Old 04-30-2009, 02:50 PM   #61
oggi
oggi's Avatar
Oddometer: 69
does anyone know if the bearing cups on the x-chal are the same diameter as on the f650?
oggi is offline   Reply With Quote
Old 05-01-2009, 02:06 AM   #62
Max Kool
Xtankteam™
Max Kool's Avatar
Oddometer: 3,237
I've been told there's even the same as those from a K100 or a BMW airhead.
Max Kool is offline   Reply With Quote
Old 05-01-2009, 03:46 AM   #63
DownhillChief
bOOb
DownhillChief's Avatar
Oddometer: 46
I don't like the screws to adjust the forks. Anyone knows good and easy to fit 'knobs'? Would be so much easier...
2007 BMW G650 XCH (to be farkled)
2002 BMW F650GS Dakar (to be sold)
DownhillChief is offline   Reply With Quote
Old 10-01-2009, 08:32 AM   #64
bmw_elvis
bmw_elvis's Avatar
Oddometer: 12
i m also interested in this option...has anyone done this?
bmw_elvis is offline   Reply With Quote
Old 10-01-2009, 05:53 PM   #65
R80 STrider
Oddometer: 40
Everything comes at a price! I believe Wunderlich sell knobs for this very purpose.
R80 STrider is offline   Reply With Quote
Old 10-06-2009, 02:10 PM   #66
Rordog
Oddometer: 154
Question
Just wanting to know if there are any tricks about taking the forks apart to put new springs and oil in. Do I take the caps off, then drain the oil, and install new springs and oil. I've looked all over and cann't find any information. Anything would help.
Rordog is offline   Reply With Quote
Old 10-06-2009, 02:33 PM   #67
mattconeill
non-n00b
mattconeill's Avatar
Oddometer: 50
I would also like to learn how this is done...
Especially if it is easy-ish... Are people using the aftermarket Touratech springs? Does Ohlins make springs for these shocks?
Thanks in advance!
__________________________________________________ __________________________________________________
Own: '07 BMW G650X Challenge; '99 BMW R1100s; '92 BMW R100gs
Sold: '07 KTM 990 Adv; '03 Ducati 999; '01 Kawasaki KLR 650; '98 Suzuki DR200se; '82 BMW R65ls (restored)
mattconeill is offline   Reply With Quote
Old 10-07-2009, 08:48 AM   #68
"A"
numbum
"A"'s Avatar
Oddometer: 375
I put in a set of Wilbers. They provided instructions that gives the info needed. It required removal of the forks from the bike, taking caps off etc. Correct procedure to put in the right amount of oil and purge out air is explained. Hope this helps.
"A" is offline   Reply With Quote
Old 10-08-2009, 07:45 AM   #69
Cruz
Lost but laughing.
Cruz's Avatar
Oddometer: 5,976
Hyperpro do springs for the XC as well.
"I reckon it would be good getting a heap of XR's in the one spot and watching a heap of blokes kicking fuck out of there bikes and swearing."
xronly
Cruz is offline   Reply With Quote
Old 10-08-2009, 08:16 AM   #70
DownhillChief
bOOb
Oddometer: 46
Is there some kind of report of all these aftermarket springs? I really don't like the stock ones but have no idea which springs to get...
Old 10-08-2009, 11:12 PM   #71
Cruz
Lost but laughing.
Cruz's Avatar
Oddometer: 5,976
I have read a few reports and received info from owners who have changed springs on the XC. Most gave the Hyperpro a huge + for improvement while some other brands did not make that much difference.
Other than oil and springs there is not much else that can be done to the standard fork. In Oz Hyperpro front springs are approx $250 and the rear shock is $1650 (compared to the Ohlins for $760 delivered).
Might just do the front springs and oil first and see what the difference is and then think about the Ohlins.
xronly
Old 10-18-2009, 12:49 PM   #72
Pine Sol
Pine Sol's Avatar
Oddometer: 498
me likes this photo............................................. .....Ride Report Here
if its only gonna take Hyperpro front springs, with a Hyperpro rear shock, to get my bike to do this.
then me thinks its money well spent.
Pine Sol is offline   Reply With Quote
Old 12-15-2009, 02:21 PM   #73
plumley51
Oddometer: 1
Question frt suspension
I understand that many of you wanted to alter your front suspension. I would like to pursue altering the frt height (I'm 6' 1 1/2") and as I ride it feels like the bike is angled rear-to-frt. There is aprox 1in 4/64 of tube above the clamp. So what happens to the handling if I raise the clamp. Nothing in the owners manual about the tube height. I'm a newbe oh yea I weigh 225lbs. I see some have changed using risers, I have ABS and am not sure of my cable length allowance.
plumley51 is offline   Reply With Quote
Old 12-25-2009, 03:24 PM   #74
evoluzione
evoluzione's Avatar
Oddometer: 333
revalving the xc front forks
i've been playing with the front fork valving on my xc and have found there is a lot of potential with these forks (yes, i know it supposedly can't be done but by machining my own parts i can now make changes to valving/shims).
i've found the compression side really does nothing until you get through most of the travel. the rebound side has the control of both rebound & compression but the adjustment screw only affects rebound. by modifying the compression side i've found a lot more control throughout the range as well as the ability to have meaningful adjustments.
as i continue to test out the settings i will post my findings.
regards,
ken zeller
president - evoluzione cyclesports
www.evoluzione.net
evoluzione is offline   Reply With Quote
Old 12-25-2009, 07:42 PM   #75
Cruz
Lost but laughing.
Cruz's Avatar
Oddometer: 5,976
and we wait with baited breath.........
and orders and money.
xronly
Cruz screwed with this post 12-26-2009 at 02:04 AM
Times are GMT -7.   It's 01:27 PM.
