Old 09-15-2010, 08:26 PM   #1591
Banfius
Oddometer: 12
Anyone ever find a rear shock from another bike that would bolt up? I know nails1 was testing some out a few posts back.
Banfius is offline   Reply With Quote
Old 09-16-2010, 12:50 AM   #1592
Renxx
Moto maniac
Renxx's Avatar
Oddometer: 19
91 TT350 in mx race:
Renxx is offline   Reply With Quote
Old 09-16-2010, 06:01 AM   #1593
condor-machinist
el dirt hombre
condor-machinist's Avatar
Oddometer: 105
Mud=Fun
Great pics, looks like a blast.
Santa Barbara/Goleta, CA
condor-machinist is offline   Reply With Quote
Old 09-16-2010, 06:36 AM   #1594
nails1
nails1
Oddometer: 187
Nope, I was just talking. Haven't done anything with my XT (including ride it) all summer -- trying to build a workshop.
At this rate, I'll get back to the XT after I'm dead.
(If it's that hard to find a rear shock, maybe look for a whole swingarm/shock?)
nails1 is offline   Reply With Quote
Old 09-16-2010, 07:09 AM   #1595
Banfius
Oddometer: 12
I ebayed a rear shock off an 86 yz125. I'm guessing it's too long, but I'll report when it comes in.
Old 09-16-2010, 07:18 AM   #1596
SkidMarx
SkidMarx's Avatar
Oddometer: 2,335
That was my thought (which I will never get around to doing).
Pick up a TT350 shock/swing arm/linkage and try that. I'd also need the TT Triple clamp so I could fit a better set of forks in it.
Not that I want to discourage anyone from trying, but I abandoned the idea. By the time I buy the parts and spend who knows how much time on it I'd still have a 20 year old bike with mediocre suspension. Also, the lack of any kind of lower frame concerns me. Better suspension might be able to take a bigger hit, but can the frame? I don't plan on ever selling my XT, but I think I'd be better off dumping money into a more modern bike that I can get aftermarket parts for.
Now if someone found a shock that would fit in the stock setup(with a few mods) that was better or at least rebuild-able, I'd be all over that.
'90 XT350
'08 WR250R
GLDS
SkidMarx is offline   Reply With Quote
Old 09-16-2010, 07:53 AM   #1597
nails1
nails1
Oddometer: 187
I suspect that we may be able to do better than TT parts.
Old 09-16-2010, 02:22 PM   #1598
xt4ever
xt4ever's Avatar
Oddometer: 80
Can't remember where, but I remember very well someone told a XT600 rear shock fits in the XT350 frame; it was a little bit longer, but it fits. There is some recent movement in eBay as well about rear shocks for the XT350; expensive, but there is something.
BTW, I just received my pair of Wilbers progresive springs for the front suspension. I will report how it does when I had a chance to mount it.
-JL
xt4ever is offline   Reply With Quote
Old 09-16-2010, 02:34 PM   #1599
Renxx
Moto maniac
Renxx's Avatar
Oddometer: 19
look here: http://xt350.de/rahmen.php?seite=artikel/federbein
Old 09-16-2010, 02:37 PM   #1600
xt4ever
xt4ever's Avatar
Oddometer: 80
Originally Posted by Renxx
Exactly!
Old 09-16-2010, 04:10 PM   #1601
truck6driver
The Fireman
Oddometer: 7,566
So the XT600 rear will fit the XT350 Thats something to look into. I see a difference in the spring. Wonder if the shock/valving is different?
I wish I could read German. I could make out a few words, just enough to get an idea of what he did just not the details. But it seems he used an XT600 shock and the 350 link. I think anyway.
Ray
Life has F@#ked with the wrong man. I will come out on top. Just watch.
truck6driver screwed with this post 09-17-2010 at 06:24 AM
truck6driver is offline   Reply With Quote
Old 09-16-2010, 06:31 PM   #1602
Tinner
Oddometer: 325
Originally Posted by spokexx
where does that go???
Darned if I know...lol
Still waiting for parts that I have ordered. But I did buy it as a winter project. Hoping to have it done in time to ride some ice.
Ride em if you got em!
Tinner is offline   Reply With Quote
Old 09-16-2010, 07:38 PM   #1603
spokexx
boob
spokexx's Avatar
Oddometer: 90
fork spacer length
So i want to add more preload to my forks (stock springs), what is the maximum safe length I can make a spacer to fit in there? Too long and the springs will fully compress and i could lose travel, right?
giddy up!!
spokexx is offline   Reply With Quote
Old 09-18-2010, 12:22 PM   #1604
Banfius
Oddometer: 12
Compression Test
When you test the compression on the XT, should the decompression cable be disconnected from the kick start?
I ran the test exactly as described in Clymer. My results were way below what Clymer suggests are appropriate, but I'm using the kickstart to turn the engine so the decompression is opening up. The numbers could be adjusted for this consideration, in which case I have a valve seal problem.
My pressure hit around 90psi. Clymer says 128psi minimum and should be closer to 150psi I think.
Old 09-18-2010, 03:55 PM   #1605
cjm1219
cjm1219's Avatar
Oddometer: 107
Very unlikely anyone will stock the boots. Just order them.
It could have been a stuck float or if the boots were leaking bad enough you may not have had enough vacuum the suck the gas out of the bowl.
A good clean carb, new boots and air filter and you should be all set.
I would suggest buying some new fuel line and vent hose as they are also likely dry rotted and won't last very long. Get twice as much as you think you need. It never seems to go as far as you think. A piece of vent line will work for the piece that came apart that goes between carbs.
Sounds like the bike is due for a good going through.
Cleaned the carb the best i could. Put on the new boots and it fired right up
Now i got a slight fuel leak out of the bowl on the carb. I must not have tighened the screws down enough. Is there supose to be a gasket of some sort there?
cjm1219 is offline   Reply With Quote
Times are GMT -7.   It's 12:14 PM.
