Old 10-28-2010, 04:10 PM   #136
Colebatch
"Moto Porn"ographer
Colebatch's Avatar
Oddometer: 3,983
Originally Posted by Cruz
Thanks to Az-Twin for his help, these arrived last week.
Will be a couple of weeks before the suspension shop can get to work on them and put the cartridges into the OEM forks as they are moving shop.
Have to make the bottom of the OEM forks look like this.
l
What exactly are they mate?
*** New Sibirsky Extreme Trail DVD Trailer HERE ***
Moroccan Extreme 2011 DVD available HERE
World Motorcycle Altitude Record video HERE
Sibirsky Extreme - The Home of Adventure Motorcycling in Siberia and Mongolia - On Facebook
Colebatch is offline   Reply With Quote
Old 10-28-2010, 11:42 PM   #137
Max Kool
Xtankteam™
Max Kool's Avatar
Oddometer: 3,239
My guess: a pair of Marzocchis
Max Kool is offline   Reply With Quote
Old 10-29-2010, 12:05 AM   #138
gsd4me
90% bluff
gsd4me's Avatar
Oddometer: 7,571
My guess would be; bloody expensive.
David Hunn:
R100GS Ray Peake special.
http://www.advrider.com/forums/showt...uild+australia
gsd4me is offline   Reply With Quote
Old 10-29-2010, 05:05 AM   #139
FinnDuro
Winter wonderlanding
FinnDuro's Avatar
Oddometer: 379
I'll chime in with a guess: Marzocchi Shivers off of Aprilia RXV.
GSD4ME: Decent 45mm USD Shivers can usually be found for around 250-300 US$, relatively affordable in my books.
Stable: BMW R 80 GS -90, KTM 690 Enduro R -12 // finnduro.com
FinnDuro is offline   Reply With Quote
Old 11-01-2010, 05:17 AM   #140
Cruz
Lost but laughing.
Cruz's Avatar
Oddometer: 6,093
Max and Finn are both right.
$300usd plus freight. Still a lot cheaper than a single cartridge from Marzocchi (if you could get one)
Could have a wheel spacer made and a disc adapter, plus the lower triple clamp area on the stanchion needs to be about 3mm smaller in diameter, otherwise axle and top clamp are correct size.
I want to keep the ABS so will go with the cartridge replacement instead and see how that works.
Just a question for those who have played with the OEM forks, has anyone ever fitted 2 OEM right hand side rebound cartridges to the OEM forks and see how they worked?
"I reckon it would be good getting a heap of XR's in the one spot and watching a heap of blokes kicking fuck out of there bikes and swearing."
xronly
Cruz is offline   Reply With Quote
Old 11-01-2010, 10:12 AM   #141
Colebatch
"Moto Porn"ographer
Colebatch's Avatar
Oddometer: 3,983
XC stanchions
Just a thought, for people before they spend too much on original forks:
My originals that I used last year are (i think) slightly bent. Getting the sliders back into after taking them out for a service was pretty tough. Can check to confirm it later.
Before I started last years ride, Simon Pavey who raced one in the Dakar in 08 had briefed me that the stock XC stanchions (tubes) were made of a soft metal on the XC. After bending 3 pairs, he swapped his stanchions out for same sized but better metal units from a HP2.
Only problem is, since they dont make HP2s anymore, the HP2 stanchions are rare as hens teeth and super expensive.
Just something else to bear in mind.
Maybe the shiver stanchions will fit? Are they the same length?
Old 11-02-2010, 12:21 AM   #142
Cruz
Lost but laughing.
Cruz's Avatar
Oddometer: 6,093
The stanchions are the same length on mine just the lower clamp area is slightly larger but could be turned down to fit properly.
New Marz 45 sliders are about a cm longer than OEM.
Will be keeping my bits for spares.
xronly
Old 11-02-2010, 02:07 AM   #143
FinnDuro
FinnDuro's Avatar
Oddometer: 379
Note to all: when / if you need to machine down the lower triple clamp area on the Marzocchi Shiver tubes to make them fit into original Xchallenge triples, be careful not to overtighten them upon final installation.
10Nm is adequate torque for the lower triple clamp bolts. More than that, and you risk squeezing the machined tubes too much, resulting in stiction and general shitty behaviour. On the top triple clamp area, 25Nm should suffice, and it's not that critical.
(and I have a set of RXV Shivers coming in, too - building a set of forks for my friend's X.)
Old 11-03-2010, 01:20 PM   #144
magno
Oddometer: 38
Shivers
Hi all
Anyone out there know if the 45mm Marzocchi Shivers from a 2007 Gas Gas EC250 will fit the X Challenge?
I was hoping to keep the original sliders and fit the stanchions from the new forks.
Any help appreciated.
magno is offline   Reply With Quote
Old 11-04-2010, 05:25 AM   #145
FinnDuro
FinnDuro's Avatar
Oddometer: 379
Originally Posted by magno
Anyone out there know if the 45mm Marzocchi Shivers from a 2007 Gas Gas EC250 will fit the X Challenge? I was hoping to keep the original sliders and fit the stanchions from the new forks. Any help appreciated.
eBay UK, huh? :)
For what it's worth, i.e. my opinion: I think they should be ok.
Old 11-10-2010, 01:32 AM   #146
Colebatch
"Moto Porn"ographer
Colebatch's Avatar
Oddometer: 3,983
Marzocchi factory series 45s
I recently picked up a set of the Black Marzocchi 45mm Factory Series forks ... http://www.marzocchi.co.uk/moto/45legsend.html
They dont make them anymore, but I found a pair on Ebay.
I got them because my old riding buddy Terry (BAM Road Terry) bought a pair for his X-Country and said they fitted straight in. I had thought about using these a year ago, but dismissed it because I thought they were the wrong size for the stock triple clamps ... but I was wrong.!
Like other compatible Shiver transplants, this is probably the easiest high quality fork transplant for the X-Country / X-Challenge. They fit right in. All that needs to be done is to spin off the axle clamps from the stock forks, drill access for the compression adjustment and put them on the black anodised sliders on the Marzocchis.
Here is Terry's bike yesterday in the Hyperpro workshop in Alphen, Holland. Bas was respringing and revalving, and changing the weight of oil in the forks. The bike sits as high as an X-Challenge now
Colebatch screwed with this post 11-10-2010 at 01:52 AM
Old 11-10-2010, 02:16 AM   #147
Cruz
Lost but laughing.
Cruz's Avatar
Oddometer: 6,093
Will be good to read what he thinks of them.
Still waiting for mine to be done the same way.
xronly
Old 11-10-2010, 02:39 AM   #148
Colebatch
"Moto Porn"ographer
Colebatch's Avatar
Oddometer: 3,983
I will also do a set for my XChallenge ... so will be able to compare directly with the WP forks I have in there now.
Will do a full write up when I begin
Old 11-10-2010, 05:59 AM   #149
motobone
Free for all!
Oddometer: 222
Wanted - used front fork
I went for a litle ride last week, had a couple of offs, just like any other day. However, on my ride yesterday, I noticed my newly replaced fork seal was leaking like crazy. Upon further inspection, I noticed this--
I've been reading the posts and it looks like were left out for replacements without some fabrication and a fist full of cash, which I'm a little short on.
I'm hopefully going to be able to still use these forks for this weekend, but I'm not sure.
So, does anyone have a front fork they want to get rid of? I'm trying to avoid the $700 to purchase a new upper fork.
I'm also open to options for an upgraded front end now.
Every time you eat meat, a hippie drops his hacky sack.
2007 BMW G650X Ch
2012 Husqvarna TE310
motobone is offline   Reply With Quote
Old 11-10-2010, 11:13 PM   #150
FinnDuro
FinnDuro's Avatar
Oddometer: 379
Umm, what actually is the "this" in your photo? Damaged dust seal, no?
Or have you opened the fork, and there's something terribly wrong inside there... that a new dust seal, oil seal and bushing replacement will not fix?
Times are GMT -7.   It's 08:19 AM.
