Old 07-10-2013, 02:57 PM   #5716
everready
everready's Avatar
Oddometer: 532
Originally Posted by manx_20 View Post
I've been going to them for years and bought a ton of stuff there. I don't think they making it up. They didn't go CSI on it because when i brought it in I had a feeling that it wasn't good and just asked them to see why it wont start. They just gave me a list of possible causes. I'm going to get the bike back tomorrow. Like I said I'm no mechanic but I can certainly take things apart so I'll dig into it myself and see if I can find an obvious cause.
A few tips for you:
Work without distraction.
Keep your work area clean and well lit and organized.
Take a LOT of pictures.
Bag and label parts and store them logically.
Don't drink until after you're done for the day.
Take your time.
Do you have a Clymer for your bike? I'd probably buy one........
Good luck,
Al
everready is offline   Reply With Quote
Old 07-10-2013, 07:31 PM   #5717
manx_20
manx_20's Avatar
Oddometer: 425
Originally Posted by everready View Post
A few tips for you:
Take your time.
Good luck,
Al
That one might be tough
Like David pointed to above. I asked the shop for minimal work and some ideas and that's exactly what they did. I've been going there for years and its even gotten to the point where the older head mechanic there habitually gives me a stern talkin to about riding till my chain drags on the floor and my tires look something like this. They're not a bad shop just going on what information they have at hand. I should mention that they were happy to point out that its most likely cheaper and a better bet to find a good engine with lower mileage which they would be willing to do the swap for me.
┌∩┐(◣_◢)┌∩┐ Noo Joisey
manx_20 screwed with this post 07-10-2013 at 07:47 PM
manx_20 is offline   Reply With Quote
Old 07-10-2013, 08:15 PM   #5718
ToasterTech
Working for the Man
ToasterTech's Avatar
Oddometer: 41
Originally Posted by G.Smiley View Post
If you are interested in a really simple, easy to tow trailor with good capacity, check out Third Wheel Trailers. Really good people (like most of my friends otherwise they wouldn't be!). Best design for handling, great through the curves and a well engineered hitch.
http://www.thirdwheeltrailers.com/
Thanks, nice looking trailers. Seems like with a trailer, there would be very little reason to drive a car for running errands!
2011 Ducati Monster, 2009 Kawasaki Versys, 2004 KTM 250 EXC, 1997 Kawasaki KDX 200, 1994 Suzuki Dr 350 SE, 2002 Yamaha TTR 225, 1985 Honda XR 200
ToasterTech is offline   Reply With Quote
Old 07-11-2013, 03:20 AM   #5719
Murphy Slaw
Murphy Slaw's Avatar
Oddometer: 1,670
ok here goes
- oil was changed every 4k to 5k miles
- oil used either kawasaki oil or if I couldn't get to the shop when they were open I would use Castrol motorcycle oil found at Autozone which practically never closes
- oil filter was the kawasaki filter - i'd buy a few at a time for the reason above.
- valve clearances were checked with just about every tire change so between 11k and 13k miles
- spark plugs were changed once
Man, sounds like you did your part. I wonder if there are any Ninja's with failure around the same mileage?
I know there is somebody in here with over 70K on a Versys, but that's all I can think of.
This sucks.
Best of luck.
The Murph Channel
Acoustic Originals and some Double Aught
http://www.youtube.com/channel/UCkomGsMJXH9qn-xLKCv4WOg
Murphy Slaw is offline   Reply With Quote
Old 07-11-2013, 10:16 AM   #5720
EdM
Oddometer: 308
Sounds silly but: getting on the thing!?
A local dealer has a 2009 Versys available. I've been mulling over a 250cc class machine but this seemed like an attractive alternative at around the same price as a new 250.
I'm 70 years of age, 6' tall, and in decent condition but I could not swing my leg up high enough to get on the bike. I was mortified. I cannot imagine how those with saddle bags or top cases can do so.
Do many of you get on as if you were getting on a horse and step on the footpeg for assistance? I did not try that as it seemed like asking for a quick way to tip the bike over but it seems to be the only alternative.
Is there a trick I am unaware of?
Really curious.
Ned
EdM is offline   Reply With Quote
Old 07-11-2013, 10:20 AM   #5721
Kiko
Kiko's Avatar
Oddometer: 1,860
Speedy's lowering kit will lower it about 1 1/2"
http://shop.motowerk.com/Standard-Lo...-LK-STD-R2.htm
Conmigo piscas, y no moloncos.
Kiko is offline   Reply With Quote
Old 07-11-2013, 11:26 AM   #5722
sieg
sieg's Avatar
Oddometer: 2,900
Really curious.
Ned
Have you tried bending your leg and putting your knee over then just drag the rest of your leg over? It's doesn't look graceful but it gets the job done. BTW saddle bags ain't bad but I don't use my top case for this reason.
"Democracy is two wolves and a lamb voting on what to have for lunch.
Liberty is a well-armed lamb contesting the vote" Ben Franklin
Current bikes F800GS-EXCF350-Versys-690R-RZ350
sieg is offline   Reply With Quote
Old 07-11-2013, 11:36 AM   #5723
Neckrom
What was that!
Neckrom's Avatar
Oddometer: 116
Really curious.
Ned
I actually have my bike raised up about an inch and a half due to the mods I put on. I am 6ft tall and can touch fine when on the bike but I have the same issue mounting and dismounting. I do as you suggested and stand on the footpeg and then just raise my other leg over. It works like a charm and I have not had any problems. I actually started doing it on my KLX also just because its so easy. No stretching, kicking, running, nut hopping. Just an easy up and over.
Four wheels move the body. Two wheels move the soul. ~Author Unknown
Neckrom is offline   Reply With Quote
Old 07-11-2013, 12:41 PM   #5724
David R
I been called a Nut Job..
David R's Avatar
Oddometer: 2,588
I am only 52. If anything is on the rear seat, horse mount works fine. Side stand Is plenty strong.
Sent from the phone in my shoe. Maxwell Smart.
2012 R1200R ! 2000 R1100RT (parts for sale!), 1976 R75/6, 2014 Vulcan 900 Trike
There is a seat for everyone.
David R is offline   Reply With Quote
Old 07-11-2013, 02:54 PM   #5725
EdM
Oddometer: 308
I appreciate the replies.
Appears it would be worthwhile to have another look at the machine.
Ned
Old 07-11-2013, 04:22 PM   #5726
sieg
sieg's Avatar
Oddometer: 2,900
Ned
Being 6ft tall it may be a bit crowded. I'm 5'11" and had the seat raised and the
"pocket" moved back, it's perfect now. But my son is 6'5" and it was fine for him stock. It's my favorite bike!
Old 07-11-2013, 06:56 PM   #5727
ToasterTech
Working for the Man
Oddometer: 41
+1 I'm 6'1", started doing it on all my dirt bikes unless the ground is real soft, it just easier. BTW lowering the foot pegs and inch, raising the handle bars an inch and installing a Seat Concepts seat made the bike much more comfortable for all day riding. I have ridden single track to interstate and everything in between.... all in the same day. It is my favorite bike!
Old 07-11-2013, 07:28 PM   #5728
bash3r
I ain't no DingWeed
bash3r's Avatar
Oddometer: 1,741
I usually get on foot first right thru the seat area. You can also get a different seat that is lower cut than the stock. My Corbin is a bit lower than stock and makes a big difference .
Good luck! I hope to be still riding at 70!
08' Yamaha WR250R
09' Yamaha WR250F
14' BMW F800GSA
Adventure Tshirts | 3 Step Hideaway |Campground POIs
bash3r is offline   Reply With Quote
Old 07-12-2013, 06:34 AM   #5729
Gizzaride
Oddometer: 191
Thumb Reply from a youngster!!!
Well I'm a sprightly 61 yr old with a hip displacement (will need a hip surgery/replacement at some time) & I seemed to have a bigger problem with the KLR I had than the Versys I've just bought.Standing on the downside peg is quite acceptable.Here's the "1st Day on my Versys" video.
http://www.youtube.com/watch?v=UuFOlwIrTQ0
Gizzaride is offline   Reply With Quote
Old 07-12-2013, 09:34 AM   #5730
matloik
kludge
matloik's Avatar
Oddometer: 1,247
I'm pretty sure you were not properly ATGATT even while washing your new bike.
2011 KTM 250 XC-F / DRZ-ADV / 2013 WR250R (wife's)
matloik is offline   Reply With Quote
Times are GMT -7.   It's 12:50 PM.
