Old 10-24-2008, 09:17 AM   #16
Oni
Ronin
Oni's Avatar
Oddometer: 1,838
Check out Gaspipes thread in the X Challenge index. Marzocchi Shivers fit with some mods.
Oni is offline   Reply With Quote
Old 10-24-2008, 09:22 AM   #17
johan
johan's Avatar
Oddometer: 249
Hmm, slightly beyond my budget I think...
08´KTM 250 EXC-R (Yes, it's getting silly...)
08´KTM 450 EXC-R (can't stop buying...)
07' BMW X-Challenge (For the longish trips)
03' KTM 640Adv (Passed on to other hooligan)
04' BMW 650 Dakar (Oops, totalled)
81' YAMAHA YZ 125 (Died in my arms of old age)
johan is offline   Reply With Quote
Old 12-31-2008, 04:48 PM   #18
Dagwood_55
Dagwood_55's Avatar
Oddometer: 994
Another question about setting the front suspension
Hate to sound dumb, but when you guys say -5, and -5 settings: Do you mean 5 clicks to the - (counterclockwise) from the stock settings?? and the same on the other fork?? I weigh 190lbs and want them soft as I don't ride hard or jump.
If this is not correct, what does it mean??
Live long, love much, laugh often, and
Ride, Ride, Ride.....
Dagwood_55 is offline   Reply With Quote
Old 12-31-2008, 09:24 PM   #19
FlyingFinn
Oddometer: 939
Yes. Yes.
That's correct.
Mikko
FlyingFinn is offline   Reply With Quote
Old 12-31-2008, 09:47 PM   #20
gsd4me
unconditional love
gsd4me's Avatar
Oddometer: 5,619
Exactly what are the stock setting? I bought my bike second hand, and I`m guessing things had been played with.
David Hunn:
R100GS Ray Peake special.
http://www.advrider.com/forums/showt...uild+australia
gsd4me is offline   Reply With Quote
Old 01-01-2009, 04:52 AM   #21
Dagwood_55
Dagwood_55's Avatar
Oddometer: 994
My new bike stock settings were 11 clicks - (counterclockwise) from all the way in (clockwise), on both sides.
Glad to learn this, I'm going riding this morning and the stock setting is quite hard to me.
Old 01-01-2009, 01:38 PM   #22
gsd4me
unconditional love
gsd4me's Avatar
Oddometer: 5,619
Thanks for that mate, that means they were set at half way. I`m new to having adjustable forks, having previously run airheads.
David Hunn:
gsd4me screwed with this post 01-01-2009 at 11:26 PM
Old 01-01-2009, 06:09 PM   #23
tbarstow
Two-wheelin' Fool
tbarstow's Avatar
Oddometer: 2,565
Front Suspension Dive during braking
What is the best working solution that anyone has come up with for dealing with the excessive front end dive during braking? New springs?
tbarstow is offline   Reply With Quote
Old 01-01-2009, 07:39 PM   #24
ropedrag
ropedrag's Avatar
Oddometer: 312
Best thing I've found is a light tap on the rear brake, seems to deal with it fairly effectively.
Do not mistake for wisdom the fantasies of your sick mind
ropedrag is offline   Reply With Quote
Old 01-04-2009, 12:05 PM   #25
Cail
Oddometer: 118
Stiffer springs solves that problem. Touratech has them. They are Wirth springs I think you can source them from Hyperpro or Wilburs as well.
Todd Davis
TRS, AMRA, AMA, BRC
Cail is offline   Reply With Quote
Old 01-05-2009, 01:53 AM   #26
Max Kool
Xtankteam™
Max Kool's Avatar
Oddometer: 3,206
Send a message via MSN to Max Kool Send a message via Skype™ to Max Kool
You really find the front dive that excessive? I never bottomed the forks out under braking, even in rocky terrain. I'm inclined to think stiffer springs will not only reduce front dive, but reduce the effective suspension travel as well.
I mean, you can hardly have one without the other.
Max Kool is offline   Reply With Quote
Old 01-05-2009, 08:41 AM   #27
tbarstow
Two-wheelin' Fool
tbarstow's Avatar
Oddometer: 2,565
I guess that my GSA has affected my perception of how much the front end dives on the X. How stiff the spring is won't affect the net travel of the front end, just what load it takes to compress the springs.
An earlier post put the spring setup for a 75 kg (165 pounds) rider. I'll weigh in at 95-100kg (210 to 220 pounds) geared up, so I probably need to swap the springs out so I don't have excessive sag in the front end to begin with and this should help me to keep the front end from bottoming out on the trail.
Old 01-05-2009, 09:00 AM   #28
DiscoDino
DiscoDino's Avatar
Oddometer: 1,812
I'm 275lbs geared up, and the front dive could be better, but it isn't THAT much excessive...as Max said, the stiffer springs will result in less suspension travel/effectiveness when not braking (most of the time)...
Adventurer transitioning from 4x4 to 2x1
'07 G650Xch - Under Mod-struction
DiscoDino is offline   Reply With Quote
Old 01-05-2009, 01:48 PM   #29
mcftw
hxc n33b
mcftw's Avatar
Oddometer: 454
Are they progressive springs?
"Open up your mind and think like me." Jason Mraz
mcftw is offline   Reply With Quote
Old 01-05-2009, 05:18 PM   #30
MTDewX8
MTDewX8's Avatar
Oddometer: 503
I remember my test ride and was very surprised on its dive when braking.
granite I am not used ot it and on a test ride so I coudlnt' get all crazy.
but I felt like I was going to do an Indo trick or something.
but that is just me of cousre.
Bike-less at the moment
MTDewX8 is offline   Reply With Quote
Times are GMT -7.   It's 02:42 AM.
