09-19-2008, 04:53 AM
#151 |
boob
Oddometer: 84
if i were to drill out my secondary main to a 120, what drill bit size would i use?
09-19-2008, 05:01 AM
#152 | |
thumper tourer
09-19-2008, 06:06 AM
#153 |
boob
Oddometer: 84
wow!!! it doesnt take much to go from 112-115 to over 120 with a slightly larger drill bit. Just a hair. Thank you.
09-19-2008, 06:28 AM
#154 | |
thumper tourer
09-19-2008, 08:45 AM
#155 |
nails1
Oddometer: 185
Drilling is a charming notion, but you probably won't find the right sizes.
I've heard of taking the jet to a jeweler to put on his lathe. For me, it was easier to go through my pile of old jets and put two old jets together: tap and screw one with the right insides into one with the right outsides, then make it all right with solder. As I recall, the outside threads should be 8 X 1mm. I think the height of the jet matters for this carburator. |
09-20-2008, 12:14 PM
#156 |
Have Fun, Don't Die!
Oddometer: 1,835
My Submarine!
Here's a picture of my little mule before a ride last week...sure wasn't that clean when I got home! Got a little too brave and tried to cross a section of trail with knee high swamp and dropped her! Completely sub-merged! Took 20-30 minutes to get her running agian! Had to empty/clean airbox, full of mud and water...drain bowl twice...dry spark plug...kick about a hundred times and she finally fire up!!! Spit water for a coupla minutes but kept on thumping!!!
09-20-2008, 12:23 PM
#157 |
thumper tourer
Looks nice
The road becomes my bride, and the Earth becomes my throne... '85 Moto Guzzi V65 TT (never heard of it?) '93 Yamaha XT 350 Touroduro (sold & missed) |
09-22-2008, 08:45 AM
#158 | |
Oddometer: 97
It is a lot easier to die, then it is to use your head. R.A. Heinlein KLR650 '09 |
09-22-2008, 09:29 AM
#159 | |
Oddometer: 5,631
BTW, looks good in blue. I like that better than my old red bike.
KTM 640 LC4E KTM 200 MXC XT200 |
09-22-2008, 04:10 PM
#160 |
Oddometer: 3,315
Won't start
My previously reliable XT350 won't start. It's been sitting for about 3 months. I charged up the battery and kicked to no avail. I sprayed some starter fluid in and it started but failed to run. After about six if these episodes I am at a loss. I feel sure its a fuel problem. Any ideas ?
It was starting and running great the last times I used it.
If I wasn't here, I'd be somewhere else |
09-22-2008, 07:14 PM
#161 | |
Oddometer: 1,835
Tank bags
Cheap too, like 25 bucks I think i paid...bought them hear: http://www.shopprocycle.us/productde...cts=tank%20bag They have a coupla differnet types. |
09-23-2008, 04:57 AM
#162 | |
boob
Oddometer: 84
09-23-2008, 08:06 AM
#163 |
Oddometer: 5,631
I agree with the last post. But mine also had a strange issue from day one that lasted the whole 17 years that I owned it. Anytime it sat for a while I had to turn the fuel tap off, drain the primary carb float bowl and then turn the fuel tap back on.
If you didn't do that you could kick it a 1000 times and it would not start. Drain the float bowl and it would start second or third kick. The long time mechanic that worked on the bike never figured that one out. It just was. But you might want to try it before taking it apart. And DO NOT BEND THE FLOAT OUT OF ADJUSTMENT when you pull the float bowl off. There is a rubber hose on the back of the float bowl that needs to come off first so the bowl will drop straight down. If you bend the float out of adjustment you be hating life and fabbing a Yamatool to readjust it.
KTM 640 LC4E KTM 200 MXC XT200 Grreatdog screwed with this post 09-23-2008 at 08:16 AM |
09-24-2008, 08:39 AM
#164 |
boob
Oddometer: 84
well, i rode my xt350 to work this morning. First time since i bought it and put it on a diet and tweaked the carbs. Wow!! im impressed. It had great bottom end to mid pull, which will be perfect in the woods and trails. It feels much different than my xt550, more.... upright. Im sure it has a steeper fork angle. My 550 feels a bit more relaxed and long.
I put a 128 jet in the primary side, and had the secondary drilled out a bit larger. I dont know what size, my mechanic did it for me and i forgot to note what size bit he used. I also put in a 48 pilot jet, i didnt even need the choke to start it nor did i have to feather the throttle. It was ready to rip right away. I also have a Uni filter in it and a Cobra exhaust. I still have to swap on the knobbies, but ill enjoy motarding the roads around here for a few days. Ill get pics up soon. |
09-27-2008, 05:04 PM
#165 |
BCgser
Oddometer: 6
XT350 does not like to cruise downhill
After reading this enthusiastic thread on the XT350, I have new appreciation for my 1984 XT350. BUT now I have a carburator problem. It was running fine for a few years, but recently floods out when coasting downhill. Uphill and flat is no problem. If I sit for a couple of minutes, the carburator is fine again. I am guessing I need a float adjustment, I checked float height with a clear plastic tube attached to the bottom of the float chamber and visually aligning with the float chamber, but this was very rough measurment. I was told to take the carbs off and visually check the floats by turning the carb upside down and sighting along the top of the float chamber. Clymer manual shows a coaster enrichment diaphram which is rubber and visually it looks OK. I have tried carb cleaning and fresh gas, and this has helped the problem, but not cured it. Anyone solve this problem before on their XT350 ? No carb kits available, just make a guess order the next expensive part and wait a week.
