Old 09-09-2012, 06:18 PM   #3061
gearheadE30
gearheadE30's Avatar
Oddometer: 889
Originally Posted by NordieBoy View Post
Both rims should be 2.15" wide.
The TT rim has the stupid "Z" spokes and 2 bearings each side.
Both my TT rims are rotting out with age.
It does indeed have the Z spokes and the double bearings. If you're in need of a solid rim, mine's pretty good. It'll be going up on Ebay soon, probably.
My XT must have had a wider rim laced onto it, because it's at least a quarter inch wider, and doesn't have the typical size markings on it.
Also, if anyone has a spare rear XT wheel lying around, I'm still looking for a reasonably priced one.
2005.5 KTM 950 Adventure and 2012 KTM 200 XC-W
1991 BMW 318is turbo track car
1989 Chevrolet Caprice Classic Wagon sleeper tow car
1992 Subaru SVX daily
3 Months Exploring the US on a 950
gearheadE30 is offline   Reply With Quote
Old 09-11-2012, 03:20 AM   #3062
Lenz1
Oddometer: 141
The TT rims seem seriously strong though. The rear rim had a significant lip bend / flatspot courtesy of the previous owner. Said rim ding would NOT move with bracing and the delicate strokes of a large metal hammer so out with the large heating torch, some careful support / bracing with a length of timber, a large assistant to hold said wheel and a big rubber hammer to belt the right amount of sense into said wheel.
What a difference it made to heat the defect area well and support it correctly. The flat spot is gone and the rim lip is now no more than 1 mm out of line. I massaged the flat spot first then the lip bend. Realistically this is a 2 person job.
Yee hah - my engine parts, tyres etc have arrived. The cyl head has been massaged with porting, new valve seals, valves / seats refaced and the cam caps massaged for < 2 thou clearance on the camshafts. Probably be a few valve shim changes to produce correct clearances. Light bore hone, new rings, a little bump in compression and additional oil cooling (2x) should see a more lively little motor. I'm gonna use some of TT Klaus' carbie settings as a start point for tuning.
Lenz1 is offline   Reply With Quote
Old 09-11-2012, 05:08 PM   #3063
Coots
That's what she said
Coots's Avatar
Oddometer: 155
Service Manual
Does anyone have a service manual in PDF and in English? My other lauguages suck.
Coots Jr is just a younger me!
03 DL1000 "Bumble Bee"
91 XT600
03 SV650S SOLD
Coots is offline   Reply With Quote
Old 09-11-2012, 07:58 PM   #3064
ahook93
Oddometer: 11
intake boot
My 350 ran good until today. started idling pretty high. culprit seems to be a broken carb to head boot. Online i can only seem to find them for $40 + bucks. Seems outrageous. Anyone know of a cheap replacement?
ahook93 is offline   Reply With Quote
Old 09-12-2012, 05:58 AM   #3065
SkidMarx
SkidMarx's Avatar
Oddometer: 2,131
$40ea is a good price.
'90 XT350
'08 WR250R
GLDS
SkidMarx is offline   Reply With Quote
Old 09-12-2012, 09:48 AM   #3066
kwakbiker
kwakbiker's Avatar
Oddometer: 643
There are some links in this thread(somewhere), if not pop over to thumpertalk and into the yammy section on there as theres links in the first few xt threads
Oh and $40 bucks is cheap...lucky sod
2007 Versys
More fun being upright
kwakbiker is offline   Reply With Quote
Old 09-13-2012, 08:14 PM   #3067
ahook93
Oddometer: 11
high idle
recently my xt has developed a high idle after it has been warmed up and ridden. I could have my idle turned down to 1500 or so and after a ride it will progressively make its way past 3000. Now my carb boots were trashed so i siliconed them up while waiting for the new ones to come. Although they still may be leaking and causing this I think it may be something else. any ideas?
Old 09-13-2012, 08:46 PM   #3068
SkidMarx
SkidMarx's Avatar
Oddometer: 2,131
Silicone won't work on the boots. Don't bother trying to "fix" anything until you get new ones. I wouldn't ride the bike either.
'90 XT350
'08 WR250R
GLDS
Old 09-14-2012, 12:51 AM   #3069
ahook93
Oddometer: 11
do you think even the slightest leak would cause it to idle so high?
Old 09-14-2012, 06:18 AM   #3070
SkidMarx
SkidMarx's Avatar
Oddometer: 2,131
Any leak will cause all kinds of unpredictable problems. High idle is possible.
'90 XT350
'08 WR250R
GLDS
Old 09-14-2012, 10:12 AM   #3071
jch
jch's Avatar
Oddometer: 82
Originally Posted by jch View Post
Rear wheel with Shinko 712R road tire - wheel is in very good shape and tire has over 50% tread - $120 shipped
Mounting bracket for speedo and tach - $20 shipped
Cylmer manual - $20 shipped
PM me for pictures or more info
Clymer manual is sold, still have the wheel and the mounting bracket. PM me for pics if interested.
jch is offline   Reply With Quote
Old 09-24-2012, 11:02 AM   #3072
Indiesol
Putz
Indiesol's Avatar
Oddometer: 46
She's coming along. I'm pretty happy with the CycleRacks rear rack, and with the Clarke 4 gal tank I've confirmed range of up to 220 miles (with some gas still in the tank). 520 chain conversion tonight followed in the next couple days by installing my DG slip on and jet kit. Seat is being recovered in black today. Gotta pick up some new tires, too.
Anyone have a rear shock in good shape they'd like to sell? I have a hypercoils spring for it, I'd just like to keep my original shock and spring together as spares.
"Being shot out of a cannon will always be better than being squeezed out of a tube. That is why God made fast motorcycles, Bubba...."
Hunter S. Thompson
Indiesol is offline   Reply With Quote
Old 09-24-2012, 08:27 PM   #3073
LarryGee
Oddometer: 356
Looking at a used 1991 XT350. Guy has the title but can't seem to find the vin on the bike. Where do stamp the vin? On frame? On motor only?
LarryGee is offline   Reply With Quote
Old 09-25-2012, 09:11 AM   #3074
Coots
Coots's Avatar
Oddometer: 155
Breathing
What do the masses say about replacement air filters? Any aftermarket one good, great, shit? I need to replace the stock and would want one with very little modification to the stock box.
91 XT600
03 SV650S SOLD
Old 09-25-2012, 09:53 AM   #3075
kwakbiker
kwakbiker's Avatar
Oddometer: 643
On the headstock, motor will have a seperate number
2007 Versys
Times are GMT -7.   It's 05:15 PM.
