Old 10-23-2012, 05:56 AM   #3121
Captain Caution
Captain Caution's Avatar
Oddometer: 118
Originally Posted by Indiesol View Post
I like them too. I believe the only one available for the XT350 is the 4 gal like I have, but I've gone 220 miles on it before filling up and there was still some fuel left in the tank. Man I love this bike. Blew the low beam the other night though. I spent half my Saturday trying to track down a bulb locally but ended up having to order it. Picked up two so I'm covered the next time. I need a new rear tire as well. Looking for suggestions on a DOT legal knobbyish tire. What are you guys happy with?
I bought Shinko 244's for my XT and I like them.
http://www.motorcycle-superstore.com...Rear-Tire.aspx
I ride two lane black top 90% of the time and when I off road it's hard packed, dusty, rock strewn single track. They're cheap and they wear well...mine have 6000 km on them and the front has hardly any wear, while the back is at about 60%. I can email you some pics if you like. You may have to get them out of the states, as I couldn't find them in Ontario at the time.
Cheers!
Captain Caution
Fight cancer, not war.
Captain Caution is offline   Reply With Quote
Old 10-25-2012, 01:28 AM   #3122
EATPharmD
Hiding out
EATPharmD's Avatar
Oddometer: 136
Originally Posted by Eatmore Mudd View Post
I am digging that Clarke tank. I may have to get me one.
Here you go!
http://www.advrider.com/forums/showthread.php?t=830019
Before
After
As you can see I also swapped out the Gonzo nose front fender
EATPharmD is offline   Reply With Quote
Old 10-26-2012, 10:03 AM   #3123
Indiesol
Putz
Indiesol's Avatar
Oddometer: 46
I finally picked up a donor rear shock for my XT yesterday. $38.24 shipped and it looks to be in pretty good condition.
My plan is to swap the stock spring on the donor shock for a Hypercoil spring with a 600lb spring rate. It should help with the bottoming out in the back. If it doesn't, or it's worse, I can just put the original one back on. I've heard/read good things about this modification though.
The long way home from work....
"Being shot out of a cannon will always be better than being squeezed out of a tube. That is why God made fast motorcycles, Bubba...."
Hunter S. Thompson
Indiesol is offline   Reply With Quote
Old 10-26-2012, 11:15 AM   #3124
Captain Caution
Oddometer: 118
[QUOTE=Indiesol;19905407]I finally picked up a donor rear shock for my XT yesterday. $38.24 shipped and it looks to be in pretty good condition.
Yes, please do post the results. I'd like to upgrade my bike too, as I usually have to stand on it with the sidestand down to kick it over, which almost makes me fall over now, as the shock weakens.
Cheers!
C.C.
Old 10-28-2012, 09:18 AM   #3125
George 99
George 99's Avatar
Oddometer: 787
My XT hasn't been out'a the garage since I got back from Flagstaff in August. Need to give her some exercise.
George
Sometimes in Kingman, Arizona
George 99 is offline   Reply With Quote
Old 10-30-2012, 04:47 AM   #3126
GaMtnRider
Oddometer: 23
Cheers!
C.C.
I also would really like to hear about some results with the hypercoil 600 lb spring.
Also- I've had the rear shock out of my bike, but it was not obvious how to change the spring. Could someone who's done it post up a brief how-to?
'00 Yamaha XT350
'96 Honda XR 400 tagged
GaMtnRider is offline   Reply With Quote
Old 10-30-2012, 10:59 AM   #3127
Mr. BigWheel
b00b
Mr. BigWheel's Avatar
Oddometer: 756
Does anyone have any advice on removing the seal on the front caliper of a late eighties XT?
The main seal on the piston (the one that is deeper in the bore) comes out easily enough but the bellows-type dust seal is giving me fits. The seal might even be the original but I'm ripping it to shreds in the process of extracting it. Is there a circlip or something I'm missing?
Any advice to stop the headbanging would be appreciated.
Regards,
Mr. BigWheel
The BigWheel channel - Home of the self-aggrandizing Enduro Alaska videos:
http://www.youtube.com/user/MisterBigWheel?feature=mhum
Mr. BigWheel is offline   Reply With Quote
Old 10-30-2012, 01:52 PM   #3128
Indiesol
Putz
Indiesol's Avatar
Oddometer: 46
Looking for a primary/secondary carb set. If anyone has one, please send me a message.
Hunter S. Thompson
Old 10-31-2012, 12:41 AM   #3129
Indiesol
Putz
Indiesol's Avatar
Oddometer: 46
I mounted my Hypercoil spring to the donor shock I picked up off eBay. Hopefully I'll have it installed tomorrow.
Here's a quick mockup of my ammo can saddle bags. I had to swap out the blinkers for ones with shorter stems to fit with the pannier mounts. I like the looks and will permanently mount the bags tomorrow as well as install the matching front signals.
Hunter S. Thompson
Indiesol screwed with this post 10-31-2012 at 01:09 AM
Old 10-31-2012, 04:33 AM   #3130
GaMtnRider
Oddometer: 23
Looks good!
What year is your bike? Earlier in this thread someone posted that the rear shock got longer in 87 or 88, but it's not clear if the spring stayed the same or not.
'00 Yamaha XT350
GaMtnRider screwed with this post 10-31-2012 at 06:30 AM
Old 10-31-2012, 10:35 AM   #3131
Indiesol
Putz
Indiesol's Avatar
Oddometer: 46
Originally Posted by GaMtnRider View Post
Looks good!
My bike is a '92. The shock came off an '89. I looked at the microfiche for years '85, '89 and '92 and all use the same part number rear shock assembly (at least, according to BikeBandit).
Re: Removal, I just started unthreading things from the adjuster side. Had to use a bit of PB blaster but it eventually came apart.
Hunter S. Thompson
Old 11-01-2012, 04:05 AM   #3132
Lenz1
Oddometer: 141
TT 350 rebuild
Hi All
The TT350 rebuild has finally past a significant hurdle in the new carbie setup. I've deleted the original parallel carbie format, built steel manifolds angled at ~ 13degrees to the inlet port face for a straighter inlet tract and used 34mm ID fuel pipe as the connectors between manifold and carbie. This means the carbies are now "splayed" instead of parallel which has of course significantly altered the mechanical linkages between primary and secondary carbies.
Fabricating a new contact plate / arm for the secondary and setting it up to achieve the correct secondary throttle positions was an exercise in patience and persistence but the job is done. The secondary throttle cracks at 3.3mm of carbie slide clearance on the primary and at full slide clearance (100% primary) the secondary throttle is at midline ---- perfect.
This was a significant win for me - there were periods when that dear little secondary carbie was absolutely gonna be replaced with another cable operated carbie like the left primary.
So there's a few pics coming - I'd had enough of the whole thing by the time the secondary was working correctly
Next phase is the dual oil coolers ...... too easy .....
Lenz1 is offline   Reply With Quote
Old 11-08-2012, 05:07 AM   #3133
GaMtnRider
Oddometer: 23
My 600lb Hypercoil spring came in Tuesday. Installed last night. Couple pics below.
Without having ridden the bike, only sat on it, first impression is that it is definitely better than stock, but I think I would like it a little stiffer, mostly because there is so little dampening.
Spring rate feels similar to my XR400 but the dampening is so much better on the XR.
I'll try to take it for a little spin tonight and see she rides.
Update: Definitely better. Looking forward to taking her over some of the jumps that used to bottom out the rear shock.
Next up - shore up front suspension more than the 20wt shock oil and longer spacers I have already done.
Planning on the Progressive springs and maybe a gold valve emulator- if someone has found one that fits.
'00 Yamaha XT350
GaMtnRider screwed with this post 11-09-2012 at 05:34 AM
Old 11-18-2012, 10:18 PM   #3134
Indiesol
Putz
Indiesol's Avatar
Oddometer: 46
Bike started running rough while riding about sixty miles an hour, as if she was running out of gas. I flipped over to reserve, which seemed to help things, but I still had half a tank of gas. I turned around and headed home, and by the time I got home, even with the reserve on, which was my temporary fix, the bike was sometimes dying at idle.
Bike is a '92 with a new Clarke tank that only has about 1000 miles on it. Plenty of oil. I've had the bike since 3500 miles and it has 5400 on it now and it ran great up until this weekend. Hadn't rebuilt the carbs yet because the bike ran so well.
Obviously I'll check the fuel valve as well, but this will be the first time I've taken the carbs apart on this bike. Any tips or tricks? Any chance I can avoid having to sync these things? I sometimes have a hard time with that part. I seem to remember reading somewhere in this thread about carefully removing the link between the two carbs? Can anyone expand on that a bit ? Thanks.
A few days before she started running rough on some random logging road in Washington.....
Hunter S. Thompson
Old 11-19-2012, 06:24 AM   #3135
SkidMarx
SkidMarx's Avatar
Oddometer: 2,335
You likely needs new intake boots.
you will have to remove the carbs, but won't have to mess with them.
'90 XT350
'08 WR250R
GLDS
SkidMarx is offline   Reply With Quote
Times are GMT -7.   It's 03:41 PM.
