Old 10-22-2008, 10:13 AM   #226
Grreatdog
Grreatdog's Avatar
Oddometer: 5,938
Originally Posted by SkidMarx
"Something isn't right here." I say to myself while looking at my kickstarter laying on the ground.
Upon inspection I see that the shaft is twisted right off.
It looks like it may have had some cracks for a while. Likely caused by me having to kick the crap out of it befor I got the carbs sorted out.
That is a actually a common problem with older XT350's. Mine did it and I know of several others that did the same thing. They must have had a bad casting for that shaft or else it was underdesigned. The auto-decomp stuff in there is a little tricky. But you are right, the fix isn't that hard.
The good part about mine was it happened to the scumbags that stole it instead of to me and got me the bike back. It was recovered because it had been abandoned in some woods when the kickstarter broken off. So I got a call from the state police one day saying they recovered my bike after it had been gone for a year.
But, since I was still in the process of sicking the state Attorney General's office on State Farm over the claim, I still had the title. So State Farm let me have it back despite being totalled because I had been such a naughty boy and reported them for lying to me. I just had to sign a waiver against further claims and they paid me the total loss value.
KTM 640 LC4E
KTM 200 MXC
XT200
Grreatdog screwed with this post 10-22-2008 at 10:22 AM
Grreatdog is offline   Reply With Quote
Old 10-22-2008, 11:18 AM   #227
SkidMarx
SkidMarx's Avatar
Oddometer: 1,342
I shouldn't be suprised.
Many years ago the decomp cable broke and I didn't bother fixing it right away. Combine that with the poor cold starting with its super lean stock jetting and you get a lot of he-man kicking.
I've been so spoiled since I fixed the jetting that it never crossed my mind that a few light kicks could finish off what I started so many years ago.
My season was pretty much over anyway so I'll just fix it this winter when fix the piston slap.
'90 XT350
'08 WR250R
GLDS
NOMADS
SkidMarx is offline   Reply With Quote
Old 10-22-2008, 09:52 PM   #228
tathambenjamin
tathambenjamin's Avatar
Oddometer: 563
Wicked questions for you xt riders.
Hey guys-
So, I have a bike up for sale/trade and have a couple trade offers that could involve XT350's.
One is an '88 and has almost 9k on the clock the other is an '86 and has about 13k. The 9k is completely stock and has slight oil leak from valve cover.....the other looks well sorted and has a couple nice mods. Moose bars, larger sprockets etc. The 9k guy wants a couple hundo more for his bike.....
So, my concern is.......how will this engine hold up? Is the higher mileage bike gonna be due for a top end at any time? Other problems to look out for with the engine or trans in higher mileage examples? Also, is there any aftermarket for these? If I want to buy a spare parts engine are they available? Someone fill me in please, opinions, rants, etc. Thanks
hmmm, one of those guys may frequent this board.....oh well, its all the same I guess. Just looking for an objective opinion.
heres the 13k:
http://mail.google.com/mail/?ui=2&ik...disp=inline&zw
(hopefully that link works)
There he goes. One of God's own prototypes. Some kind of high powered mutant never even considered for mass production. Too weird to live, and too rare to die.
-HST
tathambenjamin is offline   Reply With Quote
Old 10-23-2008, 02:00 AM   #229
jegrmajstr
thumper tourer
jegrmajstr's Avatar
Oddometer: 135
Send a message via MSN to jegrmajstr
Originally Posted by tathambenjamin
Hey guys-
heres the 13k:
I'd say go for the 9k because of the mods and lower mileage, the oil leak is most likely because of a blown gasket, which is simple fix you can do yourself, but you'll need to order the gasket at the dealer's. 13k also isn't a very high mileage, I have more than 25k on my XT 350 and it's still going strong, my dealer checks the valve clearance every year and it's still in factory tolerances, no problems with gears or anything else. The only thing I had to change were the clutch pads.
As I said before in this thread, the parts availability isn't a problem, any Yamaha dealer should be able to provide you with the spare parts, although they might not be on stock so you'll have to order the parts.
And for the aftermarket... If you had read through this tread, you would've found this:
Originally Posted by jegrmajstr
- Suspension:
Wilbers makes both the rear shock and progressive front springs - very good, very expensive.
Wirth has progressive fork springs - also expensive.
- Brakes:
Braking has a front disk - very good and cheaper than the original.
A variety of brake pad manufacturers (Carbone Lorraine, EBC, Saito, Lucas...).
There are stainless steel brake lines available (Lucas), but the cheapest way to get them at a local hydraulics shop - tried and tested :)
- Engine
Wiseco and Wössner sell piston kits (Wiseco also has a high-compression piston)
I'm not sure for cams.
Lucas and EBC make clutch friction pads and springs.
There are also High-Flo (and other manufactorers) oil filters available.
- Exhaust
There are a couple of manufacturers that have exhausts for the XT 350: Supertrapp, Sebring and Marving, but with a bit of DIY you can make any other enduro silencer fit, there's just a connecting pipe to be made.
- Gas tank
Clarke has a plastic tank, but not much bigger than the original.
Acerbis makes tanks for XT 600 and 400, both 20l (perhaps an early '90-'94 XT 600 tank would fit?)
- Carburetor & air intake
I don't know if larger jets are considered aftermarket.
K&N and UNI make air filters.
- Drivetrain
There are chain sets available by DID and Regina, and also sprockets by RK, Sunstar and DID.
- Other:
Hepco&Becker makes a luggage rack for side cases.
Renthal has handlebars.
Acerbis has handguards.
MotoDetail sells oil temperature gauges.
Lots of different indicator manufacturers.
Found a centre stand on ebay once, but forgot the manufacturer.
PS: the link doesn't work
The road becomes my bride, and the Earth becomes my throne...
'85 Moto Guzzi V65 TT (never heard of it?)
'93 Yamaha XT 350 Touroduro (sold & missed)
jegrmajstr is offline   Reply With Quote
Old 10-23-2008, 11:18 AM   #230
tathambenjamin
Oddometer: 563
allright
someo good information there. I took a look through the thread but will have to look again I suppose. Sorry about the link.
-HST
Old 10-26-2008, 06:09 AM   #231
jegrmajstr
thumper tourer
jegrmajstr's Avatar
Oddometer: 135
Interesting...
Found this on a german XT350 site:
The silencers are from a CRF 250R, but the pipes are custom made. No sound clip though, I wonder how this baby roars
PS: I was thinking how to address the problem with the crapy XT forks...
If I recall correctly, the forks are 41mm in diameter, so the obvious solution would be simply changing them with better, adjustable forks from a different bike (like a DR 350) that has the same diameter forks, keeping the original triple-trees.
There would still be a bit of a problem sorting out the front axle, wheel and brake, or just using the whole front end of the other bike.
The other thing is that all this would be probably too expensive, but hey, why not
jegrmajstr screwed with this post 10-26-2008 at 08:46 AM
Old 10-26-2008, 06:11 AM   #232
johned206
johned206's Avatar
Oddometer: 16
520 Chain Conversion?
Hey, FlyingFinn and J-Ball, thanks for the advice on the fork seal change. Things went smoothly and I got the job done. Reading the posts in this thread has got me thinking about doing the 520 chain conversion. Who out there has done it, where did you get the parts, and has it been worth it? I ride mostly fireroads and a little single track from time to time, very little time on the pavement. Thanks
johned206 screwed with this post 10-30-2008 at 02:43 PM
johned206 is offline   Reply With Quote
Old 10-28-2008, 06:22 AM   #233
The Full Monty
The Full Monty's Avatar
Oddometer: 97
Question Wheel Bearing Numbers?
Does anyone have the front and rear wheel bearing numbers? Not for the OEM, but for sealed bearings and seals? I would like to have the bearings in my hands before I pull the wheels off.
It is a lot easier to die, then it is to use your head. R.A. Heinlein
KLR650 '09
The Full Monty is offline   Reply With Quote
Old 10-28-2008, 07:29 AM   #234
Corky1
Corky1's Avatar
Oddometer: 363
Talking 520 Chain Conversion?
Chain conversion is a good idea. When out riding and you need to borrow somethingit will be the same as most others use.
Conversion info here.
http://www.pbase.com/corky1/xt_350_project_bike
Good luck, Corky
Corky
www.racersandranchers.com
Blueribbon Coalition Member # 34313
AMA # 199311 Charter Life Member
"Keep The Rubberside Down"
Corky1 is offline   Reply With Quote
Old 10-28-2008, 08:38 AM   #235
Grreatdog
Grreatdog's Avatar
Oddometer: 5,938
The front fork fix I used was to add spring preload spacers under the fork caps and go to a 2.5 heavier weight fork oil. I think i raised the level a little too. But my memory isn't that good.
I have no idea how long the preload spacers were. I tried several lengths before I got what I thought worked OK. It was no miracle cure but at least the didn't bottom on hard braking anymore.
KTM 640 LC4E
KTM 200 MXC
XT200
Old 10-29-2008, 11:50 PM   #236
tathambenjamin
Oddometer: 563
Wicked New xt...maybe.
Well, I have been lurking through this thread for a while and it seems I am about to get my hands on an 86 XT350 with somewhere between 12-14k on it (broken odo), but looking in prime condition.
Owner asking $1200- but we are also making a trade, my bike needs some repairs, trading down so to speak. Has had-
-SS brake line installed
-Sprockets changed for higher gearing
-New chain (not sure which size?)
-Moose bars w/ end weights
-some other minor things.
When I spoke to the owner I asked, "Has it been ridden off road much?"
to which he responded, "off road? Well, I rode it in my yard once..."
Super nice guy who is about 60 and says he has to sell because his knees arent up to the kickstart anymore. I am pretty excited....
Heres a picture- please tell me if you notice anything I havent mentioned.
he says it doesnt leak a drop of oil and that he changes all the filters and oil every season regardless of how few miles he rides. (says he has ridden it for 4k in 8 years). Mileage may be a little high but it looks and sounds like it has been well cared for. Forgot to ask about valve adjustments and weight of fork oil, etc. but I will get to that later.
So, what do you guys think?
-HST
Old 10-30-2008, 02:05 AM   #237
jegrmajstr
thumper tourer
jegrmajstr's Avatar
Oddometer: 135
Looks really nice, I'd say go for it
Like I said, mileage isn't a problem if the bike was cared for like he says, although I would change all the fluids (oil, fork oil, brake fluid), change front brake pads and rear brake shoes, check the wear on the brake disc (and replace it if it has grooves) and all-in-all thoroughly clean the whole bike when I would brought it home.
PS: Try to haggle a hundred $ or so down, just for the sake of haggling
Old 10-30-2008, 04:49 AM   #238
The Full Monty
Oddometer: 97
Thumb
Yes, very clean! I got my 86 for 900 and it was not nearly as clean as this one.
KLR650 '09
Old 10-30-2008, 06:32 AM   #239
cnj
Oddometer: 69
I just finished doing this conversion on my '00 XT350. When I get home from work, I will research the part numbers/applications of the sprockets I used and post here. I went with steel front and back for durability.
2002 KLR250
cnj is offline   Reply With Quote
Old 10-30-2008, 09:39 AM   #240
nails1
nails1
Oddometer: 185
Somebody gave me this P/N, which I bought at the local auto store. Please search on this BBS (I'm pretty sure it was a thread here, but maybe ThumperTalk). Let me know if you can't find it -- maybe I wrote it down somewhere.
Be advised that it's basically impossible to drift in the front bearing without breaking the hub. The part that breaks is what drives the speedo, and I fixed mine with JB Weld.
nails1 is offline   Reply With Quote
Times are GMT -7.   It's 05:36 AM.
