Old 12-21-2011, 02:45 PM   #361
Bell driver
Bell driver's Avatar
Oddometer: 325
This might help:
http://moto.zoic.org/xlv/fuelpump.html
1988 Honda XLV750R
1989 KLR650A
1991 NX650
2007 XR650L
2008 KLR650E
Bell driver is offline   Reply With Quote
Old 12-22-2011, 12:32 AM   #362
Two Plugs
Two Plugs's Avatar
Oddometer: 1,303
Originally Posted by GASco View Post
Guys,
In the process of starting / running the bike (for the first time in a number of years) it would appear the fuel pump failed (plunger jammed) and then the fuel relay had the smoke escape, so that rendered it all useless, so am now looking for an aftermarket unit. In various threads I've seen details of the pump failing but haven't seen anything explaining what has been used in it's place.
If anyone has some handy hints as to what has been successfult and what hasn't, would appreciate your feedback.I can see REPCO have a variety of pumps which I believe could be adapted
To continue the story, got it running using a piece of hose direct to the carby's and with the help of gravity feed, had her purring in no time.
Man, it sounds good, although not sure what the neighbours thought at that time of night. I'm sure they will be understanding of a man and his toys ! ! !
Cheers, GASco
GASco, the fuel pump troubles are the same on the Africa Twin 750 and the MK1 Varadero 1000 (Carb version). I think this could be helpful:
http://users.bart.nl/~stikfort/new_i..._feulpump.html
Bernard 'Two Plugs', NL
Honda XL1000V Varadero & VFR1200X Crosstourer Forum www.vci-forum.com
22-25 May 2015: 17th Varadero & 4rd Crosstourer International Meeting, Milau, France!
Two Plugs is offline   Reply With Quote
Old 02-04-2012, 07:41 AM   #363
De motormuis
Oddometer: 3
Honda XLV750 R parts list
Hello,
Is there someone that has the Honda XLV750 R parts list? I can't find it on the internet.
Thanx!
De Motormuis
De motormuis is offline   Reply With Quote
Old 02-04-2012, 08:50 AM   #364
Two Plugs
Two Plugs's Avatar
Oddometer: 1,303
Originally Posted by De motormuis View Post
Hello,
Thanx!
De Motormuis
Will be difficult, Motormuis. I guess you are Dutch (regarding your name), did you try the Dutch club?
www.transalpclub.nl - select the Forum in the left menu, there is a special XLV750R section.
Old 02-05-2012, 06:22 AM   #365
ray3656
Oddometer: 81
also try
ray3656 is offline   Reply With Quote
Old 02-05-2012, 08:36 AM   #366
Two Plugs
Two Plugs's Avatar
Oddometer: 1,303
Not to mention XLV Guru Rolf from Switzerland:
www.xlv.ch
Old 02-17-2012, 12:44 PM   #367
sp1
Oddometer: 9
I have to mount new spokes on front & back wheel.
Is it possible to do it by myself?
Any good experience with companies in Germany, Netherlands, Belgium?
Thank you
sp1 is offline   Reply With Quote
Old 02-17-2012, 02:11 PM   #368
Bell driver
Oddometer: 325
Versuch' mal die hier.
http://www.menze-fahrzeugteile.de/ueber%20uns.htm
1988 Honda XLV750R
1989 KLR650A
1991 NX650
2007 XR650L
2008 KLR650E
Old 02-22-2012, 09:32 AM   #369
Two Plugs
Two Plugs's Avatar
Oddometer: 1,303
Thank you
Haan Wheels in Waalwijk (NL)
And
http://www.jvd-wheels.com/index.htm
The last company works together with the almost famous Laverda specialist Simon Poelman which is actually the guy who did all the wheels on both my 2 XLV's and a Transalp. I changed the original spokes for RVS (stainless steel). Paid around 90 per wheel.
Excellent job!
Please note... After a short while, you have to tighten the new spokes and re-align the wheels. Although it is a job you can do on your own, Simon did it for me.
Old 02-25-2012, 03:34 AM   #370
sp1
Oddometer: 9
Thank you
Thank you very much
Due to some other recomendations,
the distance between my home & the company,
a fast & acceptable quote I give the job to
Haan weheels.
Now I have to wait for 3 weeks.
Old 02-26-2012, 02:11 AM   #371
Two Plugs
Two Plugs's Avatar
Oddometer: 1,303
Haan Wheels is an excellent choice!
Old 04-07-2012, 10:15 AM   #372
Two Plugs
Two Plugs's Avatar
Oddometer: 1,303
XLV carburettor replacement NEEDED & WANTED...
Hi All,
Despite all efforts, the damage to my carburettor (see the XLV topic about my restoration here at www.advrider.com forum and www.varadero-international.com forum for details) is beyond repair. Fuel is leaking along the rubber seals. The intensive cleaning has revealed serious corrosion to the carbs; due to this corrosion, the rubber seals don't close as tight as they should...
I'm now looking to a carburettor set who can replace the original. Is there a valid and good substitute? F.e. Transalp XL600V or Africa Twin XRV750? Any advice is appreciated.
Tnx for your help,
Bernard, The Netherlands.
Old 04-16-2012, 08:56 AM   #373
Voorspoed
Voorspoed's Avatar
Oddometer: 10
Sorry for the hijack but do anyone know where I can get a set of big end bearings for the XLV?
I am in South Africa and would appreciate any help in this regard.
Voorspoed is offline   Reply With Quote
Old 04-16-2012, 09:36 AM   #374
Bell driver
Oddometer: 325
We are talking about the conrod bearings, right?
The size and part number depends on the diameter of your crankshaft.
The partnumbers are:
13218-ME9-003,
13219-ME9-003, or
13220-ME9-003.
These buggers are hard to come by, you have to do a world wide search.
I read somewhere that some Mitsubishi cars use the same size bearings, but that's hearsay.
The maintenance manual tells you which part you'll need for what crank diameter.
1988 Honda XLV750R
1989 KLR650A
1991 NX650
2007 XR650L
2008 KLR650E
Old 04-16-2012, 09:40 AM   #375
Voorspoed
Voorspoed's Avatar
Oddometer: 10
Thx so much Bell Driver, I will get the details and revert.
Times are GMT -7.   It's 01:43 PM.
