Old 08-03-2012, 03:11 AM   #256
hunter_greyghost
XS650 Allroads Traveller
hunter_greyghost's Avatar
Oddometer: 5,499
Nice, wheels aren't original, should be mags not wires,
or am I wrong again?, different countries - different wheels?
As you can see, I run whatever wheels as needed, can't get a decent knobby in 16", so I use 18" wire with a Dunlop 606,
Cheers
Baza
1981 XS650SH "Tourer" [ For Sale - when / maybe?], 1975 XS650B "Adventure" ['Kenny Krazyhorse'], 1982 XL500R 'Project'
www.aussiegreyghost.smugmug.com
Couldn't afford a 'GSA', so now it's an 'XSA' "I didn't do it! & whoever said I did, is a liar!"
hunter_greyghost is offline   Reply With Quote
Old 09-22-2012, 10:15 PM   #257
ThumperStorm
ThumperStorm's Avatar
Oddometer: 137
Originally Posted by SOS View Post
Question was what other front ends will meld with the XS650 and what issues are there?
I haven't melded the 1986 YZ125 front end to the 1979 XS650 yet, trying to finish off the F11 first. But I did some research before I bought the 125. The triple tree stem has the same inner bearing diameters as the XS650 stem, so barring any bearing height issues the YZ stem should mate in the XS head tube with the stock XS head bearings. The other issue is stem length. The XS650 stem is slightly longer than the YZ stem, but the YZ uses about a 1" tall top nut, so a shorter version might work.
Don't know if that is what you were after, but that's what I got.
Any updates on fitting the front end?
"Maybe you ain't in a rut, maybe you're in a ditch, way over your head." Don Marshall
ThumperStorm is offline   Reply With Quote
Old 09-22-2012, 11:33 PM   #258
hunter_greyghost
Oddometer: 5,499
+1
Cheers
Baza
Times are GMT -7.   It's 04:40 AM.
