Old 12-05-2012, 10:45 PM   #31
eakins
Butler Maps
eakins's Avatar
Oddometer: 19,247
Originally Posted by Mack View Post
How about change the fluid, and see how it looks. If it's nasty then rebuild. Though it could very well look nasty and be fine, but as soon as you see ugly fluid coming out, it will be suspect in your mind, right? At that point I doubt I would be happy until I saw what the internals looked like.
I still say change the fluid every 6 to 12 monthes, and rebuild every other year. If it's just sitting, very low mileage I'd go longer, if it's ridden hard and/or lot's of miles, I'd rebuild annually. There now, it's all clear as muddy fork oil, isn't it?
If your riding the ADV as hard as you should have been riding that 400 SX, your more of a man then me!
because oil is constantly forced around in forks it's gonna be nasty even in 6mo.
Alaska
Butler Maps website:
http://www.butlermaps.com
Old 01-19-2013, 03:22 PM   #32
zimi
Oddometer: 62
Hi guys me again...
still doing some works on my bike. After the changing of oil and rebound needle, I wanted to put again the factory setting on the fork. I realized that I can turn endlessly the plastic knob n the to of the fork.... I suppose it has something to do with the rebound needle... Somebody can help me? I hope I don't need to dismount everythign again...
zimi is offline   Reply With Quote
Old 01-19-2013, 07:45 PM   #33
Aussie Steve
Aussie Steve's Avatar
Oddometer: 1,398
Go to the index page, this problem is discussed and written up very well in the fork rebuild how to here and on husaberg forum http://husaberg.org/forum/viewforum....3f2aa0bc617282
Aussie Steve is offline   Reply With Quote
Old 01-20-2013, 04:58 AM   #34
RideFreak
Green Chile Eater
RideFreak's Avatar
Oddometer: 6,239
Originally Posted by Bart View Post
Using thin brass shims (even a strip of aluminum pop can) under the slider seals helps prevent leakage past the damper.
Just my 2.5 cents.
Bart
Another trick that's been used for years is to get the long feeler guages, .002" works well and cut them to sit between the bushing and the outer fork leg. Thighens the bushing freeplay right up
Chris
"Life's journey is not to arrive at the grave safely in a well preserved body, but to rather skid in sideways, totally worn out, shouting ... Holy Shit, what a ride!"
CL Adventure Ride 2013 /CL Revisited 2014 / 700 Miles of Scenic Utah Backcountry / MY VIDEOS / RIDEFREAK TV
RideFreak is offline   Reply With Quote
Old 02-14-2013, 02:53 PM   #35
zimi
Oddometer: 62
Hi aussie Steve,
sorry but I couldn't find it. I found all the posts about oh to service the fork but not something explaining what to do in my case.
I checked this one:
http://www.advrider.com/forums/showthread.php?t=339544
and another one:
http://www.advrider.com/forums/showthread.php?t=164375
without success....
Can somebody help me to find the right topic please ??
Old 02-15-2013, 07:10 AM   #36
meat popsicle
Ignostic
meat popsicle's Avatar
Oddometer: 14,247
Originally Posted by zimi View Post
Hi aussie Steve,
I checked this one:
and another one:
without success....
I'm guessing you reassembled the rebound needle or adjuster incorrectly if the knob keeps turning... damn sorry to say. As my guide says (your first link above) the adjuster rod needs to be properly seated in the rebound assembly, so maybe you can get away with just opening the tops and try to seat the rod properly.
And did you search the Husaberg forum? Aussie Steve how'bout a direct link to the thread you were thinking of... I looked quickly and didn't find assembly advice for this component. But I did find this:
http://husaberg.org/forum/viewtopic....needle#p138197
Which mentioned this:
https://www.factoryconnection.com/Me...ry_Code=FCSHKP
Something to eliminate the rebound needle issue? I'd better ask a tuner about it first before recommending or trying it myself.
Kronreif Trunkenpolz Mattighofen LC4 640
Its not so much staying alive; its staying human that counts.
meat popsicle screwed with this post 02-15-2013 at 07:24 AM
meat popsicle is offline   Reply With Quote
Old 02-18-2013, 08:28 AM   #37
zimi
Oddometer: 62
Thanks Meatpopsicle,
no I didn't checked the Husaberg one...
But yesterday I finally found to time and the ...courage to dismount again and reopen my fork, and I found out what was the problem.
The adjustment screw didn't turn anymore.. the little plastic screw was not moving at all. I dismounted it and set it correctly and now it's working!!!
THANKS for your help
Old 02-19-2013, 12:02 PM   #38
meat popsicle
Ignostic
Oddometer: 14,247
Originally Posted by meat popsicle View Post
... But I did find this:
Factory Connection says that is not for the forks, and they don't make one for the forks... too bad.
Times are GMT -7.   It's 03:17 PM.
