Old 10-04-2011, 12:29 PM   #16
CycleDoc59 OP
Wrench Rider
CycleDoc59's Avatar
Oddometer: 984
Originally Posted by alexisan View Post
ok, will do that.
Was checking Loewes yesterday for Goop. Didn't have it. Where did you get yours?
Most hardware stores around here carry it. I find it very handy to keep around as it's flexible
and very tenacious....
This might help: http://www.biosafe-inc.com/ag_adhesives.htm
CycleDoc59 is offline   Reply With Quote
Old 10-06-2011, 10:33 PM   #17
fraler
Oddometer: 10
I used Goop to seal the front and rear wheels on a 95 Tiger
7 years ago, many flats and 170,000 km's since then with no issues at all with the Goop sealant. Also did the rear on my 950 2 years ago.
Just an ordinary day
fraler is offline   Reply With Quote
Old 10-07-2011, 08:38 AM   #18
alexisan
Oddometer: 190
and did you put it just on the spoke nipples or all around?
alexisan is offline   Reply With Quote
Old 10-09-2011, 11:06 PM   #19
backdaddy
FDNY never forget
backdaddy's Avatar
Oddometer: 35
Have any of you had problems inflating the tire after going tubeless? I did this last winter. Stock bear rims. The rear sealed easy. The front was a beaotch. Thought I would never get any air in it. Used a strap around the tire, a ton of tire lube and 100psi with out the valve stem in. I feel like I just got lucky, finally sealed. Not looking forward to replacing the tire.
I love my carbon footprint.
backdaddy is offline   Reply With Quote
Old 10-10-2011, 07:46 AM   #20
alexisan
Oddometer: 190
ok, got the goop and filled the nipples yesterday night. Now have to let it cure for 2 days...soo long...cant wait...
Did anybody try the front wheel too? (I know, no safety bed, etc...) anybody?
Old 10-10-2011, 10:38 AM   #21
fraler
Oddometer: 10
Alexisan
Just on the nipple, 3 layers seems to do the job. Some of the nipples
will need a wee bit more as you"ll see upon final inspection.
Old 10-10-2011, 06:29 PM   #22
alexisan
Oddometer: 190
I let it cure for 12 hours and put one layer on. Mounted the tire and it holds air. Lets see how it looks tomorrow...
So did someone do the front on an Adventure too?
Old 02-21-2012, 08:45 AM   #23
slammer218
Slammer
slammer218's Avatar
Oddometer: 148
Getting ready to do my rear rim on a 950. When you say just do the spoke do you do around the nipply also,and what about the valve stem, is an automotive stem that is used...
Ride until the wheels fall off then buy new
slammer218 is offline   Reply With Quote
Old 02-21-2012, 08:56 AM   #24
backdaddy
FDNY never forget
backdaddy's Avatar
Oddometer: 35
I did each spoke nipple with a glob of Goop, did 3 spokes at a time and let dry for about 20-30 minutes. I placed my wheel on a truing stand. I covered the spoke and the valley or indentation around the spoke, the Goop will flatten out as it dries. I did each spoke twice. When I put on the tire I had 2 that leaked. Had to redo them. I did my front wheel also, but inflating the front wheel and getting it to seat on the rim was next to impossible. The rear inflated no ptoblem at all. I have had one flat on the front, just pluged it, still going strong. Good luck.
Old 02-21-2012, 09:24 AM   #25
avocadofarmer
Fruit Coot
Oddometer: 294
I'd be tempted to add a strip of Christy's 10mil or 20 mil thick plumbing tape as rim tape too...That stuff is good.
Also a bit concerned about reseating the bead to the rim if a tire goes flat out in the boonies and I don't have a compressor to help with the volume. Suppose you could always throw in a tube if nothing else works.
avocadofarmer is offline   Reply With Quote
Old 02-21-2012, 11:01 AM   #26
brents347
Trusting my Cape...
brents347's Avatar
Oddometer: 3,913
How is it any easier to seat the bead if the tire has a tube in it?
Also, in my experience, even a tire with low pressure (25-ish) that does not have the bead seated will seat it on its own once you ride the bike. I think it is a combination of a little centrifugal force and putting heat into the tire but they always seat on their own for me.
07 Yamaha R6
07 KTM 950 Super Enduro
04 KTM 250exc- plated two-stroke
01 Kawasaki KE100
74 Honda MR50
brents347 is online now   Reply With Quote
Old 02-21-2012, 12:32 PM   #27
cristi-mic
cristi-mic's Avatar
Oddometer: 95
My approach: http://www.tenereclub.ro/index.php?p...3&t_id=346&s=1
Works perfectly, 2 sets of tyres and no problems.
http://cristi-mic.blogspot.com/
cristi-mic is offline   Reply With Quote
Old 02-21-2012, 01:25 PM   #28
dlrides
1:1.618
dlrides's Avatar
Oddometer: 5,493
So ...................... when you apply adhesive or sealant directly on the nipple, how do you tighten/adjust spokes ?
P.T. Barnum once said .............................
Flat track racers have been doing it for years with this method :
http://www.teamincomplete.com/Projec...elesswhee.html
“Men marry women with the hope they will never change. Women marry men with the hope they will change. Invariably they are both disappointed.”
― Albert Einstein
dlrides screwed with this post 02-21-2012 at 01:40 PM
dlrides is offline   Reply With Quote
Old 02-21-2012, 06:19 PM   #29
sstewart
sstewart's Avatar
Oddometer: 1,058
Tubeless
I let Woody's do mine.
sstewart is offline   Reply With Quote
Old 02-23-2013, 03:08 PM   #30
fuelish
Oddometer: 732
another lamb to the slaughter
Here I go. Needed a new back tire any way, so lets give tubeless a go. This is precleaning.
fuelish is offline   Reply With Quote
Times are GMT -7.   It's 05:51 PM.
