Old 11-19-2010, 01:36 PM   #1696
Stagehand
Imperfectionist
Stagehand's Avatar
Oddometer: 26,994
it has gas, right? not that I'VE Ever run out of gas before
Seriously, need more info. Did you do any work at all to it, recently? Check all the obvious stuff... fuel petcocks on, sparkplug wire seems like its on, kill switch... try it in neutral with clutch in... fuel hoses look ok.... drain the fuel in the bowl, maybe its got a little water, umm.... obvious stuff first. THEN replace the crankshaft
Sometimes I need to hold the throttle WFO while kicking.
Unintentional psychokinesis.
Stagehand is offline   Reply With Quote
Old 11-19-2010, 02:59 PM   #1697
PCK_4xCustoms
lost
PCK_4xCustoms's Avatar
Oddometer: 267
half tank of fuel, tried fuel petcock on res and standard on, WFO and closed, kickstand up clutch in neutral, choke on and off and in between.
It ran fine as I rode it into town to go to class for the day, then when I went to leave it just wouldn't go.
Haven't done any work on it besides a cam chain tensioner in june.
PCK_4xCustoms is offline   Reply With Quote
Old 11-22-2010, 06:38 AM   #1698
SkidMarx
SkidMarx's Avatar
Oddometer: 2,274
Intake boots leaking?
I don't remember if you said you replaced them or not.
'90 XT350
'08 WR250R
GLDS
SkidMarx is offline   Reply With Quote
Old 11-22-2010, 10:14 AM   #1699
anarxias
Oddometer: 12
sprockets
Hello guys
I want to know in which way should a sprocket be installed.For example should the stamp that indicates the model or the number of tooth of the sprocket be facing the side of the bike or the other side.
Thank you
anarxias is offline   Reply With Quote
Old 11-22-2010, 10:24 AM   #1700
Stagehand
Imperfectionist
Stagehand's Avatar
Oddometer: 26,994
Originally Posted by anarxias
Hello guys
Thank you
Front sprocket you mean? I would guess it would be installed such that you can see the stamped number.
Old 11-22-2010, 10:30 AM   #1701
Stagehand
Imperfectionist
Stagehand's Avatar
Oddometer: 26,994
OK. After making sure the kill switch is not accidentally hit, turn on the key and unless its my bike, you should see headlights and idiot lights. Yes?
Then: Fuel, spark, compression. I'd check em in that order.
Drain the bowl, make sure there's juice in there. If there is sufficient gas coming out of the drain tube, (as in, with the petcock open, it does not stop coming out) I would proceed to check out if there is Spark.
I bet you will find out one or the other is somehow gefuct, and it could easily be a spark plug cap worked loose, or something. Check the float bowl and work backwards up to the tank if its wrong, then check the plug and work backwards to the wires and then the coil.
Old 11-22-2010, 11:00 AM   #1702
Grreatdog
Grreatdog's Avatar
Oddometer: 12,026
No headlight on my old 1986 XT350 unless it was running. Maybe later years were different, but on mine turning on the key only gave you a tail light and idiot lights.
525EXC, 640 Enduro, XT200
Grreatdog is offline   Reply With Quote
Old 11-22-2010, 11:01 AM   #1703
Stagehand
Imperfectionist
Stagehand's Avatar
Oddometer: 26,994
I've got a '91 and had a '96. It has been almost that long since I've had a working battery, though, so I am not sure I was pretty sure the battery kept it lit when on, otherwise at idle your headlight would dim to almost nothing :lol ask me how I know.
Old 11-22-2010, 11:08 AM   #1704
FlatlanderInVT
FlatlanderInVT's Avatar
Oddometer: 203
The headlight on my '90 is not on until the bike is on, and it in fact does dim quite a bit at idle. Not sure what the state of the battery is, but the neutral light works fine with just the key on, and all signals, etc work fine, it even powers my heated vest just fine.
FlatlanderInVT is offline   Reply With Quote
Old 11-22-2010, 12:52 PM   #1705
Zecatfish
XTique Rider
Zecatfish's Avatar
Oddometer: 7,927
Tail light, and neutral light are the only ones that work off the battery.
The headlight is stator powered.
You know your idle is set to low if the headlight is to dim at idle.
Google Earth GPS Howto (still a work in progress) use USGS TOPO Maps to layout trails.
http://home.windstream.net/catfish/GPS
The Early Bird gets the worm, but the second mouse gets the cheese.
https://sites.google.com/site/ozarkadventuretours/
Zecatfish is offline   Reply With Quote
Old 11-22-2010, 01:41 PM   #1706
PCK_4xCustoms
lost
Oddometer: 267
Stagehand:
I get neutral light and tail light when the key is on yes, no headlight till it runs.
Fuel Comp. and Spark (at least spark from screwdriver jammed into the plug boot. Dont have the socket I need as its MIA)
Good flow from the tank and I cant get the durn drain screw to turn. Matter of fact I cant get the intake boot clam screws to turn either.
I got one backfire when kicking through with no fuel on hoping to just clear the carb.
Skidmarx:
It ran fine earlier, by earlier i mean I rode it into town the day it died and out to trails the day before and it ran fine. But I went to start it to head home and she wouldnt go. Guess I'm just sayin I don't think its the boots due to prior good running.
Old 11-22-2010, 05:22 PM   #1707
Stagehand
Imperfectionist
Stagehand's Avatar
Oddometer: 26,994
cant get the drain screw to turn?.. no telling whats in there.
could be the plug just shit the bed. got to pull it and see if its really got spark.
Old 11-22-2010, 06:54 PM   #1708
Grreatdog
Grreatdog's Avatar
Oddometer: 12,026
I have posted this before, but this is getting to be a long thread so here it is again: mine absolutely would not start after it sat for a while unless I drained the float bowl first. It was weird, almost like the old days of having to tickle the carbs.
But when I say would not start I mean it. And it was almost every time it sat. When it was stolen and recovered it came back with the kickstarter shaft broken off. And I know why. The scumbags never did figure out the trick since it flowed gas and had spark.
When mine wouldn't start it was ALWAYS condensation in the float bowl. Even after I switched to a Clarke tank. But all I had to do was drain the float bowl at the screw and let a little fresh gas flow through. At least try it before you tear her down.
Surely mine wasn't the only one that had such an issue. After that I would check the plug for spark. I once field stripped a DT175 to the frame in a swamp only to discover it was a shorted kill switch. We unplugged it and it fired right up.
In other words do the quick and easy stuff first. Then get serious.
Old 11-24-2010, 09:37 AM   #1709
cjm1219
cjm1219's Avatar
Oddometer: 107
My bike was running fine then not and wouldn't start. New intake boots fixed it. I'm guessing the leaky ones didn't create enough vacuum to pull gas into the motor.
The boots were a lot more expensive than i hoped they would be, but it is all well and good now.
cjm1219 is offline   Reply With Quote
Old 11-24-2010, 11:07 AM   #1710
SkidMarx
SkidMarx's Avatar
Oddometer: 2,274
"Get new intake boots" is my stock answer to all XT350 woes.
Won't start? "Get new intake boots".
Poor idle? "Get new intake boots".
Suspension Sucks? "Get new intake boots".
No Brake Light? "Get new intake boots".
Flat tire? "Get new intake boots"
'90 XT350
'08 WR250R
GLDS
Times are GMT -7.   It's 12:47 AM.
