Old 03-18-2008, 11:46 AM   #31
nails1
nails1
Oddometer: 187
I rode MX in late 70's and only street since, so I'm not the best of judges. Got a 99 XT 350 last month (1400 miles, $2K, not the best of care). I don't really understand why folks are so apologetic about it, like DR having more power (both are 27hp at 7600-8K). Not sure about that "17hp restriction" (mine is apparently after that). Seems to run great.
Right now, I'm waiting on carb parts mostly to replace bad rubber (definitely fuel leaks, suspect air leaks). I'm also fussing with jetting -- I live at 7500 ft elevation, so the Webistan jetting info doesn't work for me ;( Moose mini bars and handguards installed.
Everybody says to do the 428 to 520 chain swap.
From what I've found, the only significant and easy power mod appears to be Supertrapp and jetting. This "XT350 power" thread as various info http://www.thumpertalk.com/forum/sho...ht=XT350+power Seem to be mixed reviews about White Bros powerup kit (if even still available).
I've heard of progressive spring replacement for forks, as well as fork swaps (seem to lead to a lot of other fussing). This site http://www.xt350.de/viewtopic.php?t=2061 lists the original front spring specs.
- Frontspring : K1 = 3,4 N/mm (19,6 lb/in)
- length new : 580 mm (22,835 in)
- lenght bad : 575 mm (22,638 in)
Seems like something might swap-in off the shelf -- anybody know of a way to sort that out? This site has more info http://www.thumpertalk.com/forum/arc.../t-437922.html
I understand rear progressive swaps are available for some $500.
I've given up on using an oil cooler for various reasons, including messing with that oil line to the head seems like a bad idea after all. Has anyone had luck with an oil temp gage on this sump system?
http://www.advrider.com/forums/showthread.php?t=263871 has specs for a roll-your-own battery eliminator.
nails1 is offline   Reply With Quote
Old 03-18-2008, 09:02 PM   #32
TTKlaus
Oddometer: 329
I have an oilcooler on my 350. Also, I used to run a Supertrapp, but now I'm convinced that the noise/power tradeoff is not worth it. For your elevation I would think that a 116-118 primary main and a 120 secondary main is in the ballpark. I also live in NM near 6500 ft.
TTKlaus
Do it in the Dirt!
1974 DT250, 1980 TT500, 1986 TT350, 1993 KLX650C, 03 KTM450EXC
TTKlaus is offline   Reply With Quote
Old 03-20-2008, 07:07 AM   #33
nails1
nails1
Oddometer: 187
Thanks. I think XT and TT got way different stock jetting. I just ordered 104/124, which I believe is one (small) step lean from stock (my plugs are a black kind of tan). How did you fit the cooler? Maybe PM a photo? I'm near Pecos. Carb parts probably won't make it this weekend tho.
Old 03-20-2008, 07:51 PM   #34
TTKlaus
Oddometer: 329
Nails,
I'm just down the road in Lamy. I've found that the closer together you can get the 2 carbs in jet sizes the better they work, they are a pain in the ass until you get them right. I will try to get a pic posted about my cooler, it hooks into the oilfilter cover (custom made), that way all of the oil gets cooled, not just the oil that goes up into the head.
TTKlaus
Do it in the Dirt!
Old 04-22-2008, 10:53 PM   #35
StuckXJ
StuckXJ's Avatar
Oddometer: 61
I'm lost as to what to try next so I was hoping one of you guys could help. When I put the bike away for the winter it was running well. I change the oild tear apart the carb, and fresh gas... Now it starts like it used to, one kick but, it revs high but besides that runns great for about 1 min or just far enough, usually down a hill, away from my tools and a safe place to wrench. (far and few between on a college campus) So then i try and kick start it for a few and it usually starts with only a little more trouble than usual. But now it revs high and has no power, shifting into gear is enough to kick it. Adjusted the clutch, I first thought that to be my problem, but no... I can fiddle the choke, as i had to last year, to get it to idel right but still no power. If I give it gas it will hesitate then rev but still once i try to get it rolling it just bogs and dies unless i grab the clutch. I was thinking maybe the petcock, its old and needs to be replaced but up until now has been working ok. I was thinking that the bowl was draining out of gas and not filling up fast enough to keep going? Once it sits for a while, 20 min or so, and I start it it will then act like it did in the beginning, runs great for a min or so. Only 2 weeks left untill summer break and i'll tear it down at home and paint it up nice replacing all the old warn parts, but for now its just taunting me sitting outside the dorm window. Thanks for any help!
-Steve
1989 Yamaha XT350
http://s323.photobucket.com/albums/nn479/StuckXJ/
StuckXJ is offline   Reply With Quote
Old 06-10-2008, 12:10 AM   #36
Ziggy
Oddometer: 3
Xt 350 Trouble
I just got a 2000 XT350 it seems to be backfiring through the carb. It
starts good but when it gets warmed up it misses and backfires through
the carb. I changed the spark plug and looked for air leaks. Changed
the secondary carb inlet which the rubber had separated from the
mount. The air filter is clean I even left the cover off but no
difference. I checked the gas flow from the petcock and it's full
stream. I'm stumped! Also do these bikes always run hot?
Bikes are like good friends
They may come and go
But you never forget one.
Ziggy is offline   Reply With Quote
Old 06-10-2008, 09:21 AM   #37
SkidMarx
SkidMarx's Avatar
Oddometer: 2,266
I can't believe I missed this thread.
My '90 XT350 Post rebuild.
Stripped it down to the frame.
Cleaned repainted, and/or polished everything. in process pix here
Put new fork seals in with 15wt oil (thats how it all started)
Added seal savers.
Moved the clip on the rear shock down one spot.
The fenders are from a YZ 125. Front one is shimmed a little so it fits.
The rear is the back 1/3rd cut down and heated a little so it would fit better.
Cut the stock plate holder cut down and rolled up further into the fender.
Added a LED brake/tail light.
Relocated the case vent.
see a few more pix here
Other mods already done.
Uni air filter
Home made PowerNow inserts
Rejetted
Heavy duty valve springs w/Ti retainers
Repositioned horn for better airflow in left scoop
Ground the weld off of the inside of the header pipe. (not sure if it helped any)
H4 Headlight bulb.
'90 XT350
'08 WR250R
GLDS
SkidMarx is offline   Reply With Quote
Old 07-02-2008, 03:59 AM   #38
The Full Monty
The Full Monty's Avatar
Oddometer: 97
Question Turn Signal Flasher
Hey does anyone know where the turn signal flasher is located? I think it is under the tank, but it would be nice to know before I get started.
Also, do I have to get a specific Yamaha flasher or will any do?
It is a lot easier to die, then it is to use your head. R.A. Heinlein
KLR650 '09
The Full Monty is offline   Reply With Quote
Old 07-02-2008, 09:04 AM   #39
The Full Monty
Oddometer: 97
Thumb SkidMarx
SkidMarx, Great job on the '90 XT! Hope mine looks that good one day!
KLR650 '09
Old 07-02-2008, 02:33 PM   #40
SkidMarx
SkidMarx's Avatar
Oddometer: 2,266
Thank, and btw, I'm pretty sure the the flasher is under the tank.
'90 XT350
'08 WR250R
GLDS
Old 07-02-2008, 02:39 PM   #41
seriousracer
be a man dodge tree bark
seriousracer's Avatar
Location: i am not f***ng stupid,but i used too. niles mi.
Oddometer: 7,434
under tank.
loaned my xt to a friend who want one now.
lol
and he only rode 60 miles.
seriousracer is offline   Reply With Quote
Old 07-02-2008, 07:32 PM   #42
The Full Monty
Oddometer: 97
Yep! Found it, thanks. Also, replaced flasher with a Buss Flasher No.552 from local autoparts store for under $4!
KLR650 '09
Old 07-03-2008, 07:38 AM   #43
nails1
nails1
Oddometer: 187
LED conversion
My flasher unit is probably also dead -- turn signals light up but don't flash. Thanks for the part ID. I bought some LEDs but haven't sorted the mounting. I wonder if that flasher unit will work with LEDs, or will they flash some funny speed. Anybody know whether this really matters?
Old 07-03-2008, 08:03 AM   #44
The Full Monty
Oddometer: 97
I don’t think it matters. Check out this photo of a cheep set of led flashers on ebay http://cgi.ebay.com/ebaymotors/ws/eB...ksid=p3907.m32
The flasher unit is 12v 10w max, which is about what mine is.
What type/brand led did you get?
KLR650 '09
Old 07-03-2008, 08:27 AM   #45
nails1
nails1
Oddometer: 187
I got clearance marker lights and a tail-stop combo at a truck stop. Mine are Roadpro brand. Maybe RP-1559A for clearance and RP-5500R40L for stop-tail. Just got them last week. They're gonna be PIA to mount. I'll probably make a rack and put all the back lights on it (then use mx fender), and I'll probably mount front lights on a flap thing hanging off the hand guards. Still need to look into LED instrument replacements. Maybe one day I'll sort out a HID headlight, but have 65W bulb in there for now.
Times are GMT -7.   It's 10:10 PM.
