Old 12-13-2011, 03:50 AM   #4171
Murphy Slaw
Murphy Slaw's Avatar
Oddometer: 1,594
Can I be your nephew?
Murphy Slaw is offline   Reply With Quote
Old 12-13-2011, 11:24 AM   #4172
ag_streak
Tiene Ruta Cuarenta?
ag_streak's Avatar
Oddometer: 3,188
Originally Posted by Ogre_fl View Post
Nothing major.
I think I may have routed some a little different but nothing that required taking anything apart.
FWIW I run the bars full width too, which is notably wider than stock.
You can cut their width down closer to stock if desired.
The biggest issues were dealing with the pins in the control housings that fit holes in the stock bars, and getting the vibe damper weights installed.
I simply ripped off the pins with pliers and added a bit of tape to the bars so the controls would fit tight and not turn.
I made some bar inserts out of big well nuts from Ace Hardware, but there are motorcycle specific bar inserts that you can buy that probably would bet better.
Ogre, how did you mount the well nuts in the end of the bars? Did you have to tack weld them in or something?
I'm assuming the Tusk bars are aluminum with thicker walls than steel bars, yes? I'm trying to figure out how to mount my bar ends on the Protaper Fatbars...
2013 Triumph Tiger 800, 2012 Suzuki DR650, 2006 Suzuki V-strom Sidecar Rig
ag_streak is offline   Reply With Quote
Old 12-13-2011, 11:55 AM   #4173
sieg
sieg's Avatar
Oddometer: 2,826
These maybe??????????
https://www.denniskirk.com/maier/del...prd/613291.sku
https://www.denniskirk.com/moose/out...prd/615212.sku
https://www.denniskirk.com/acerbis/r...prd/619307.sku
"Democracy is two wolves and a lamb voting on what to have for lunch.
Liberty is a well-armed lamb contesting the vote" Ben Franklin
Current bikes F800GS-EXCF350-Versys-690R-RZ350
sieg is offline   Reply With Quote
Old 12-14-2011, 03:10 AM   #4174
dhr
Explorer of suburbs
dhr's Avatar
Oddometer: 173
So I found out why my Versys keep blowing the fan relay. The fan motor went bad. Turns out Kawasaki wants over $300 for a new fan!! The local salvage yards wanted $100-$200. eBay was the easy choice at $29.00 with free shipping
00 Ducati Monster 750
GO Bears!!!
dhr is offline   Reply With Quote
Old 12-14-2011, 03:14 AM   #4175
Murphy Slaw
Oddometer: 1,594
Is it the EXACT same fan?
Old 12-14-2011, 06:44 AM   #4176
Ogre_fl
Ogre_fl's Avatar
Oddometer: 2,295
All the items sieg noted are the "correct" way to do it.
The Tusk bars are just like the Protapers and other "Fat" style aluminum bars with a different wall thickness.
I had the old bars off and realized that the stock bar ends did not have expandable inserts, but welded in ones.
I was too impatient and cheap (need that free shipping you know) to order what I needed, so it was off to ACE.
What I did was found the biggest and longest well nuts they had at ACE that would just fit in the end of the bar.
I trimmed off the flange so they would slide up into the bar and used new longer bolts with washers to attach the bar ends.
Leaving a little flange so its a very snug fit helps keep the nuts from turning when you first tighten them down.
Ogre_fl screwed with this post 12-14-2011 at 06:54 AM
Ogre_fl is offline   Reply With Quote
Old 12-14-2011, 09:31 AM   #4177
Jeff B
Socially Awkward
Jeff B's Avatar
Oddometer: 5,803
I replaced mine w/an EX650 fan. [ebay] It was slightly different, mounts and all. But it still fit and w/a little twisting lined up. My original also took a shit because of a piece of gravel jamming it.
Jeff B is offline   Reply With Quote
Old 12-14-2011, 06:57 PM   #4178
dhr
Explorer of suburbs
dhr's Avatar
Oddometer: 173
It came off a 2008 Ninja 650R which looks very similar. The 06 and 07 Ninja have a different fan. The Versys fan is made by Denso part # 065000-4140 but I was unable to find a chat with other applications for that fan.
GO Bears!!!
Old 12-14-2011, 07:24 PM   #4179
Oh2RideMore
Oddometer: 1,296
Pirelli front arrived today
Stopped by cyclegear to get a front and rear paddock stand, which are 1/2 off right now, 80$ for the set. With that anakee 2 rear, will be ready to change the tires soon. My grip heater set from symtec arrived as well, but no progrips yet. Ready to tear down the new bike and farkle it out.
2008 WR250R(Anywhere)
2009 Versys
Oh2RideMore is offline   Reply With Quote
Old 12-15-2011, 10:47 AM   #4180
RaY YreKa
I Am the Mayor
RaY YreKa's Avatar
Oddometer: 16,273
Claimed dry weight of the V is 181kg.
Anyone have accuracy of this, and/or wet weight?
IBA #40578
shine on, you crazy emo diamond
RaY YreKa is offline   Reply With Quote
Old 12-15-2011, 10:55 AM   #4181
eakins
Butler Maps
eakins's Avatar
Oddometer: 18,844
that's 399lbs for US riders.
Alaska
Butler Maps website:
http://www.butlermaps.com
Old 12-15-2011, 11:48 AM   #4182
RaY YreKa
I Am the Mayor
RaY YreKa's Avatar
Oddometer: 16,273
Yup.
My last bike (1150GS) has a claimed dry weight of 231kg, or 110lbs heavier than the V, if you'll excuse my mixing the measures
IBA #40578
Old 12-15-2011, 12:35 PM   #4183
Ogre_fl
Ogre_fl's Avatar
Oddometer: 2,295
The specs say 454.2 lbs curb.
I have seen "as measured" full fuel weights around the 455 lbs range from a few test and reviews.
A perspective that I have found interesting is that the Versys and the BMW G650GS single "as measured" weights are almost identical when holding the same quantity of fuel.
Though BMW specs would lead you to believe the GS is 25 lbs lighter.
Old 12-15-2011, 01:17 PM   #4184
Oh2RideMore
Oddometer: 1,296
85 miles now and riding continues
Have not switched the tires yet, just got the paddocks to lift the bike. Doing a motoman break in, and enjoying the ride. Twisted throttle is moving hq and no shipments until the 19th. :(
2009 Versys
Old 12-17-2011, 03:10 PM   #4185
Oh2RideMore
Oddometer: 1,296
doubled the miles today
Nice sunny day with the highs in the 40s. Took the versys out to test those dunlops on back roads today. Heated gear worked a little too well and burned my left hand knuckle. 140 miles of riding, fairly comfortable, great bike. 284 miles now on bike. At this rate, will have to do the 600 mile service on Christmas. Any words of advice regarding first service? Sounds like dealer is not needed. Just change the oil, check the chain and all bolts.
2009 Versys
Times are GMT -7.   It's 05:22 PM.
