Old 11-11-2008, 06:57 AM   #256
Corky1
Corky1's Avatar
Oddometer: 364
Mr O, XT350 wire diagram.
Go here for some other ideas, http://www.pbase.com/corky1/xt_350_project_bike
Good luck,
Corky
Corky
www.racersandranchers.com
Blueribbon Coalition Member # 34313
AMA # 199311 Charter Life Member
"Keep The Rubberside Down"
Corky1 is offline   Reply With Quote
Old 11-11-2008, 07:08 AM   #257
Corky1
Corky1's Avatar
Oddometer: 364
Csavargo,
Here is a fix for your intake manifolds. See picts
Use wire wheel, remove rubber from manifold
Find vinyl tube that fits over manifold
cut to correct length
small hose clamp over tube to intake manifold
connect manifold to engine and connect to carbs.
Good luck, Corky
Corky
Old 11-11-2008, 08:51 AM   #258
Csavargó
Industrialist-hippy
Csavargó's Avatar
Oddometer: 154
Thanks corky. Sadly i had already dove into the project utilizing industrial gas resistant bond adhesive to bond the boot back to the boss. Im hoping it will work but it didnt solve the dry rot issue. I sprayed it up nice with silicone to try mitigate furthur dry rot. I like your solution a lot better than mine since it utilizes new rubber and is much more elegant of a fix. If / when my fix fails, i will be sure to use your advice.
Master of the hobo arts!
Hajrá Fradi!!!!
1995 BMW R1100gs
1993 Yamaha XT350
1990 Suzuki VX800
2006 Brunton Stalker
Free GusGus Now!
Csavargó is offline   Reply With Quote
Old 11-14-2008, 09:15 AM   #259
johned206
johned206's Avatar
Oddometer: 26
JT 845.41 steel rear sprocket
Anybody know where I can buy a JT 845.41 rear sprocket? I know Sprocket Specialists has a 41 tooth aluminum rear for my 520 chain conversion, but I want to go steel. Help!
johned206 is offline   Reply With Quote
Old 11-14-2008, 01:11 PM   #260
seriousracer
be a man dodge tree bark
seriousracer's Avatar
Location: i am not f***ng stupid,but i used too. niles mi.
Oddometer: 7,432
hola!
anyone have some extra jets they can lend??
with the weather getting colder i wanna fatten it up and try some things for cold weather runs.
also any carb parts?
seriousracer is offline   Reply With Quote
Old 11-14-2008, 04:26 PM   #261
cnj
Oddometer: 70
I don't recall where I ordered mine from, but you could call the Bike Alert in Georgia (from the JT Sprockets web site). I'm sure they will help you.
Bike Alert Inc.
1465 Trae Lane, Lithia Springs
Atlanta, GA 30122, USA
Tel. +1 770 948 8880
cnj is offline   Reply With Quote
Old 11-16-2008, 04:15 PM   #262
Texspeleo
Opportunivore
Texspeleo's Avatar
Oddometer: 257
XT350 project in Colorado Springs
If anyone in the Colorado Springs area is looking for a project, I found a '91 (I think...white/red paint scheme) at ActionCycles in the back warehouse. It'll need some fixing up, but the guy at the shop says it runs okay.
Cheers----Chris
Texspeleo is offline   Reply With Quote
Old 11-18-2008, 04:55 AM   #263
johned206
johned206's Avatar
Oddometer: 26
Bike Alert Inc.
Thanks.
Old 11-24-2008, 07:28 PM   #264
johned206
johned206's Avatar
Oddometer: 26
Talking 520 chain conversion
For those interested in doing this I provide the following information:
JTR845 steel rear sprockets are available from www.mxmegastore.com. I bought the 41 tooth version for $23.39 plus $11.90 shipping; front steel sprockets are available from www.sprocketspecialists.com. I bought the 15 tooth version for $22.99 with $11.38 shipping; DID520NZ 120 link chain is $34.95 plus $10.42 shipping on ebay from turbo283. Your mileage may vary.
johned206 screwed with this post 12-01-2008 at 04:10 PM
Old 12-05-2008, 01:21 PM   #265
Capsicum
Oddometer: 26
I finally have street tires, bridgestone spitfire s11 110/90-18 rear, and metzler 880 80/90-21 front. They seem to work well, and were all I could find that would fit and was not backordered until the end of time.
The maxxis promaxx m6102 is no longer made in 3.00-21.
Also, I switched the stock 55t rear sprocket with a 47t. (Chain needs to be exactly 4 rollers shorter than stock.)
Countershaft is still 19t, stock.
I haven't tried my supertrapp yet, but with the stock muffler and a cool night on level freeway at 60 feet of elevation, it would accelerate slowly in 6th at 60mph. My new 5th equals the stock 6th. 1st-5th gaps feel more appropriate now. 1st does well off the line, better than stock actually as you don't have to shift so soon, but I'm only 170 pounds with gear.
Not too much clutch work is needed but it is noticable, about like most standard street bikes I've ridden, and not as bad as most 4cyl. sport bikes.
I would not recomend this for standing starts on steep trails.
My normal 3-4 mile commute rarely exeeds 50mph and I'm not really using 6th but I like the new 1-5th feel. I may well try my 50t sprocket after I try my supertrapp.
I certainly won't be going back to stock 55t though, unless I put full dirt DOT nobbies on it. (In which case I have a 57t sprocket to try and may also try the 18t drive sproket, stock is pretty low though.)
Capsicum is offline   Reply With Quote
Old 12-06-2008, 07:49 AM   #266
cnj
Oddometer: 70
Originally Posted by Tyko99
Came across this on the net:
Whenever feasible to obtain a specific ratio, avoid using a smaller than stock front sprocket. The smaller sprocket requires the links of the chain to turn a tighter radius, which increases friction and decreases the life expectancy of the chain (by decreasing life expectancy of the o-ring seals of the chain).
[FONT='Times New Roman','serif']
[/font]
Agreed. I don't believe it is applicable in this case, however, as the diameter of the 520 type 15 tooth front sprocket is very close to the diameter of the stock 428 19 tooth front sprocket (due to difference in pitch/tooth size, etc).
Old 12-08-2008, 08:07 PM   #267
Burtonridr OP
Wanderlost
Burtonridr's Avatar
Oddometer: 3,725
Has anyone managed to find somewhere on the internet to buy progressive fork springs? Or anyone we can call for the springs?
I'm having a hell of a time locating any
Have beer, will fly
"This forum requires that you wait 30 seconds between posts. Please try again in 1 seconds."
Burtonridr is offline   Reply With Quote
Old 12-08-2008, 08:20 PM   #268
Burtonridr OP
Wanderlost
Burtonridr's Avatar
Oddometer: 3,725
Ok, I found a website that has them... They are located in the UK, but only have the fork springs for a 1985-1990 xt350.
Are the front forks the same after 1990? Are UK models the same?
I also found somewhere that said that klr250 and xr200r front fork springs are near the same (or the same) and I should be able to find progressive springs for those models, anyone know for sure?
Does anyone know what the spring rate of our front fork springs is?
Can Anyone Confirm that the front fork spring dimension is 580mm long and 38mm in diameter?
Have beer, will fly
Burtonridr screwed with this post 12-08-2008 at 09:04 PM
Old 12-09-2008, 06:43 AM   #269
nails1
nails1
Oddometer: 187
See post 31.
I'm thinking of getting custom-built springs, based on my existing springs (I'd send them in) and the preload I get. Should work for both ends.
nails1 is offline   Reply With Quote
Old 12-09-2008, 10:41 AM   #270
Burtonridr OP
Wanderlost
Burtonridr's Avatar
Oddometer: 3,725
Originally Posted by nails1
See post 31.
Thanks,
Now I just need to find the spring length and rate of a KLR250
But if the length is right, or even a little longer or shorter it should work. The two bikes are very close to the same weight. They are only about 30lbs different. So I would think that the KLR250 progressive springs will work with the right spacer or preload, right?
I'm emailing back and forth with a rep at Progressive suspension to figure out what will work best.
XT350 specs:
Fork Spring Length = 580mm
Fork Spring Diameter = ??
Fork Spring Rate = 19.6lb/in (3.4 n/mm)
Bike Wet Weight = 330 lbs
KLR250 Specs:
Fork Spring Length = ??
Fork Spring Diameter = 29mm
Fork Spring Rate = ??
Bike Wet Weight = 295 lbs
Please let me know if anything is incorrect...
Have beer, will fly
Burtonridr screwed with this post 12-09-2008 at 11:12 AM
Times are GMT -7.   It's 10:00 PM.
