Old 11-03-2011, 07:32 PM   #346
baldtire
Oddometer: 101
Two Plugs
How did you adjust/alter your preload on the shock,once installed its a pig to get to.
baldtire is offline   Reply With Quote
Old 11-06-2011, 11:06 AM   #347
Menasco Pirate
Menasco Pirate's Avatar
Oddometer: 349
Wilbers Shock
My Wilbers shock arrived and I installed this weekend. I was able to remove the old shock without removing the swing arm by removing the shock bolts, the shock link completely and then just removing the 3 battery box attachment screws. I left the battery box in place (and all the wires and junk) but it gave enough to allow me to remove the stock shock. The Wilbers shock went in much easier since its a bit less volume than the stock unit.
We got rain and snow in SoCal but I plan to ride it today.
Steve
XLV750, RTL250S, 1989 XL600V, 1990 XL600V Transalps Red and Moonstone, 1992 XL600V Green, 1993 CRM250R, 1994 XRV750 Africa Twin
2009 FE390 tagged, 2011 FE450 tagged, 2011 FE570S super motard, 2011 FE570S
Menasco Pirate is offline   Reply With Quote
Old 11-06-2011, 11:59 AM   #348
Menasco Pirate
Oddometer: 349
Originally Posted by baldtire View Post
Two Plugs
Sag appears to be close from the factory
Old 11-06-2011, 07:38 PM   #349
baldtire
Oddometer: 101
Steve
Thanks for that bit of info,I decided to go the other way and that was a pain.
Old 11-06-2011, 10:45 PM   #350
Menasco Pirate
Oddometer: 349
Wilbers install
I rode the XLV today and I'm pretty happy with the shock, the sag worked out fine as shipped. Now I need to work on the front brake noise, any ideas?
Steve
Old 11-20-2011, 05:15 PM   #351
TEZZA
ADV B4 DEM/TED
TEZZA's Avatar
Oddometer: 302
Question XLV 750 Parts
Hi all , i am in the process of possably getting a XLV 750 with some miner damage to the tank and may have some other damage .The fuel pump has been changed to a fuel pump from a Mazda Capella and i am told that it works ?????
Are parts easy or hard to find , i am only paying a few hundred for the bike after a look at it first .
Would it still be worth it to buy or leave it alone ?????
Tezza
Tezza.
KTM 990 ADVENTURE.
KTM 520 EXE.
Now the Perfect pair!!!!
TEZZA is offline   Reply With Quote
Old 11-20-2011, 10:59 PM   #352
Two Plugs
Two Plugs's Avatar
Oddometer: 1,390
Tezza
Hi Tezza,
Get it! It's a very rare machine. Don't worry about the Mazda fuelpump. The Africa Twin XRV750 and the Varadero XL1000V are using Mitsubishi fuelpumps. On my MK1 Varadero I replaced it by an Rover fuelpump....
Keep in mind that hardware is more- en more difficult to find.
Bernard 'Two Plugs', NL
Honda XL1000V Varadero & VFR1200X Crosstourer Forum www.vci-forum.com
22-25 May 2015: 17th Varadero & 4rd Crosstourer International Meeting, Milau, France!
Two Plugs is offline   Reply With Quote
Old 11-21-2011, 01:39 AM   #353
TEZZA
ADV B4 DEM/TED
TEZZA's Avatar
Oddometer: 302
Question XLV 750 parts
Hi All , so are parts hard to get ????????????????
Tezza
Tezza.
KTM 990 ADVENTURE.
KTM 520 EXE.
Old 11-21-2011, 01:51 AM   #354
Bell driver
Bell driver's Avatar
Oddometer: 349
It depends on what you need.
There are quite some industry standard parts in there.
You might have a problem when it comes to engine or transmission parts.
Plenty of spares in France.
http://www.leboncoin.fr/annonces/off...q=xlv+750&th=1
Pretty much everyone operating an XLV has one or two bikes sitting around for spares.
1988 Honda XLV750R
1989 KLR650A
1991 NX650
2007 XR650L
2008 KLR650E
Bell driver is offline   Reply With Quote
Old 11-21-2011, 08:03 AM   #355
Two Plugs
Two Plugs's Avatar
Oddometer: 1,390
...."Now I need to work on the front brake noise, any ideas?"
Steve
Same here. But I've just started to neglect the noice... In my case, it only occurs when I pull the bike backwards with the steering fully out to the right or left.
Old 11-23-2011, 04:59 PM   #356
RickS
RickS's Avatar
Oddometer: 608
I may have an opportunity to purchase as XLV. How is the parts situation in the USA for them? Any reoccurring issues that one needs to be aware of, but since it is a honda all should be well. Mainly concerned about parts. Looks like a really neat bike.
RickS is offline   Reply With Quote
Old 11-24-2011, 01:25 AM   #357
Bell driver
Oddometer: 349
I think they were never sold in the US.
Honda dealers are pretty much out of stock. Parts you'll find are the few ones common with other bikes.
For everything else you need to warm up the net and search.
I bought parts from all over the world when they were available and cheap. That gives me quite an inventory.
Grab the opportuniy and buy that bike!
1988 Honda XLV750R
1989 KLR650A
1991 NX650
2007 XR650L
2008 KLR650E
Old 12-04-2011, 12:50 AM   #358
Hodgo
TWIN Cylinder ADV
Hodgo's Avatar
Oddometer: 1,591
Few bits that might interest someone on here in Oz seeing as though these are getting very rare
http://www.ebay.com.au/itm/HONDA-XLV...item2316f8202a
Hodgo Spot
My North America Trip
RD07 Africa Twin, KTM 950 Super Enduro
www.facebook.com/KTM950SE
Retired.. CR500E & lots more
Hodgo is offline   Reply With Quote
Old 12-04-2011, 01:31 AM   #359
Old fart
Keen AG100 rider
Old fart's Avatar
Oddometer: 815
About $1700 dollars too much
Old fart is offline   Reply With Quote
Old 12-21-2011, 01:21 PM   #360
GASco
GASco's Avatar
Oddometer: 17
XLV 750 Fuel Pump Failed
Guys,
In the process of starting / running the bike (for the first time in a number of years) it would appear the fuel pump failed (plunger jammed) and then the fuel relay had the smoke escape, so that rendered it all useless, so am now looking for an aftermarket unit. In various threads I've seen details of the pump failing but haven't seen anything explaining what has been used in it's place.
If anyone has some handy hints as to what has been successfult and what hasn't, would appreciate your feedback.I can see REPCO have a variety of pumps which I believe could be adapted
To continue the story, got it running using a piece of hose direct to the carby's and with the help of gravity feed, had her purring in no time.
Man, it sounds good, although not sure what the neighbours thought at that time of night. I'm sure they will be understanding of a man and his toys ! ! !
Cheers, GASco
GASco is offline   Reply With Quote
Times are GMT -7.   It's 03:57 PM.
