aivasovsky's Avatar
Oddometer: 155
Hi mate!
The space under the tank was really much more than i thought.
You can use it freely.
I also have changed my flasher bulbs to 21watt automotive bulbs.
and used standard automobile flasher relay for them.
XT350 had an electronic relay and i had problems for different bulbs as well.
If the standart automotive relay doesnt work properly due to lower total power of bulbs, you can add an electronic resistor in series to the wiring
after or before the relay.
Best wishes,
SKY
Originally Posted by xt4ever
Good job, SKY. Does the box fit without issues with the fuel tank? Just wondering
You seems to have good knowledge about electrical systems, so I will ask a question: what flasher relay will work well for leds or for 10w bulbs? I changed my flasher lights, but they don't flash with 10w bulbs, I need to replace the bulbs with 21w ones (stock ones), but they burn the plastic very often. I would like to mount 10w bulbs to fix the issue completely
Regards
-JL
2003 KTM 640 LC4e 18000km (High Flow top)
1993 Yamaha XT350 40000km
Rebuilding XT350 project pics:
http://s263.photobucket.com/albums/i...350/?start=all
Aivasovsky is offline   Reply With Quote
Old 08-26-2010, 04:22 PM   #1519
truck6driver
The Fireman
Oddometer: 7,449
Poor Bastard
Well the young guy, that I traded the XR600R to get the XT350, did not take my warning about the power of the 600 seriously.
His mother just e-mailed me and said he is in the hospitial getting surgery on his leg and knee. Seems that the bike did not like the way he rode. He had never ridden anything but the XT350, so, why is it when someone, that has experence on a bike, warns someone about the dangers of the bike, that they think they know better?
She made it seem like it was my fault that he wrecked because I traded the bike to him. He is 19 years old, not my fault right?
I hate it for him but I guess he knew better.
Ray
Old 08-26-2010, 05:19 PM   #1520
Zecatfish
XTique Rider
Zecatfish's Avatar
Oddometer: 7,927
Ray
Caveat Emptor
He is 19 years old and most likely thinks his first cousin is Superman.
No reason for you to be blamed, he was the one that did it.
As the Honda sticker goes.
My kids had these on all their bikes.
I used it alot when they screwed up.
Google Earth GPS Howto (still a work in progress) use USGS TOPO Maps to layout trails.
http://home.windstream.net/catfish/GPS
The Early Bird gets the worm, but the second mouse gets the cheese.
https://sites.google.com/site/ozarkadventuretours/
Zecatfish is offline   Reply With Quote
Old 08-27-2010, 05:17 AM   #1521
xt4ever
xt4ever's Avatar
Oddometer: 80
Old 08-27-2010, 07:10 AM   #1522
Grreatdog
Grreatdog's Avatar
Oddometer: 11,413
Ray
Obviously you are a bad, bad man.
I hope you have better luck with XT350.
525EXC, 640 Enduro, XT200
Grreatdog is online now   Reply With Quote
Old 08-27-2010, 07:35 AM   #1523
truck6driver
The Fireman
Oddometer: 7,449
Yea me too!
Ray
Old 08-27-2010, 09:37 AM   #1524
ventura guy
Oddometer: 1
Relay
I was having a lot of trouble with my stock relay. I switched to this one:
Tridon/Hazard Warning Flasher
Part Number:
EL12
Its sold off the shelf at most Autozones for $9.99. I did not have to modify anything with stock bulbs or connectors. Plug n play!
Originally Posted by Aivasovsky
Hi mate!
Best wishes,
SKY
ventura guy is offline   Reply With Quote
Old 08-27-2010, 01:26 PM   #1525
BHW
BHW's Avatar
Oddometer: 4,128
I've found a great deal on a set of xt 350 wheels. They rims are the exact same model and size as is on my XR650L. Does anyone know what size axles the XT350 uses? I'm kinda hoping to be able to use these as a 2nd set on the Honda without major modification.
2003 Aprilia Tuono
Alcohol, Tobacco and Firearms should be a convenience store, not a government agency!
BHW is offline   Reply With Quote
Old 08-28-2010, 10:44 AM   #1526
truck6driver
The Fireman
Oddometer: 7,449
Yea I saw them too. I would be worried about the rotor and sprocket placement. If you want you can ride the XR down here one evening and put the bikes side by side and wrench away to see if it will work. PM if interested.
OR
You could just buy them and if they don't work I will make sure they find a good home and will not charge you disposal fees.
On a serious note I have an XRL front rim with rotor you can buy. Needs to be trued a bit. I used it as my dirt rim on my old XRL.
Ray
Old 08-28-2010, 11:03 AM   #1527
BHW
BHW's Avatar
Oddometer: 4,128
The guy is out of town, but I'm meeting him Tuesday to look at those wheels. I'll probably just take the wheels off my XRL and take them with me to compare side by side.
2003 Aprilia Tuono
Old 08-28-2010, 02:03 PM   #1528
truck6driver
The Fireman
Oddometer: 7,449
OK offer is still there.
Again......I Still have the XRL front too.
Ray
Old 08-28-2010, 02:07 PM   #1529
BHW
BHW's Avatar
Oddometer: 4,128
PM me your asking price for the XRL front.
2003 Aprilia Tuono
Old 09-01-2010, 06:21 AM   #1530
PCK_4xCustoms
lost
PCK_4xCustoms's Avatar
Oddometer: 260
any suggestions off the top for a new handlebar setup? My new to me '95 has a pair thats a bit tweaked and the Maier hand guards I got for it dont seem to fit right at all.
PCK_4xCustoms is offline   Reply With Quote
Times are GMT -7.   It's 10:02 AM.
