Old 09-01-2010, 08:45 AM   #1531
xt4ever
xt4ever's Avatar
Oddometer: 80
Originally Posted by PCK_4xCustoms
any suggestions off the top for a new handlebar setup? My new to me '95 has a pair thats a bit tweaked and the Maier hand guards I got for it dont seem to fit right at all.
I have this one:
http://www.racing4ever.com/index.php?article=4373
gold color:
and I'm happy with it so far
HTH
-JL
xt4ever is offline   Reply With Quote
Old 09-01-2010, 01:45 PM   #1532
cjm1219
cjm1219's Avatar
Oddometer: 107
Hello all. I have had my XT350 for about a month and have taken it on some short (10-30) mile rides. It has done well, for the most part.
I took it on a longer ride about 100 miles but it didn't make it the last 5 to the house.
I did about 70 miles or nice desert dirt road type stuff and the bike ran great and had no issues. I stopped a few times. It started up fine every time.
The route i took was over the top of a 8500 ft. mountain. At about 6500 ft or so the bike started to run roughly. Some backfiring, inconsistent power. It got worse as i got to the summit of the mnt.
I assumed the carbs aren't tuned right and were being effected by the altitude. I road over the top and back down the other side thinking it would clear up as i got lower. I stopped at about 6000 feet and had a heck of a time getting it to restart. 10 minutes or so of kicking on and off.
I road it the rest of the way backfiring and power surging and just running like crap.
once i got to a stop sign back in town it died and i couldn't get it restarted. had to get a ride back home and came back to get it with my truck.
I haven't dug into it yet to see what might be the problem.
Any ideas? Suggestions what to look for?
I am thinking maybe spark plug. I was going to pull that but it used a different size spark plug socket then everything else i have. Anyone know what size it uses?
Maybe the rubber intake boots are bad. I don't know.
Had a wonderful time on the ride, just a little frustrating toward the end.
cjm1219 screwed with this post 09-01-2010 at 02:12 PM
cjm1219 is offline   Reply With Quote
Old 09-01-2010, 01:52 PM   #1533
xt4ever
xt4ever's Avatar
Oddometer: 80
Originally Posted by cjm1219
Is the air filter clean?
For the spark plug you will want a 18 mm spanner
HTH
-JL
Old 09-01-2010, 02:13 PM   #1534
cjm1219
cjm1219's Avatar
Oddometer: 107
Yeah, Airfilter is a new UNI that i put in when i got the bike. has about 300 miles on it since then
Old 09-01-2010, 02:40 PM   #1535
xt4ever
xt4ever's Avatar
Oddometer: 80
You said you ran about 70 miles of nice desert dirt road, that's enough to block the small filter the XT350 uses. Please, check it. FYI the land where I use to run is literally a desert, and I clean my filter with petroleum every ride. And don't forget to oil it with a good oil for foam air filters. BTW, I use a UNI filter as well
Old 09-01-2010, 03:16 PM   #1536
truck6driver
The Fireman
Oddometer: 7,435
I had the XR650L give me fits at higher altitudes. I found that when I got high that I had to pull off the air box cover to get more air to the carb. When I came back down just put it back on and all was well. Bike idled high above 5000ft too.
Ray
When the system fails you, what then?? Do you fight it or just surrender and give up? If all seems doomed what is left to fight for? Is it just me or does the world seem to close in on you when you seem to be making ground? Options are dwindling down, what comes next? And in the words of Pink Floyd "Is there anybody out there". All I know is I WILL SURVIVE.
truck6driver is offline   Reply With Quote
Old 09-02-2010, 08:17 AM   #1537
Aivasovsky
Aivasovsky's Avatar
Oddometer: 155
Hi Mates!
I started hearing some humming noise at the 6th gear, when accelerating.
Checked old pics of my gears and saw that my 6th gears
has rough surfaces on teeth.
I wonder if i should be concerned seriously about this.
Will they make noise only or will cause more complicated problems immediately?
Best wishes,
SKY
2003 KTM 640 LC4e 18000km (High Flow top)
1993 Yamaha XT350 40000km
Rebuilding XT350 project pics:
http://s263.photobucket.com/albums/i...350/?start=all
Aivasovsky is offline   Reply With Quote
Old 09-02-2010, 04:54 PM   #1538
Psycho18th
Oddometer: 397
I like the Tusk Aluminimbars sold by Rocky Mountain ATV/MC. I use the KX high bend. $28 a piece. Best bang for the buck in my opinion.
They also sell Tusk branded aluminum handguards that work like a champ for $30. I then add a set of MSR or Cycra plastic sheilds to them.
Psycho
02 DRZ400E Dualsported in AZ
14 KTM 250 XCW (Plated in AZ)
85 HON XL80S (Wife's ride)
00 and '07 YAM TTR 90s (kids' bikes)
89 Lockheed F-16C (Work vehicle )
Psycho18th is offline   Reply With Quote
Old 09-02-2010, 05:01 PM   #1539
Psycho18th
Oddometer: 397
I ran my '93 XT up above timberline and back in CO all the time, and never had a problem once I got back down to lower elevations. My only guesses that would be caused by an altitude change would be that it was running rich enough when you were up high to partially foul the plug, and it never cleared completely, or that the fuel tank vented out on the acsent, but not back in on the descent, and it somehow vapor locked. Did it start if you removed the fuel tank cap? Otherwsie, I would think the problem is not related to the altitude change.
Psycho
Old 09-02-2010, 07:32 PM   #1540
Zecatfish
XTique Rider
Zecatfish's Avatar
Oddometer: 7,927
That kind of wear on the teeth looks almost like one of two things.
  1. Its been sitting underwater,
  2. electrolysis
Its toast anyway.
Time to replace the gears.
On a separate note:
Does anyone know where to source a braided stainless brake line?
How about converting the front to a dual piston caliper?
Google Earth GPS Howto (still a work in progress) use USGS TOPO Maps to layout trails.
http://home.windstream.net/catfish/GPS
The Early Bird gets the worm, but the second mouse gets the cheese.
https://sites.google.com/site/ozarkadventuretours/
Zecatfish is offline   Reply With Quote
Old 09-03-2010, 06:51 AM   #1541
kimber45
I'm over it.
kimber45's Avatar
Oddometer: 781
Originally Posted by Zecatfish
On a separate note:
i've seen these guys mentioned. no personal experience though.
kimber45 is offline   Reply With Quote
Old 09-03-2010, 09:29 AM   #1542
SkidMarx
SkidMarx's Avatar
Oddometer: 2,036
All Bike Brakes has the lines.
'90 XT350
'08 WR250R
GLDS
SkidMarx is offline   Reply With Quote
Old 09-03-2010, 04:29 PM   #1543
raptortrail
raptortrail's Avatar
Oddometer: 188
Thumb Spark plug
Change your spark plug,at high altitude your are running very rich and could easily foul the plug
raptortrail is offline   Reply With Quote
Old 09-03-2010, 05:18 PM   #1544
raptortrail
Oddometer: 188
Question
Originally Posted by Aivasovsky
Hi Mates!
Best wishes,
SKY
I have a complete transmission for the XT in good condition if you are interested,but do not know how much the shipping would be fron US.
Old 09-04-2010, 09:53 AM   #1545
cjm1219
cjm1219's Avatar
Oddometer: 107
Thanks for the responces.
I cleaned, oiled and replaced air filter. Was dirtier than i expected.
Put in a new spark plug. Still not getting anything. Not even a cough. Looks like i am getting spark, but maybe not getting any gas in the cylnder? All my mechanical skill have come from experimenting and reading the internet, so they aren't great.
What is the spark plug gap? I read on another thread .7-.8. Is this correct.
Anyother ideas before i take it to a pro.
Times are GMT -7.   It's 09:46 PM.
