Old 12-13-2013, 04:24 AM   #1
Emoto OP
Sure, why not?
Emoto's Avatar
Oddometer: 18,632
Finding Map Files on Nav V (presumably also Zumo 660/665)
Tried to find a thread to add this as a reply to, and failed.
Anyway, I have a Nav V hooked up to a Win 7 machine and am poking around in all the folders trying to locate the map files to take a look at their names and properties, etc. My original motivation had been to see if there was a separate file for 3D. I had expected to find items with names like gmapsupp.img or similar but I find nothing with any kind of img extension.
Can anyone fill me in on how/where to view the map files on a unit like this? I have it set to show hidden files.
Old 12-13-2013, 09:27 AM   #2
DRTBYK
Long Haul Adventurer
DRTBYK's Avatar
Oddometer: 5,991
You must of had a hard night if you couldn't find the Nav-V thread...
How is the Nav-V connected? MTP or USB Mass Storage mode?
Cheers,
Dan
All Things GPS
Reviews at www.GlobeRiders.com
DRTBYK is offline   Reply With Quote
Old 12-13-2013, 11:26 AM   #3
Emoto OP
Sure, why not?
Emoto's Avatar
Oddometer: 18,632
Um... how do I tell the mode? I hook it up with its USB cable and then I use Windows Explorer to see the device after I hear the PC recognize that something has been attached. Screen caps from the PC below.
Old 12-13-2013, 12:48 PM   #4
DRTBYK
DRTBYK's Avatar
Oddometer: 5,991
The Nav-V mounted as a Removable Storage Device (USB Mass Storage) on your Windows computer - you can tell by the ICON used to represent it. As for the Internal Storage file structure, that's a new one on me.
Did you add the BaseCamp folder? If not, what's in it?
Cheers,
Dan
All Things GPS
Old 12-13-2013, 12:54 PM   #5
Emoto OP
Sure, why not?
Emoto's Avatar
Oddometer: 18,632
I did not add any folders.
Old 12-13-2013, 01:06 PM   #6
DRTBYK
DRTBYK's Avatar
Oddometer: 5,991
First, since my Nav-V hasn't shown up yet, I'm just speculating on all of this.
Interesting that Garmin included a "backup" install of BaseCamp...but I sure wouldn't install that version on my computer. The current version is v4.2.4. You could replace that one with the latest. Makes for a handy backup if you get caught without a computer somewhere and need (are allowed) to install BaseCamp on someone else's.
So, we still haven't found the maps. I'm getting the feeling that Garmin has put them behind the "firewall". Maybe one of the nuvi-tech literate folks can shed some light.
Never the less, I bet if you use Garmin MapInstall add a map to the "internal" storage it will show up as an installed map in the Settings > Map & Vehicle > myMaps. Then it would be interesting to see if that shows up in the Internal file structure.
Cheers,
Dan
All Things GPS
Old 12-13-2013, 01:35 PM   #7
Emoto OP
Sure, why not?
Emoto's Avatar
Oddometer: 18,632
I could try adding another map of some sort. Maybe this weekend.
Here is a piece of a file called GarminDevice.xml. Note the handful of .img references. There is also a tag before them called "path".
0380POID0743030C.gpi006-F0057-0151.Systemgmapbmap.img006-D2338-152014.Systemgmapprom.img006-D1074-00130.Systemgmaptz.img006-D2364-152014.Systemgmap3d.img006-D2248-002011.Systemgmapdem.img006-D3191-1120.System/JCVD3191110A.JCV006-B0970-
Old 12-13-2013, 02:28 PM   #8
DRTBYK
DRTBYK's Avatar
Oddometer: 5,991
The GarminDevices.xml file is XML code that tells my.garmin.com and Garmin Express or any other Garmin application that reads it what the device configuration is.
In this case the location of your Maps is in the ".System" directory.
Cheers,
Dan
All Things GPS
Old 12-13-2013, 02:36 PM   #9
Emoto OP
Sure, why not?
Emoto's Avatar
Oddometer: 18,632
Which I'll be damned if I can see anywhere.
Old 12-13-2013, 02:38 PM   #10
DRTBYK
DRTBYK's Avatar
Oddometer: 5,991
It is an operating system directory. Do you have "Show Hidden AND System Files" selected?
Cheers,
Dan
All Things GPS
Old 12-13-2013, 03:47 PM   #11
Emoto OP
Sure, why not?
Emoto's Avatar
Oddometer: 18,632
Yeah, and I still don't see it.
Old 12-13-2013, 03:52 PM   #12
DRTBYK
DRTBYK's Avatar
Oddometer: 5,991
Garmin may have hid it from being viewed.
Cheers,
Dan
All Things GPS
Old 12-13-2013, 03:59 PM   #13
Emoto OP
Sure, why not?
Emoto's Avatar
Oddometer: 18,632
Maybe, but there has to be a way to un-hide it, if its contents can be updated (and clearly they can).
Old 12-13-2013, 04:03 PM   #14
DRTBYK
DRTBYK's Avatar
Oddometer: 5,991
Not necessarily. The programs that can do the updates could communicate with the unit using a different protocol giving them "system" privileges.
Cheers,
Dan
All Things GPS
Old 12-13-2013, 06:46 PM   #15
georger
Oddometer: 8
Show Hidden System Files
Dan is correct about the name of the folder that includes the map. It is in the Garmin folder on the Navigator 5 device storage. I have a Mac and had to use an application called InVisible to be able to view it. I found it quite by accident while removing some .trashes folders. If you can view the hidden system files in Wndows you should be able to see the .system folder and the map.
Happy Hunting!
Rod
georger is offline   Reply With Quote
Times are GMT -7.   It's 12:57 AM.
