Old 11-10-2010, 11:59 PM   #151
pampaX
pampaX's Avatar
Oddometer: 431
Does anybody know if this ones would fit?
Marzocchi Shiver 45mm forks Beta
This is a set of take off front forks from my 2008 Beta 525
pampaX is offline   Reply With Quote
Old 11-11-2010, 05:22 AM   #152
motobone
Free for all!
Oddometer: 222
You're right. It's already been fixed. I was just a little nervous since I have a ride planned this weekend, so I was looking to overnight parts if necessary.
If I didn't have the ride planned I would, I would start really working on the front end and use this as an excuse.
Originally Posted by FinnDuro
Umm, what actually is the "this" in your photo? Damaged dust seal, no?
Or have you opened the fork, and there's something terribly wrong inside there... that a new dust seal, oil seal and bushing replacement will not fix?
Every time you eat meat, a hippie drops his hacky sack.
2007 BMW G650X Ch
2012 Husqvarna TE310
motobone is offline   Reply With Quote
Old 11-11-2010, 07:48 AM   #153
sideway5
Mudmuppet
sideway5's Avatar
Oddometer: 36
Fork clamp diameter
I've tried searching but couldn't find any reference to the diameter of the upper and lower fork clamps? Anyone got the numbers at hand? I don't have my bike at hand so can't take the measurement myself atm.
sideway5 is offline   Reply With Quote
Old 11-11-2010, 09:59 AM   #154
FinnDuro
Winter wonderlanding
FinnDuro's Avatar
Oddometer: 380
The OEM fork clamp, and respective fork tube, diameters are: Upper 54mm, Lower 57mm.
And just for information, when considering forks conversions based on Marzocchi Shiver 45mm units off of other models:
Aprilia RXV forks: upper 54mm, lower 57mm
Husqvarna TE forks: upper 54mm, lower 58mm.
Stable: BMW R 80 GS -90, KTM 690 Enduro R -12 // finnduro.com
FinnDuro is offline   Reply With Quote
Old 11-11-2010, 10:44 AM   #155
sideway5
Mudmuppet
sideway5's Avatar
Oddometer: 36
Great info, many thanks!
Old 11-11-2010, 04:12 PM   #156
magno
Oddometer: 38
How many litres is that fuel tank?
magno is offline   Reply With Quote
Old 11-12-2010, 05:25 AM   #157
Colebatch
"Moto Porn"ographer
Colebatch's Avatar
Oddometer: 3,992
Think Terry said it was about 7.5 litres
*** New Sibirsky Extreme Trail DVD Trailer HERE ***
Moroccan Extreme 2011 DVD available HERE
World Motorcycle Altitude Record video HERE
Sibirsky Extreme - The Home of Adventure Motorcycling in Siberia and Mongolia - On Facebook
Colebatch is offline   Reply With Quote
Old 11-12-2010, 05:34 AM   #158
Niedz
Niedz's Avatar
Oddometer: 642
is that tank being sold, or is it a one-off?
Niedz is offline   Reply With Quote
Old 11-12-2010, 06:09 AM   #159
Colebatch
"Moto Porn"ographer
Colebatch's Avatar
Oddometer: 3,992
one off
Old 11-12-2010, 06:11 AM   #160
Colebatch
"Moto Porn"ographer
Colebatch's Avatar
Oddometer: 3,992
And to confuse it more ...
I have noticed the Black Factory Series 45mm Marzocchis are sometimes 57mm at the bottom clamp and sometimes the 58mm (or more like 58.4mm I think) size.
Go figure
Old 11-12-2010, 11:34 PM   #161
Dukehunt
Dukehunt's Avatar
Oddometer: 802
Well all was going well on the WP front fork conversion until I hit a small snag,
Emig lower triple clamp with new bearing installed, all looks fine, install triple clamps, forks etc and mount the brake caliper, put the front wheel on and it is 2mm out of alignment with the disk to caliper ratio, bled, centred and double checked.
First thought, dam brake caliper spacers not right size, 2mm to thin, nah, can't be that simple, ok lets measure everything.
After checking all the distances the wheel is 2mm offset to the left (non brake side), okay back to the machine shop and get new wheel spacers made up +2mm on the left and -2mm on the right, that will also align the original supplied brake caliper spacers.
Will hopefully get that done this week and try again next weekend
Dukehunt is offline   Reply With Quote
Old 11-13-2010, 01:29 AM   #162
Cruz
Lost but laughing.
Cruz's Avatar
Oddometer: 6,285
These things were not meant to be easy it seems, makes you appreciate them more when it is completed. (Hopefully)
Mine could bolt on except for the lower leg diameter being slightly bigger then OEM so I will have the cartridges changed over to the OEM forks instead.
"I reckon it would be good getting a heap of XR's in the one spot and watching a heap of blokes kicking fuck out of there bikes and swearing."
xronly
Cruz is online now   Reply With Quote
Old 11-13-2010, 04:19 AM   #163
Colebatch
"Moto Porn"ographer
Colebatch's Avatar
Oddometer: 3,992
You are not going to machine down the shiver stanchions to fit? They will be a better alloy for sure. As mentioned above. The stock ones have a reputation for bending just from hard riding.
Old 11-13-2010, 06:43 AM   #164
Cruz
Lost but laughing.
Cruz's Avatar
Oddometer: 6,285
I am not sure whether I will ever ride hard enough to bend the OEM ones, but if I do then Iwill have the others ready to be machined down and fitted straight away.
The suspension shop may suggest your idea is the better way to go so i will wait and see what they say. I could use the aftermarket fork if I could make up a disc caliper adapter to suit the XC front brake.
xronly
Old 11-13-2010, 06:47 AM   #165
LukasM
Oddometer: 5,427
Aren't the sliders the same size? Then the insides of the stanchions would be as well. Maybe the weakness of the X-Ch stanchions simply comes from the fact that they are thinner?
Times are GMT -7.   It's 03:09 AM.
