06-28-2010, 02:40 PM
#211 | |
Oddometer: 135
1975 Honda CB550 Four 1980 Honda CX500 dual sport conversion 1983 Honda XLV750R 1983 Honda XL600R 1983 Honda CB985FII Bol d'Or 1983 MZ ETZ250 sidecar 1985 Honda XL600LM 1988 Honda NX650 1989 Honda XL600V Transalp 1992 Honda XRV750 SW-Motec 1995 Husqvarna TE610 |
06-29-2010, 12:01 AM
#212 | |
Oddometer: 980
XLV versus intensive use...
Agree with that. For long distance touring (> I'm using the XLV as an classic. And from time to time I even use it to commute ( On aspect of reliability... It is not that bad! But it depends on which model you own. On a HRC (red engine) I would ride it that much. It has some weak spots (gearbox, oil cooler, rear spring, head caskets, etc) But the Limited (black engine) has several improvements towards the red engine models.
Bernard 'Two Plugs', NL the First International Crosstourer Forum - www.crosstourer-international.com the First International Varadero Forum - www.varadero-international.com May 2013 Wales/UK: 15th Varadero & 2nd Crosstourer International Meeting! |
06-29-2010, 01:42 AM
#213 |
Oddometer: 144
to bad. I dont have place for 2 bikes. I dont mind modifing and getting dirty hands btw.
But guess ill keep on looking i also spotted a xrv650 (i have a fetish for unique bikes :P) |
06-29-2010, 02:07 AM
#214 | |
Oddometer: 135
A beautiful bike. Very reliable and good for long trips. Unfortunately I have not seen a really good one for a reasonable price. And my barn is full of old bikes waiting for a restauration. Otherwise a XRV 650 would be a good addition to my collection!
06-29-2010, 03:51 AM
#215 |
Oddometer: 980
An XLV750 can be modified. I have seen an Belgian owner who took the engine and shaftdrive of an NTV650 Revere and build in the XLV frame...
I'm in to the original thing though. Things which could be modified to make the bike more rugged for touring are not that numereaus... Some ideas...: - Double front diskbrakes; - Rearsuspension... Technoflex (or Wilbers) have still an aftermarked replacement on stock. Little expensive, though. - Sparkplugs... Invest in Iridium ones. - Gearbox... Well.. just use proper engine oil. Halfsynt. or even full synt. - Keep an eye on the cooling of the rear cylinder... Modify the airflow to the rear cylinder when riding in warm climate. I've visited the 20th anniversary XLV750 International Meeting in Switserland back in 2003. I was stunned by the modifications done to the bike by some owners! Many ideas can be viewed on Rolf's XLV pages: www.xlv.ch
06-30-2010, 02:36 AM
#216 |
Oddometer: 980
Carbs cleaning...
I finally succeeded in finding a place where I can clean the carburettor 'Ultrasound'. It's only 30 km from the place where I live; I can simply bring the carbs down there on my way up to the office.
Costs? € 25,-. Found a 2nd address at 100 km from where I live; they charge € 75,-. So I think I've got a fair price. Place to be... Motoport Assen (Assen as in Dutch GP / TT)
07-01-2010, 11:03 PM
#217 |
Oddometer: 1
Hi
I need some help and advice on a 1985 Honda XLV750R. On overrun, the bike pops and backfires. It has a Marving exhaust (Italy) which is as near stock as I could get with no signs of leaking or blowing. I have tried rejetting the main and idle jets using 115, 118 main, plus 40, 42 and 45 idles all with varying combinations. Stock is 118 / 42. I have also fitted new diaphrams and tried max and min positions for the mixture screw. All with no success. I have talked to a bloke who had a similar problem which he traced to the pulse generator. The manual says they should be 450 - 550 ohms. I have one at 465, the other at 422, so it does look out of spec. The problem is, its discontinued from Honda and just about everywhere else that I have tried. The part number is 30300-MG7-003. So.....has anyone else had this problem? How did you fix it and any ideas where I can get my hands on a new pulse generator or know of an alternative? Thanks Hurtlocker |
07-02-2010, 02:40 AM
#218 | |
Oddometer: 980
- Which type of fuel do you use? I've noticed that the XLV feels comfy with high-octane fuel (f.e. Super Plus 98+) - Sparkplugs... Replace the stock plugs by iridium plugs. Really one of the best mods I have done to the bike. - Cleaning... Put a bottle of Forte Fuel Guard on a full fuel tank and ride with it, reff it up. - Hows your air filter? I've got no clue about all kinda tech-talk... I prefer to keep of the engine, settings, etc as long I can fix a problem manually (fuel, fuel adding’s, etc).
07-03-2010, 03:58 AM
#219 |
Keen AG100 rider
Oddometer: 499
A change of pipe will make it run on. After having a two into one on mine then putting a twin system back on the idle revs rose without changing carb set up or idle adjustment touched. A non standard system will change the tune, usually worse. Exhaust leaks will make it run on and backfire, sometimes they are a bit hard to track down.
07-10-2010, 09:17 AM
#220 |
Oddometer: 163
The German Kraftfahrt Bundesamt (Federal Department of Motor Vehicles) tells me there are 153 XLV750 registered and on the road, of which 146 are 45kW version, 7 are the 37kW version.
Very rare now indeed.
2008 XR650L - Sutton Oil Cooler, Cigar Mike Center Stand, XRs only bash plate, Shifter & Case saver, Steel braided lines, 650R C/S sprocket, Manracks case saver, Trailtech Vapor/Dashboard. 1985 Honda XLV750R - Ignitech Sparker DC-CDI-P2, Wilbers shock and progr. forks. 2008 KLR650E- fully farkled |
07-15-2010, 05:00 AM
#221 | |
Oddometer: 980
So, the Carbs and all the non-Fero bits and pieces will be 'Wet blasted' to remove the corrosion. This seems to be a fairly new procedure. http://www.wetblast.nl/ I expect the Carbs to be ready within the next two weeks. Chances that I still can use the original Carbs have risen about 90%... Which makes me happy!
07-16-2010, 05:27 AM
#222 | |
Oddometer: 185
ignitech.cz Is that enopugh to keep you going? cheers Graeme |
08-06-2010, 12:01 AM
#223 |
Oddometer: 228
I just bought a 1986 XLV750 and plan to put a sidecar on it. It's missing the air scoops though. Anybody know where I could get a set. I recon with the chair on it will run a little hotter so the scoops are a necessity.
Had one of these years ago. Bought it new then. Great bike apart from the notchy gear change. 3 return trips across the nullabor (Perth-Sydney-Perth) didnt worry it. Phil |
08-06-2010, 04:40 AM
#224 |
Keen AG100 rider
Oddometer: 499
Hideehodee Phil, yoo buy the one from Guyra?
08-08-2010, 03:45 PM
#225 | |
Oddometer: 228
